It’s a lightweight simple emulation of a Hammond organ, with drawbar control.
Here’s the README from the repo:
Three SFZ files:
DrawbarOrgan.sfz - control drawbars with CCs. NOTE: uses too many voices.
keyswitch.sfz - select registration by keyswitch
modwheel.sfz - select registration by Mod wheel
For best results, use with X42 Whirl rotary speaker sim.
Details below.
DrawbarOrgan.sfz
Control drawbars by CC
NOTE: Every drawbar that’s not at zero uses a voice. That’s a lot!
To reduce voice usage, a drawbar voice is not played if that drawbar
is at zero. What this means is, while you can change drawbars as
you play, moving a drawbar from up from zero has no effect until
new notes are played.
The general idea for this sfz is that you’ll adjust drawbars and
save the preset, and in general won’t be fiddling drawbars as you
play with this organ. If you want to do stuff like that, use SetBFree.
Could we have different waveform types? It would be nice to have triangle, sawtooth and square to emulate the 70’s transistor combo organs sound.
Is really overkill having the 9 voice per note? It’s quite annoying when you hold a chord while moving the drawbars and you can’t listen how the sound change when moving those drawbars that was at 0 when you played the chord. I think this behavior is not acceptable for most organ players.
The 9 voices per note is just for the one SFZ file (DrawbarOrgan.sfz.) You can move the drawbars while holding a chord, but just not from zero. Pull them all out at least a bit and then move them. That’s to avoid using 9 voices when some are at zero. Also, you can easily defeat that by commenting out the loccxx=10 at the end of each <region> line.
As a compromise, the default setting could have all drawbars playing. Or we could disable the optimization to turn off voices with drawbars at zero (below 10 actually.) The current default is 888-0000-000, which is pretty much the most common setting for blues and a lot of rock.
Other waveforms added, CC1: sine, square, triangle, sawtooth.
It also defaults to all voices on, but the other ones are at 1 so very quiet. Still, setting a drawbar to zero stops that voice so you need to retrigger (play again) to get it if you increase it again.
Sadly, there isn’t another way to get CCs to control the drawbar voices without them being separate SFZ voices. So, you hit the voice limit, despite the fact that these are very low CPU-usage. Or, should be. Yet my Pi5’s fan is on, and usually it’s not …
It’d be great to see total CPU usage and CPU temperature on the mixer screen, but CPU usage per chain would be amazing. I don’t think I"ll hold my breath on that, though. It’s nontrivial, since all plugins are running in a single Linux process.
