New Raspberry PI 4
BTW, why not sending some basic telemetry data back, so you guys can track the use of peripherals…? And, doesn’t Zynthian have a channel on discord?
We’ve got an irc! Well, I’m in the irc…
Network/Channel?
#zynthian on freenode
Search result
Swapped the 23008 for a 23017, so the protype-kees can be removed.
I’ve just replaced my failing laptop with an 8g Pi4 in this case…
It runs Pycharm :smiley:
The access to the i/o port is particularly nice…
got a 32G SSD but that is being replaced soon.
I look at him for the third day… :face_with_hand_over_mouth:
Curious case. ABS base, aluminum top cover. I like the solution to move all the connectors to the backside. :+1:
It’s not obvious but the i/o exposed under a panel held on with magnets. What not to like?
:open_mouth:
No way…
Ok. It’s now got A 256g SSD Card. That’s 6 G bigger than the laptop it’s replaced.
Make sure you have a USB Mouse & Keyboard when you start it up. You can’t turn on Bluetooth till you’ve started up and you need a keyboard to set your new password.
The Gallium’s melted :smiley:
It only needs 30 degrees Celsius or - 351.67 degrees for our American friends or Daily Mail readers.
