OK, will not use raspi-config and have not performed any previous runs on this install which is another clean install from yesterday.
I’ve attached the wav file, details are as follows:
HW: Raspberry Pi 4B (Model B) Rev 1.2
O/S:Linux zynthian 5.10.60-v7l+ #1449 SMP
Sound Device: card 2: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Webconf → Hardware → Audio →
Soundcard:
RbPi Headphones
Driver Config:
dtparam=audio=on
audio_pwm_mode=2
Jackd Options:
-P 70 -t 2000 -s -d alsa -d hw:Headphones -r 44100 -p 512 -n 3 -X raw
Audio Notes Options:
-O complex -t 0.5 -s -88 -p yinfft -l 0.5
Mixer:
Headphone Left,Headphone Right
All boxes unchecked.
Sound:
DX7 Wurlitzer/RA wurly notes C2 to B2 on (Keystation Mini 32 default octave settings)
Recorded:
Output from Pi 3.5mm into Focusrite solo into Ableton, Aif converted into wav with slight gain increase.
Notes:
Have tested using multiple headphones which are confirmed to be working both ears.
Sound test in Zythian admin panel produces similar sound to sample file.
If anyone can confirm the best non-breaking way to test the soundcard outside of Zynthian , my connection is either via the UI now using a K400 or remote via ssh.
File attached:
