Just tried 2019-05-17: There seems to be a bigger problem with MIDI drops. Note-On/Note-Offs are ignored most of the time. Not playable at all.
Regards, Holger
Regards, Holger
What is the trigger? MIDI input? USB MIDI inputs? Is it the same when playing a .mid recordings?
Ahhh, ok - only the DIN-MIDI-Input is broken! USB-MIDI-IN works.
No problem with MIDI IN (5pin DIN or USB) on zynth-nord.local
my most energetic MIDI musings and sub sub Emerson impersonations don’t seem to fool it.
Elsewhere things are a little more confused …
I’m partially looking at you Motor61 USB . . . ( actually I haven’t tried it with the 12Mbyte limit…) and definately looking at you MIDI IN on zynthian-amp2.
thanks, i can wait until next week to install the new sdimage! zynthian often turns off when I change the sound, and I also crack all sounds (CPU problem?)
look forward to having a zynthian who is ok and share my impressions with you!
Glad to hear your desire…
Hold on a minute …
I just install 05-17 release, add pianoteq 6.5.
First, I activate wifi hotspot, my computer don’t see the wifi, same after rebooting my zynthian.
I try pianoteq 6.5 and it makes xrun, I take 6.4.1 no Xrun, if other people have the same problem, maybe add a text on webconf that pianoteq 6.5 is not stable on zynthian for moment
Apropos of nothing you do realise that will be #500 on Jenkins ?
