Hi @jofemodo,
can you please look at Chain control and interaction with /CUIA/ZYNPOT ? After update I have not reaction. From the touch screen the parameters are changing. From the Open Stage Control over /CUIA/ZYNPOT not. I have also zynthian without physical knobs. In mixer screen the /CUIA/ZYNPOT are working.
Send the logs, please.
Sep 14 16:00:25 zynthian startx[892]: TypeError: zynthian_state_manager.start_midi_playback() missing 1 required positional argument: 'fpath'
Sep 14 16:00:51 zynthian startx[892]: Traceback (most recent call last):
Sep 14 16:00:51 zynthian startx[892]: File "src/liblo.pyx", line 56, in liblo._weakref_method.__call__
Sep 14 16:00:51 zynthian startx[892]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 383, in osc_cb_all
Sep 14 16:00:51 zynthian startx[892]: self.state_manager.zynmixer.enable_dpm(chan, True)
Sep 14 16:00:51 zynthian startx[892]: TypeError: zynmixer.enable_dpm() missing 1 required positional argument: 'enable'
Sep 14 16:00:51 zynthian startx[892]: Exception ignored in: 'liblo._msg_callback'
Sep 14 16:01:16 zynthian startx[892]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:01:20 zynthian startx[892]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:01:20 zynthian startx[892]: ZynCore->setup_step_zynpot(1): Invalid index!
Sep 14 16:01:20 zynthian startx[892]: ZynCore->setup_step_zynpot(2): Invalid index!
Sep 14 16:01:20 zynthian startx[892]: ZynCore->setup_step_zynpot(3): Invalid index!
Sep 14 16:01:22 zynthian startx[892]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:01:22 zynthian startx[892]: ZynCore->setup_step_zynpot(1): Invalid index!
Sep 14 16:01:22 zynthian startx[892]: ZynCore->setup_step_zynpot(2): Invalid index!
Sep 14 16:01:22 zynthian startx[892]: ZynCore->setup_step_zynpot(3): Invalid index!
Sep 14 16:01:23 zynthian startx[892]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:01:23 zynthian startx[892]: ZynCore->setup_step_zynpot(1): Invalid index!
Sep 14 16:01:23 zynthian startx[892]: ZynCore->setup_step_zynpot(2): Invalid index!
Sep 14 16:01:37 zynthian startx[892]: ERROR:zynthian_gui.cuia_zynpot: zynpot requires 2 parameters: index, delta, not {params}
Sep 14 16:01:51 zynthian startx[892]: Traceback (most recent call last):
Sep 14 16:01:51 zynthian startx[892]: File "src/liblo.pyx", line 56, in liblo._weakref_method.__call__
Sep 14 16:01:51 zynthian startx[892]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 383, in osc_cb_all
Sep 14 16:01:51 zynthian startx[892]: self.state_manager.zynmixer.enable_dpm(chan, True)
Sep 14 16:01:51 zynthian startx[892]: TypeError: zynmixer.enable_dpm() missing 1 required positional argument: 'enable'
Sep 14 16:01:51 zynthian startx[892]: Exception ignored in: 'liblo._msg_callback'
SOFTWARE
zyncoder: oram (7737730)
zynthian-ui: oram (de1b7b3)
zynthian-sys: oram (9eba008)
zynthian-data: oram (6fa0db4)
zynthian-webconf: oram (346b77e)
And in debug mode:
Restarting UI in debug mode
Sep 14 16:06:53 zynthian systemd[1]: Started zynthian_debug.service - Zynthian User Interface (DEBUG).
Sep 14 16:06:53 zynthian startx[1351]: X.Org X Server 1.21.1.7
Sep 14 16:06:53 zynthian startx[1351]: X Protocol Version 11, Revision 0
Sep 14 16:06:53 zynthian startx[1351]: Current Operating System: Linux zynthian 6.6.50-v8+ #1795 SMP PREEMPT Tue Sep 10 19:39:34 BST 2024 aarch64
Sep 14 16:06:53 zynthian startx[1351]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1024 bcm2708_fb.fbheight=600 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:A7:D1:CE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=/dev/mmcblk0p2 rootfstype=ext4 fsck.repair=yes rootwait console=tty3 logo.nologo quiet loglevel=2 vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Sep 14 16:06:53 zynthian startx[1351]: xorg-server 2:21.1.7-3+rpt3+deb12u7 (https://www.debian.org/support)
Sep 14 16:06:53 zynthian startx[1351]: Current version of pixman: 0.42.2
Sep 14 16:06:53 zynthian startx[1351]: Before reporting problems, check http://wiki.x.org
Sep 14 16:06:53 zynthian startx[1351]: to make sure that you have the latest version.
Sep 14 16:06:53 zynthian startx[1351]: Markers: (--) probed, (**) from config file, (==) default setting,
Sep 14 16:06:53 zynthian startx[1351]: (++) from command line, (!!) notice, (II) informational,
Sep 14 16:06:53 zynthian startx[1351]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Sep 14 16:06:53 zynthian startx[1351]: (==) Log file: "/var/log/Xorg.0.log", Time: Sat Sep 14 16:06:53 2024
Sep 14 16:06:53 zynthian startx[1351]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Sep 14 16:06:53 zynthian startx[1351]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Sep 14 16:06:53 zynthian startx[1357]: ----------------------------------------------
Sep 14 16:06:53 zynthian startx[1357]: Linux Version: bookworm
Sep 14 16:06:53 zynthian startx[1357]: Kernel Version: 6.6.50-v8+
Sep 14 16:06:53 zynthian startx[1357]: ZynthianOS Version: 2403
Sep 14 16:06:53 zynthian startx[1357]: Virtualization: none
Sep 14 16:06:53 zynthian startx[1357]: Hardware Architecture: aarch64
Sep 14 16:06:53 zynthian startx[1357]: Hardware Model: Raspberry Pi 400 Rev 1.1
Sep 14 16:06:53 zynthian startx[1386]: /zynthian/config/img/fb_zynthian_boot.png is 1024x600 PNG image, color type GRAY, 8 bit
Sep 14 16:06:53 zynthian startx[1386]: Zooming image by 100%...done
Sep 14 16:06:53 zynthian startx[1386]: Merging...didn't find evidence of prior run.
Sep 14 16:06:53 zynthian startx[1386]: done
Sep 14 16:06:53 zynthian startx[1386]: Building XImage...done
Sep 14 16:06:53 zynthian startx[1387]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Sep 14 16:06:53 zynthian startx[1387]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Sep 14 16:06:54 zynthian startx[1387]: ZynCore: Configured 4 x Logical Zynswitches...
Sep 14 16:06:54 zynthian startx[1387]: ZynCore: Setting-up 0 x Physical Zynswitches...
Sep 14 16:06:54 zynthian startx[1387]: ZynCore: Setting-up 0 x Zynpots (zyncoders)...
Sep 14 16:06:55 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Sep 14 16:06:55 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Sep 14 16:06:55 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Sep 14 16:06:55 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Sep 14 16:06:55 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Sep 14 16:06:55 zynthian startx[1387]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1726326300.2547631
Sep 14 16:06:56 zynthian startx[1387]: Started libzynaudioplayer using libsndfile-1.2.0
Sep 14 16:06:56 zynthian startx[1387]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_main.<module>: STARTING ZYNTHIAN-UI ...
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_state_manager.__init__: Creating state manager
Sep 14 16:06:57 zynthian startx[1387]: Started libzynmixer
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_chain_manager.__init__: Creating chain manager
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_engine_alsa_mixer.get_controllers_dict: MIXER CTRL LIST: ['Digital_0', 'Digital_1']
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_engine_alsa_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: Output 1 Level (Digital_0) => 100
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_engine_alsa_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: Output 2 Level (Digital_1) => 100
Sep 14 16:06:57 zynthian startx[1387]: Started libzynseq
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_engine_alsa_mixer._send_controller_value: set 'Digital' 'Playback' 100%,100% unmute
Sep 14 16:06:57 zynthian startx[1387]: Started libzynsmf
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_state_manager.start: Opened temperature sensor '/sys/class/hwmon/hwmon0/temp1_input'
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_state_manager.start: Opened undervoltage sensor '/sys/class/hwmon/hwmon1/in0_lcrit_alarm'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_autoconnect.init: Initializing 24 slots for MIDI devices
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2' for devices with ID 'APC Key 25 mk2 MIDI 2'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2' for devices with ID 'APC Key 25 mk2 IN 2'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_midimix' for devices with ID 'MIDI Mix IN 1'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_mpk_mini_mk3' for devices with ID 'MPK mini 3 IN 1'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_duopiano' for devices with ID 'GENERAL IN 1'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_korg_nanokontrol2' for devices with ID 'nanoKONTROL2 IN 1'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchkey_mini_mk3' for devices with ID 'Launchkey Mini MK3 IN 2'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_mini' for devices with ID 'Launchpad Mini IN 1'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_mini_mk3' for devices with ID 'Launchpad Mini MK3 IN 1'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_pro_mk2' for devices with ID 'Launchpad Pro IN 1'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_pro_mk3' for devices with ID 'Launchpad Pro MK3 IN 1'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_x' for devices with ID 'Launchpad X IN 1'
Sep 14 16:06:57 zynthian startx[1387]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_riband' for devices with ID 'riband Bluetooth'
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 0: system:midi_capture_1
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 1: ttymidi:MIDI_in
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 2: jackrtpmidid:rtpmidi_out
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 3: ZynMaster:midi_out
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 0: system:midi_playback_1
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 1: ttymidi:MIDI_out
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 2: jackrtpmidid:rtpmidi_in
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 3: ZynMaster:midi_in
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Sep 14 16:06:57 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Sep 14 16:06:58 zynthian startx[1387]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 0 => midi_chan=None, mixer_chan=16, zmop_index=None
Sep 14 16:06:58 zynthian startx[1387]: DEBUG:selector_events.__init__: Using selector: EpollSelector
Sep 14 16:06:59 zynthian startx[1387]: INFO:zynthian_gui_patterneditor.get_custom_keymap: MIDI channel 0 has not synth processors.
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_gui_brightness_config.get_backlight_sysctrl_fpath: Can't find a display brightness control file
Sep 14 16:06:59 zynthian startx[1387]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:06:59 zynthian startx[1387]: ZynCore->setup_step_zynpot(1): Invalid index!
Sep 14 16:06:59 zynthian startx[1387]: ZynCore->setup_step_zynpot(2): Invalid index!
Sep 14 16:06:59 zynthian startx[1387]: ZynCore->setup_step_zynpot(3): Invalid index!
Sep 14 16:06:59 zynthian startx[1387]: INFO:zynthian_gui.zynswitches_init: INIT 4 ZYNSWITCHES ...
Sep 14 16:06:59 zynthian startx[1387]: INFO:zynthian_gui.zynswitches_midi_setup: CUSTOM I/O SETUP...
Sep 14 16:06:59 zynthian startx[1387]: INFO:zynthian_gui.osc_init: ZYNTHIAN-UI OSC server running in port 1370
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_gui.prune_screen_history: SCREEN HISTORY => []
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_gui.prune_screen_history: PRUNE 'loading' FROM SCREEN HISTORY => []
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_gui.close_screen: CLOSE SCREEN 'loading' => Back to 'audio_mixer'
Sep 14 16:06:59 zynthian startx[1387]: INFO:zynthian_state_manager.load_snapshot: Loading snapshot '/zynthian/zynthian-my-data/snapshots/last_state.zss' ...
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 1 => midi_chan=0, mixer_chan=0, zmop_index=0
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'JV/Fluid Drums' with ID '1'
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_engine_jalv.__init__: CREATING JALV ENGINE => Fluid_Drums-01
Sep 14 16:06:59 zynthian startx[1387]: INFO:zynthian_engine.start: Starting Engine Jalv/Fluid Drums
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_engine.start: Command: jalv -n Fluid_Drums-01 http://kxstudio.linuxaudio.org/plugins/FluidPlug_FluidDrums
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_gui.prune_screen_history: PRUNE 'audio_mixer' FROM SCREEN HISTORY => []
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_engine_jalv.__init__: Jack Name => Fluid_Drums-01
Sep 14 16:06:59 zynthian startx[1387]: INFO:zynthian_engine_jalv.__init__: Using default MIDI controllers for 'Fluid Drums'.
Sep 14 16:06:59 zynthian startx[1387]: INFO:zynthian_engine_jalv.get_lv2_controllers_dict: Getting Controller List from LV2 Plugin ...
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 2 => midi_chan=1, mixer_chan=1, zmop_index=1
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'JV/MiMi-d' with ID '2'
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_engine_jalv.__init__: CREATING JALV ENGINE => MiMi-d-01
Sep 14 16:06:59 zynthian startx[1387]: INFO:zynthian_engine.start: Starting Engine Jalv/MiMi-d
Sep 14 16:06:59 zynthian startx[1387]: DEBUG:zynthian_engine.start: Command: jalv -n MiMi-d-01 https://butoba.net/homepage/mimid.html
Sep 14 16:07:00 zynthian startx[1387]: DEBUG:zynthian_engine_jalv.__init__: Jack Name => MiMi-d-01
Sep 14 16:07:00 zynthian startx[1387]: INFO:zynthian_engine_jalv.__init__: Using default MIDI controllers for 'MiMi-d'.
Sep 14 16:07:00 zynthian startx[1387]: INFO:zynthian_engine_jalv.get_lv2_controllers_dict: Getting Controller List from LV2 Plugin ...
Sep 14 16:07:00 zynthian startx[1387]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 3 => midi_chan=2, mixer_chan=2, zmop_index=2
Sep 14 16:07:00 zynthian startx[1387]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'JV/Dexed' with ID '3'
Sep 14 16:07:00 zynthian startx[1387]: DEBUG:zynthian_engine_jalv.__init__: CREATING JALV ENGINE => Dexed-01
Sep 14 16:07:00 zynthian startx[1387]: INFO:zynthian_engine.start: Starting Engine Jalv/Dexed
Sep 14 16:07:00 zynthian startx[1387]: DEBUG:zynthian_engine.start: Command: jalv -n Dexed-01 https://github.com/dcoredump/dexed.lv2
Sep 14 16:07:01 zynthian startx[1387]: DEBUG:zynthian_engine_jalv.__init__: Jack Name => Dexed-01
Sep 14 16:07:01 zynthian startx[1387]: INFO:zynthian_engine_jalv.get_lv2_controllers_dict: Getting Controller List from LV2 Plugin ...
Sep 14 16:07:01 zynthian startx[1387]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 4 => midi_chan=3, mixer_chan=3, zmop_index=3
Sep 14 16:07:01 zynthian startx[1387]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'ZY' with ID '4'
Sep 14 16:07:01 zynthian startx[1387]: INFO:zynthian_engine.osc_init: OSC target in port 6693
Sep 14 16:07:01 zynthian startx[1387]: INFO:zynthian_engine.osc_init: OSC server running in port 14214
Sep 14 16:07:01 zynthian startx[1387]: INFO:zynthian_engine.start: Starting Engine ZynAddSubFX
Sep 14 16:07:01 zynthian startx[1387]: DEBUG:zynthian_engine.start: Command: zynaddsubfx -r 48000 -b 128 -O jack-multi -I jack -P 6693 -a -U
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER panning OSC PATH => /part0/Ppanning
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER voice limit OSC PATH => /part0/Pvoicelimit
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER drum mode OSC PATH => /part0/Pdrummode
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER assign mode OSC PATH => /part0/polyType
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER portamento enable OSC PATH => /part0/ctl/portamento.portamento
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER portamento auto OSC PATH => /part0/ctl/portamento.automode
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER portamento receive OSC PATH => /part0/ctl/portamento.receive
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER portamento time OSC PATH => /part0/ctl/portamento.time
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER portamento up/down OSC PATH => /part0/ctl/portamento.updowntimestretch
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER threshold type OSC PATH => /part0/ctl/portamento.pitchthreshtype
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER threshold OSC PATH => /part0/ctl/portamento.pitchthresh
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER portaprop on/off OSC PATH => /part0/ctl/portamento.proportional
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER portaprop rate OSC PATH => /part0/ctl/portamento.propRate
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER portaprop depth OSC PATH => /part0/ctl/portamento.propDepth
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER modwheel depth OSC PATH => /part0/ctl/modwheel.depth
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER modwheel exp OSC PATH => /part0/ctl/modwheel.exponential
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER bendrange OSC PATH => /part0/ctl/pitchwheel.bendrange
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER bendrange split OSC PATH => /part0/ctl/pitchwheel.is_split
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER bendrange down OSC PATH => /part0/ctl/pitchwheel.bendrange_down
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER rescenter depth OSC PATH => /part0/ctl/resonancecenter.depth
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER resbw depth OSC PATH => /part0/ctl/resonancebandwidth.depth
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER bandwidth depth OSC PATH => /part0/ctl/bandwidth.depth
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER bandwidth exp OSC PATH => /part0/ctl/bandwidth.exponential
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER panning depth OSC PATH => /part0/ctl/panning.depth
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER filter.cutoff depth OSC PATH => /part0/ctl/filtercutoff.depth
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER filter.Q depth OSC PATH => /part0/ctl/filterq.depth
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER velocity sens. OSC PATH => /part0/Pvelsns
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine.get_controllers_dict: CONTROLLER velocity offs. OSC PATH => /part0/Pveloffs
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_engine_zynaddsubfx.add_processor: ADD processor => Part 0 (zynaddsubfx)
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.get_bank_list: Loaded 1 banks
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.load_preset_list: Loaded 1 presets
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.set_preset: Preset selected: Default (0)
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.load_preset_list: Loaded 52 presets
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.set_preset: Preset selected: Push Me (35)
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.get_bank_list: Loaded 52 banks
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.load_preset_list: Loaded 31 presets
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.set_preset: Preset selected: TRUMPET 7 (27)
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.get_bank_list: Loaded 35 banks
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_zcmidi.set_midi_bank_msb: Set MIDI CH 3, Bank MSB: None
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_engine_zynaddsubfx._get_preset_list: Getting Preset List for Pads
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.load_preset_list: Loaded 16 presets
Sep 14 16:07:02 zynthian startx[1387]: INFO:zynthian_processor.set_preset: Preset selected: Synth Pad 2 (9)
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Sep 14 16:07:02 zynthian startx[1387]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Sep 14 16:07:03 zynthian startx[1387]: INFO:zynseq.restore_riff_data: Restoring RIFF data...
Sep 14 16:07:03 zynthian startx[1387]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:07:03 zynthian startx[1387]: ZynCore->setup_step_zynpot(1): Invalid index!
Sep 14 16:07:03 zynthian startx[1387]: ZynCore->setup_step_zynpot(2): Invalid index!
Sep 14 16:07:03 zynthian startx[1387]: ZynCore->setup_step_zynpot(3): Invalid index!
Sep 14 16:07:14 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNSWITCH' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:07:14 zynthian startx[1387]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 3
Sep 14 16:07:14 zynthian startx[1387]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN MIDI Controllers
Sep 14 16:07:14 zynthian startx[1387]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:07:16 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ARROW_DOWN' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:07:16 zynthian startx[1387]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'arrow_down' => [1.0]
Sep 14 16:07:16 zynthian startx[1387]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN General#1
Sep 14 16:07:16 zynthian startx[1387]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:07:16 zynthian startx[1387]: ZynCore->setup_step_zynpot(1): Invalid index!
Sep 14 16:07:16 zynthian startx[1387]: ZynCore->setup_step_zynpot(2): Invalid index!
Sep 14 16:07:16 zynthian startx[1387]: ZynCore->setup_step_zynpot(3): Invalid index!
Sep 14 16:07:16 zynthian startx[1387]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN General#2
Sep 14 16:07:17 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ARROW_DOWN' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:07:17 zynthian startx[1387]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'arrow_down' => [1.0]
Sep 14 16:07:17 zynthian startx[1387]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN General#3
Sep 14 16:07:17 zynthian startx[1387]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:07:17 zynthian startx[1387]: ZynCore->setup_step_zynpot(1): Invalid index!
Sep 14 16:07:17 zynthian startx[1387]: ZynCore->setup_step_zynpot(2): Invalid index!
Sep 14 16:07:25 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:07:25 zynthian startx[1387]: ERROR:zynthian_gui.cuia_zynpot: zynpot requires 2 parameters: index, delta, not {params}
Sep 14 16:07:26 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:07:26 zynthian startx[1387]: ERROR:zynthian_gui.cuia_zynpot: zynpot requires 2 parameters: index, delta, not {params}
Sep 14 16:07:27 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:07:27 zynthian startx[1387]: ERROR:zynthian_gui.cuia_zynpot: zynpot requires 2 parameters: index, delta, not {params}
Sep 14 16:07:29 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:07:29 zynthian startx[1387]: ERROR:zynthian_gui.cuia_zynpot: zynpot requires 2 parameters: index, delta, not {params}
Sep 14 16:07:30 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:07:30 zynthian startx[1387]: ERROR:zynthian_gui.cuia_zynpot: zynpot requires 2 parameters: index, delta, not {params}
Are you running plain Oram branch in all repositories?
Yes,
Repositories
Stable zynthian-ui
oram
zynthian-webconf
oram
zynthian-sys
oram
zynthian-data
oram
zyncoder
oram
maybe I should try the last image of oram, I havenât changed the sd card in a long time.
It looks like your open stage control is not sending the needed parameters for CUIA ZYNPOT.
No. Your zynthiam-ui repo is using stable?
In mixer screen the zynthian have not problem with OSC command (which is same as in Control UI)
(DEBUG, OSC) Out: {
address: â/CUIA/ZYNPOTâ,
args: [ { type: âiâ, value: 3 }, { type: âfâ, value: -1 } ]
} To: 192.168.88.102:1370
see on log
Sep 14 16:35:51 zynthian startx[1387]: File "src/liblo.pyx", line 56, in liblo._weakref_method.__call__
Sep 14 16:35:51 zynthian startx[1387]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 383, in osc_cb_all
Sep 14 16:35:51 zynthian startx[1387]: self.state_manager.zynmixer.enable_dpm(chan, True)
Sep 14 16:35:51 zynthian startx[1387]: TypeError: zynmixer.enable_dpm() missing 1 required positional argument: 'enable'
Sep 14 16:35:51 zynthian startx[1387]: Exception ignored in: 'liblo._msg_callback'
Sep 14 16:35:51 zynthian startx[1387]: Traceback (most recent call last):
Sep 14 16:36:18 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNSWITCH' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:36:18 zynthian startx[1387]: DEBUG:zynthian_gui.zynswitch_short: Short Switch 3
Sep 14 16:36:18 zynthian startx[1387]: DEBUG:zynthian_gui_control.set_controller_screen: SET CONTROLLER SCREEN MIDI Controllers
Sep 14 16:36:18 zynthian startx[1387]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:36:18 zynthian startx[1387]: ZynCore->setup_step_zynpot(1): Invalid index!
Sep 14 16:36:30 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/SCREEN_AUDIO_MIXER' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:36:30 zynthian startx[1387]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'screen_audio_mixer' => [1.0]
Sep 14 16:36:30 zynthian startx[1387]: ZynCore->setup_step_zynpot(0): Invalid index!
Sep 14 16:36:30 zynthian startx[1387]: ZynCore->setup_step_zynpot(1): Invalid index!
Sep 14 16:36:30 zynthian startx[1387]: ZynCore->setup_step_zynpot(2): Invalid index!
Sep 14 16:36:30 zynthian startx[1387]: ZynCore->setup_step_zynpot(3): Invalid index!
Sep 14 16:36:30 zynthian startx[1387]: DEBUG:zynthian_gui.prune_screen_history: SCREEN HISTORY => ['control']
Sep 14 16:36:30 zynthian startx[1387]: DEBUG:zynthian_gui.prune_screen_history: PRUNE 'audio_mixer' FROM SCREEN HISTORY => ['control']
Sep 14 16:36:41 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:36:46 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:36:48 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:36:51 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/mixer/heartbeat' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:36:51 zynthian startx[1387]: Traceback (most recent call last):
Sep 14 16:36:51 zynthian startx[1387]: File "src/liblo.pyx", line 56, in liblo._weakref_method.__call__
Sep 14 16:36:51 zynthian startx[1387]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 383, in osc_cb_all
Sep 14 16:36:51 zynthian startx[1387]: self.state_manager.zynmixer.enable_dpm(chan, True)
Sep 14 16:36:51 zynthian startx[1387]: TypeError: zynmixer.enable_dpm() missing 1 required positional argument: 'enable'
Sep 14 16:36:51 zynthian startx[1387]: Exception ignored in: 'liblo._msg_callback'
Sep 14 16:36:51 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:36:52 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:36:55 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:36:56 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
Sep 14 16:36:58 zynthian startx[1387]: INFO:zynthian_gui.osc_cb_all: OSC MESSAGE '/CUIA/ZYNPOT' from 'osc.udp://192.168.88.107:1370/'
I try new fresh installation of oram
And repositories are:
OK. It looks like a bug in the OSC code. I will fix later.
OK! I think itâs fixed. Please, update and test.
New Oram SD-image.:
https://os.zynthian.org/test/2024-09-14-zynthianos-bookworm-aarch64-oram-2409.img.xz
This is Oram RC2 and it has bugfixes only. Those already having RC1 donât need to download/reburn. Updating is enough,
BTW, it doesnât contain the latest updates from tonight, so it will be RC3 for sure ![]()
Perhaps some of you noted the ânosfzâ versions of the latest images RC1 & RC2. These are smaller images with a very reduced collection of sfz. The good is these images are 3GB only and can be burned in a 8GB SD-card.! The bad is obvious, but probably some of you doesnât need the SFZ collection or prefer to load his own.
All the best,
I think thatâs a great solution to the uSD-CARD size issue. Hopefully without much ongoing effort to maintain the multiple versions.
Hi @jofemodo ![]()
I have updated and thoroughly tested yesterday evening. I have recovered the selection function, both in the keypad and touchscreen. So this is reassuring!
However, even with latest nightly updates, I seem to have lost the key-binding connections of my fourth potentiometer on the keypad to the ZYNPOT 3,-1 and ZYNPOT 3,1 actions. They work only in the Main Mixer, but I cannot use them anymore for up-down navigation in all the other pages.
[PS-EDIT: I have checked both the keypad/pots programming and the webconf key-binding association, of three virtual characters with three actions of the fourt potentiometer (decrease, increase, push). They are correct and should work as before, but only the press action functions outside the Main Mixer page. I wonder if something has changed in the way Oram reads the key-binding messages]
Any ideas?..
Please. @Aethermind , always send the UI logs when reporting UI issues.
Ahhh! And update again. Perhaps there are new fixes you donât have
Similar issues here. I just updatedâŚ
zyncoder: oram (79e270a)
zynthian-ui: oram (70763f9)
I have a knob-less zynthian with generic HDMI screen.
Iâm using UI-VNC to get it controlled.
arrow keys on the mixer screen are working, but if I try to add another audio chain, the arrow keys are only working partially. up/down are working, but left right donât (hence I cannot change to reverb for example).
UI-log shows this output, after pressing right arrow key on the VNC browser window (up/down are workin) and then the down arrow key:
Sep 15 10:46:20 zynthiansampler startx[2187]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'arrow_right' => None
Sep 15 10:46:20 zynthiansampler startx[2187]: ERROR:zynthian_gui.cuia_thread_task: CUIA 'arrow_right' failed with params: None
Sep 15 10:46:20 zynthiansampler startx[2187]: Traceback (most recent call last):
Sep 15 10:46:20 zynthiansampler startx[2187]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 2383, in cuia_thread_task
Sep 15 10:46:20 zynthiansampler startx[2187]: self.callable_ui_action(cuia, params)
Sep 15 10:46:20 zynthiansampler startx[2187]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 1025, in callable_ui_action
Sep 15 10:46:20 zynthiansampler startx[2187]: cuia_func(params)
Sep 15 10:46:20 zynthiansampler startx[2187]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui.py", line 1266, in cuia_arrow_right
Sep 15 10:46:20 zynthiansampler startx[2187]: self.get_current_screen_obj().arrow_right()
Sep 15 10:46:20 zynthiansampler startx[2187]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui_engine.py", line 402, in arrow_right
Sep 15 10:46:20 zynthiansampler startx[2187]: self.zynpot_cb(2, 1)
Sep 15 10:46:20 zynthiansampler startx[2187]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui_engine.py", line 447, in zynpot_cb
Sep 15 10:46:20 zynthiansampler startx[2187]: self.zsel2.zynpot_cb(dval)
Sep 15 10:46:20 zynthiansampler startx[2187]: File "/zynthian/zynthian-ui/zyngui/zynthian_gui_controller.py", line 593, in zynpot_cb
Sep 15 10:46:20 zynthiansampler startx[2187]: if self.zyngui.zynpot_pr_state[self.index] > 0:
Sep 15 10:46:20 zynthiansampler startx[2187]: ~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^
Sep 15 10:46:20 zynthiansampler startx[2187]: IndexError: list index out of range
Sep 15 10:46:20 zynthiansampler startx[2187]: DEBUG:zynthian_gui_keybinding.get_key_action: Get keybinding function name for keycode: 114, modifier: 0
Sep 15 10:46:20 zynthiansampler startx[2187]: DEBUG:zynthian_gui_keybinding.get_key_action: Get keybinding function name for keycode: 116, modifier: 0
Sep 15 10:46:23 zynthiansampler startx[2187]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'arrow_down' => None
Same issue with touchOSC (where in some older versions the zynswitch cuia commands havenât worked).
OK! I can solve it
Fixed! Please, update and test.
