New testing image Bookworm Oram 64bits
I just rebooted my V5 & V3 from the admin menu and then from webconf and both worked fine. Be aware that reboot depends on the supervisor script running and detecting the exit status of the UI code. If you have started Zynthian manually from the command line it may not be in the right configuration to detect this and if Zynthian experiences an error during reboot it may give a different exit code which can block reboot. Check the logs.
After last update from 2024-03-01 oram, webconf on the address http://zynthian.local/ don’t work. On the IP address webconf is working.
zyncoder: oram (84612a6)
zynthian-ui: oram (901df2c)
zynthian-sys: oram (de001cc)
zynthian-data: oram (db0355a)
zynthian-webconf: oram (8fd2665)
This is associated with warnings in the log:
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 1#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 1#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 2#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 2#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 3#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 3#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 4#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 4#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 5#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 5#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 6#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 6#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 7#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 7#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 8#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 8#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 9#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 9#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 10#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 10#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 11#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 11#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 12#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 12#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 13#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 13#FluidSynth: 'legato on/off'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 14#FluidSynth: 'modulation'
May 07 15:54:35 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 14#FluidSynth: 'legato on/off'
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 15#FluidSynth: 'modulation'
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 15#FluidSynth: 'legato on/off'
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 16#FluidSynth: 'modulation'
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor 16#FluidSynth: 'legato on/off'
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 1 => modulation
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_state_manager.load_zs3: Failed to restore MIDI learning 68 => legato on/off
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor Audio Levels: 'Headphones'
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor Audio Levels: 'Digital_0'
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor Audio Levels: 'Digital_1'
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor Audio Levels: 'ADC_0'
May 07 15:54:36 zynthian-v5-64 startx[1870]: WARNING:zynthian_processor.set_state: Invalid Controller for processor Audio Levels: 'ADC_1'
May 07 15:55:04 zynthian-v5-64 startx[1870]: WARNING:zynthian_gui.busy_thread_task: Clients have been busy for longer than 30s: {'load snapshot'}
@ToFF is this on wired or wifi? There was a change to wifi that may have altered behaviour but I didn’t think it would impact wired network.
I have always found mdns to be rather tempremental with poor inter-OS compatibility. I particularly find Windows to support it poorly.
Now I switch off wifi on zynthian. I like have all music equipment hard wired. Yes, I’m in Windows and have the “DNS_PROBE_FINISHED_NXDOMAIN” issue with http://zynthian.local/. I’ll try to restart the PC and boot into linux.
EDIT: under Linux the same issue.
just tested zynthian.local and have the same error
also it happens to me: not possible to zynthian.local and zynthian.lan for webconf
with IP is possible
It seems disabling Avahi was a bad decission. I will enable it and upload a new image ASAP.
If you manage to access by IP, you can re-enable it by running this command:
systemctl enable avahi-daemon
reboot
It was kind of nice to realise this problem wasn’t my current playing around with dns as I have been recently…
Hi @zynthianers!
I released a new SD image that include all recent changes in Oram:
https://os.zynthian.org/test/2024-05-22-zynthianos-bookworm-aarch64-oram-2405.zip
If you are using a recent image, you can simply update and you will get all the important stuff, except the upgraded Salamander Grand Piano SFZ and some minor system adjustments.
We are really close to have the next stable release, so please, keep sending feedback! With your help Zynthian Oram is going to be a great great release!!
What’s the status of Pi5 with the OS? I’m waiting patiently for the v5 kit upgrade but I have all the parts lying around for a frankenzynth, if the 5 is on point yet. :>
Pi5 is working OK. At less in my prototypes.
in my FrankenZynth, Zynthian Oram mk.2405 works perfectly! :slight_smile:
Thank you @jofemodo, this is a really thrilling prospect! :star:
@Jofemodo I did a fresh installing but where can I find the upgraded Salamander Grand Piano SFZ?
Use the linuxsampler engine and look into the Pianos bank.
I forgot to say that the new image is configured by default at 48KHz.
in Piano bank I see
under System GIG > Pianos: 7 Maestro Concert grand pianos
under System SFZ> Pianos: no acoustic pianos
starting from ORAM 2405:
zynthian-ui: oram (0247724)
zynthian-sys: oram (7a6c26f)
zynthian-webconf: oram (5f6f937)
Is it crazy to expect Pianoteq at 96KHz with RPi5?
You need the new image, mate.
