If I have several audio devices connected to an IP network I would like to be able to route audio between them without the need to plug audio cables or connect via a mixing desk. An example might be that I have two Zynthians and want to take the audio from one and route it to the other. Maybe I want to use a common reverb for all my Zynthians or I may be using one as the main mixer without an outboard mixing console. It would be good if there was little (or zero) configuration required and that Zynthian detected other audio devices automatically.
There are a few ways to do this which include:
- netJack1: This supports low-bitrate codecs but requires source and destination to be defined at start-up (no discovery option). I donāt this this is a good match for this requirement.
- netJack2: This allows an arbitary quantity of clients to connect to a main device with automatic detection (within same LAN segment). Each client may have the quantity of network inputs and outputs (audio and MIDI) defined as well as its client name (defaults to hostname). This looks appealing but it loses JACK ports when disconnected from main device which will lose routing within current Zynthian implementation - this could be resolved in Zynthian. There must be exactly only one main device on the network which may be limiting, i.e. this is server / client, not peer-to-peer. A client is already easy to define by selecting āCustom Deviceā soundcard and using JACK parameters
-d net -C2 -P2 -i1 -o1
. To enable the server side we need to add a feature to load / unload the netmanager internal client (which is fairly simple) and then offer ability to route from JACK client ports called, āfrom_slave_1ā and āfrom_slave_2ā which is a fairly trivial tweak in Zynthian Audio Router. This looks quite a good match for this requirement, requiring only small changes to Zynthian. - jack.trip: This requires destination to be defined at start-up (no discovery). I donāt this this is a good match for this requirement.
- zita-j2n: This requires destination to be defined at start-up (no discovery). I donāt this this is a good match for this requirement.
There may be other protocols that we could look at, e.g. AES67, Dante, etc. These may improve interoperability. There are some opensource AES67 implementations like this one.
This may be a niche feature but I do see some wider uses, e.g. connecting to digital infrastructure (probably requires standard protocol like AES67) or Internet connectivity for rehearsal / performance (may require data reduction using current Internet technology).
