OB-Xd with all the effects! Vember Surge confirmed! Multitrack recorder!
Twin HDMI?
Theyāve swapped Ethernet & USB !
Has anyone seen my hacksaw�
What a powerful little engineā¦
@wyleu
Why are you still here? Drive to Cambridge and buy the hole stock.
Heās posting from his car dashboard zynthian you know. http://www.speacock.net/albums/2008-Maker-Faire/08_May_Maker_Faire_50_piano_car.jpg
Many have indeed asked. . .
Course some of us now have the new playable webconf . . .
I topped and tailed it, hence the missing 8 seconds . . . ![]()
Record Functionality, ogg download and Status echo and if we did top and tailing we could dump the Audacity step and operate entirely remotely of a zynth being played by someone else like, Richard my ghastly son, you can play the piece far better than I can. . . .
your wife and kids?
I just ordered a 4GB version
They have my true worth displayed on a two line display on a raspberry pi in the kitchen. . . .
Itās somewhere between the piano and the playstation .
I thought it said āGot milk?ā
Thatās approximately my value.
But at least lactose freeā¦
Donāt let them get the idea of a cowā¦
The standard reply to any of the frequent discussions of my own demise is,
āAt least weāll get a cat . . .ā
And they almost donāt live here anymore
Iām sure I will buy one reasonably soon. Fair bit of rejigging to encompass it in various cases. How far back are we going to support, Do I get my audio headless zeroās yet ?
Wow! I had given up on a new RPi anytime soon due to them categorically stating it would not appear before next year. I have just been told by the boss that we need a vacuum cleaner before a new Pi. That might not stop me though! And I was actually tempted to drive to Cambridge (which is closer to me than @wyleu but I should really get on with my day job (and installing running water back in my home). I guess we start to look at what a Zynthian Pi 4 looks like as soon as we have one in our grubby little hands but it may take a while before it becomes the standard. (At least a few weeksā¦). I am excited!
Oh! And maybe Pianoteq will play without x-runs⦠well there is always hope!
Me too, at the exact time they opened sales
It was supposed to be delivered today, but itās a local holiday, so it will be delivered tomorrow.
(it will replace the main board in my āVideoRecorderāoāDeathā)
POE is looking interesting. . .
https://www.msdist.co.uk/ubiquiti/poe/50v-1200ma-gigabit-poe-injector#Product-Specifications
PoE was available even in RPi3, with the same hat youāll need on the 4: https://www.raspberrypi.org/products/poe-hat/
And beware: the hat WILL require an 802.3af compliant power source, and the Ubiquiti PoE Injector is not one.
Yes, I knew it was on the 3. The fact that theyāve not moved the connector means they see it as an important mechanical interface going forward ( More important than the actual Ethernet connector :-D.Certainly, from a little reading itās all fairly non compatible at the moment. Hense the existance of pointless devices like this ā¦
https://www.broadbandbuyer.com/products/16618-ubiquiti-ins-8023af-i/
But I like it for stage use. Getās rid of cables and stage wall warts. Got to be a good thing.
Anyone think of any easy way of getting 60 or so volts in the middle of a field
Presumably with the specific new power supply, (probably a recommendation for Pi 4 zynthian power supply) we can assume itās upped it overall power consumption even if it does promise to shunt a fair bit of current down parasitic USBās
and donāt forget the edge connector hell of the POE HAT ā¦
A breezeā¦
Thatās got to be worth a musical forfeit
ā¦
Itās like the world cup round hereā¦
We are getting VERY strict.
ā¦those stupid budget constraints⦠
But I know the problem wery well. Once, I had to build a ligthing system for my wife theater group, 'cause they had to do a show in the middle of nowhere. I used two UPS batteries, 12V LED lights everywhere, and a customized inverter to power the amplifier at the needed voltage without too many conversions and efficiency loss.
And Iāve been able to make a system fully contained in a suitcase.
Well, probably if they had traveled by plane they would have been arrested immediately, seeing the appearance of the object, but ⦠
And BTW: I reused the āboxā with a 3A 12->5V converter, and it kept a RPi powered for almost 3 days (I was tracking a random RF signal)
Very impressiveā¦!! I did a MIDI controlled lighting controller that ran off 28 Volts AC bent out of a 240 Volt unit to power early halogen bulbs⦠Saved lots of local transformers ⦠
We donāt like mains power do weā¦?
But, I didnāt get my sound sample ⦠
I could send the Cameroonians round ā¦
