4 posts were merged into an existing topic: Offerings, some burnt. .
Will re-update and check later, thanks @jofemodo !
(and will remember to attach UI logs, I guess from webconf
Iām all updated, running a raspi 4 with a touchscreen.
I have zynswitch1 and zynswitch3 mapped to two keys on a numpad (59 and 104) and they havenāt been working since this recent round of updates. Other key bindings seem to work fine.
Here is my UI log:
Restarting UI in debug mode
Sep 15 13:53:40 zynthian systemd[1]: Started zynthian_debug.service - Zynthian User Interface (DEBUG).
Sep 15 13:53:40 zynthian startx[1473]: X.Org X Server 1.21.1.7
Sep 15 13:53:40 zynthian startx[1473]: X Protocol Version 11, Revision 0
Sep 15 13:53:40 zynthian startx[1473]: Current Operating System: Linux zynthian 6.6.47-v8+ #1794 SMP PREEMPT Thu Aug 29 16:29:21 BST 2024 aarch64
Sep 15 13:53:40 zynthian startx[1473]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=D8:3A:DD:A0:9A:D2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=/dev/mmcblk0p2 rootfstype=ext4 fsck.repair=yes rootwait console=tty3 logo.nologo quiet loglevel=2 vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Sep 15 13:53:40 zynthian startx[1473]: xorg-server 2:21.1.7-3+rpt3+deb12u7 (https://www.debian.org/support)
Sep 15 13:53:40 zynthian startx[1473]: Current version of pixman: 0.42.2
Sep 15 13:53:40 zynthian startx[1473]: Before reporting problems, check http://wiki.x.org
Sep 15 13:53:40 zynthian startx[1473]: to make sure that you have the latest version.
Sep 15 13:53:40 zynthian startx[1473]: Markers: (--) probed, (**) from config file, (==) default setting,
Sep 15 13:53:40 zynthian startx[1473]: (++) from command line, (!!) notice, (II) informational,
Sep 15 13:53:40 zynthian startx[1473]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Sep 15 13:53:40 zynthian startx[1473]: (==) Log file: "/var/log/Xorg.0.log", Time: Sun Sep 15 13:53:40 2024
Sep 15 13:53:40 zynthian startx[1473]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Sep 15 13:53:40 zynthian startx[1473]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Sep 15 13:53:40 zynthian startx[1479]: ----------------------------------------------
Sep 15 13:53:40 zynthian startx[1479]: Linux Version: bookworm
Sep 15 13:53:40 zynthian startx[1479]: Kernel Version: 6.6.47-v8+
Sep 15 13:53:40 zynthian startx[1479]: ZynthianOS Version: 2406
Sep 15 13:53:40 zynthian startx[1479]: Virtualization: none
Sep 15 13:53:40 zynthian startx[1479]: Hardware Architecture: aarch64
Sep 15 13:53:40 zynthian startx[1479]: Hardware Model: Raspberry Pi 4 Model B Rev 1.5
Sep 15 13:53:40 zynthian startx[1508]: /zynthian/config/img/fb_zynthian_boot.png is 800x480 PNG image, color type GRAY, 8 bit
Sep 15 13:53:40 zynthian startx[1508]: Zooming image by 100%...done
Sep 15 13:53:40 zynthian startx[1508]: Merging...didn't find evidence of prior run.
Sep 15 13:53:40 zynthian startx[1508]: done
Sep 15 13:53:40 zynthian startx[1508]: Building XImage...done
Sep 15 13:53:40 zynthian startx[1509]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Sep 15 13:53:40 zynthian startx[1509]: INFO:zynthian_gui_config.<module>: No Wiring Layout configured. Only touch interface is available.
Sep 15 13:53:41 zynthian startx[1509]: ZynCore: Configured 4 x Logical Zynswitches...
Sep 15 13:53:41 zynthian startx[1509]: ZynCore->setup_zynswitch(1, 17, ...): Can't request line events from RPI GPIO
Sep 15 13:53:41 zynthian startx[1509]: ZynCore->setup_zynswitch(2, 17, ...): Can't request line events from RPI GPIO
Sep 15 13:53:41 zynthian startx[1509]: ZynCore->setup_zynswitch(3, 17, ...): Can't request line events from RPI GPIO
Sep 15 13:53:41 zynthian startx[1509]: ZynCore: Setting-up 4 x Physical Zynswitches...
Sep 15 13:53:41 zynthian startx[1509]: ZynCore->setup_zyncoder(0, 17, 17): Can't configure zyncoder on a single pin!
Sep 15 13:53:41 zynthian startx[1509]: ZynCore->setup_zyncoder(1, 17, 17): Can't configure zyncoder on a single pin!
Sep 15 13:53:41 zynthian startx[1509]: ZynCore->setup_zyncoder(2, 17, 17): Can't configure zyncoder on a single pin!
Sep 15 13:53:41 zynthian startx[1509]: ZynCore->setup_zyncoder(3, 17, 17): Can't configure zyncoder on a single pin!
Sep 15 13:53:41 zynthian startx[1509]: ZynCore: Setting-up 4 x Zynpots (zyncoders)...
Sep 15 13:53:41 zynthian startx[1509]: ZynCore->gpiod_start_callbacks: Callback thread created successfully
Sep 15 13:53:41 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Sep 15 13:53:41 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Sep 15 13:53:41 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Sep 15 13:53:41 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Sep 15 13:53:41 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Sep 15 13:53:42 zynthian startx[1509]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1726404441.8989384
Sep 15 13:53:43 zynthian startx[1509]: Started libzynaudioplayer using libsndfile-1.2.0
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_main.<module>: STARTING ZYNTHIAN-UI ...
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_state_manager.__init__: Creating state manager
Sep 15 13:53:43 zynthian startx[1509]: Started libzynmixer
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_chain_manager.__init__: Creating chain manager
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_engine_alsa_mixer.get_controllers_dict: MIXER CTRL LIST: ['']
Sep 15 13:53:43 zynthian startx[1509]: Started libzynseq
Sep 15 13:53:43 zynthian startx[1509]: Started libzynsmf
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_state_manager.start: Opened temperature sensor '/sys/class/hwmon/hwmon0/temp1_input'
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_state_manager.start: Opened undervoltage sensor '/sys/class/hwmon/hwmon1/in0_lcrit_alarm'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_autoconnect.init: Initializing 24 slots for MIDI devices
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2' for devices with ID 'APC Key 25 mk2 MIDI 2'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2' for devices with ID 'APC Key 25 mk2 IN 2'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_midimix' for devices with ID 'MIDI Mix IN 1'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_mpk_mini_mk3' for devices with ID 'MPK mini 3 IN 1'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_duopiano' for devices with ID 'GENERAL IN 1'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_korg_nanokontrol2' for devices with ID 'nanoKONTROL2 IN 1'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchkey_mini_mk3' for devices with ID 'Launchkey Mini MK3 IN 2'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_mini' for devices with ID 'Launchpad Mini IN 1'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_mini_mk3' for devices with ID 'Launchpad Mini MK3 IN 1'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_pro_mk2' for devices with ID 'Launchpad Pro IN 1'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_pro_mk3' for devices with ID 'Launchpad Pro MK3 IN 1'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_x' for devices with ID 'Launchpad X IN 1'
Sep 15 13:53:43 zynthian startx[1509]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_riband' for devices with ID 'riband Bluetooth'
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 0: system:midi_capture_1
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 1: system:midi_capture_2
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 2: ttymidi:MIDI_in
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 3: ZynMaster:midi_out
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 0: system:midi_playback_1
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 1: system:midi_playback_2
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 2: ttymidi:MIDI_out
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 3: ZynMaster:midi_in
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Sep 15 13:53:43 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Sep 15 13:53:44 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 0 => midi_chan=None, mixer_chan=16, zmop_index=None
Sep 15 13:53:44 zynthian startx[1509]: DEBUG:selector_events.__init__: Using selector: EpollSelector
Sep 15 13:53:44 zynthian startx[1509]: INFO:zynthian_gui_admin.stop_rbpi_headphones: STOPPING RBPI HEADPHONES
Sep 15 13:53:45 zynthian startx[1509]: INFO:zynthian_gui_patterneditor.get_custom_keymap: MIDI channel 0 has not synth processors.
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_gui_brightness_config.get_backlight_sysctrl_fpath: Display brightness control file: /sys/class/backlight/rpi_backlight/brightness
Sep 15 13:53:45 zynthian startx[1509]: INFO:zynthian_gui_brightness_config.init_ctrls: Setting display brightness to 43.
Sep 15 13:53:45 zynthian startx[1509]: ZynCore->setup_behaviour_zyncoder(0, ...): Invalid index!
Sep 15 13:53:45 zynthian startx[1509]: ZynCore->setup_behaviour_zyncoder(1, ...): Invalid index!
Sep 15 13:53:45 zynthian startx[1509]: ZynCore->setup_behaviour_zyncoder(2, ...): Invalid index!
Sep 15 13:53:45 zynthian startx[1509]: ZynCore->setup_behaviour_zyncoder(3, ...): Invalid index!
Sep 15 13:53:45 zynthian startx[1509]: INFO:zynthian_gui.zynswitches_init: INIT 4 ZYNSWITCHES ...
Sep 15 13:53:45 zynthian startx[1509]: INFO:zynthian_gui.zynswitches_midi_setup: CUSTOM I/O SETUP...
Sep 15 13:53:45 zynthian startx[1509]: INFO:zynthian_gui.osc_init: ZYNTHIAN-UI OSC server running in port 1370
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_gui.prune_screen_history: SCREEN HISTORY => []
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_gui.prune_screen_history: PRUNE 'loading' FROM SCREEN HISTORY => []
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_gui.close_screen: CLOSE SCREEN 'loading' => Back to 'audio_mixer'
Sep 15 13:53:45 zynthian startx[1509]: INFO:zynthian_state_manager.load_snapshot: Loading snapshot '/zynthian/zynthian-my-data/snapshots/last_state.zss' ...
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 2 => midi_chan=1, mixer_chan=1, zmop_index=0
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'JV/MDA ePiano' with ID '2'
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_engine_jalv.__init__: CREATING JALV ENGINE => MDA_ePiano-01
Sep 15 13:53:45 zynthian startx[1509]: INFO:zynthian_engine.start: Starting Engine Jalv/MDA ePiano
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_engine.start: Command: jalv -n MDA_ePiano-01 http://moddevices.com/plugins/mda/EPiano
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_gui.prune_screen_history: PRUNE 'audio_mixer' FROM SCREEN HISTORY => []
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_engine_jalv.__init__: Jack Name => MDA_ePiano-01
Sep 15 13:53:45 zynthian startx[1509]: INFO:zynthian_engine_jalv.get_lv2_controllers_dict: Getting Controller List from LV2 Plugin ...
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 6 => midi_chan=None, mixer_chan=5, zmop_index=None
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'JV/MVerb' with ID '7'
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_engine_jalv.__init__: CREATING JALV ENGINE => MVerb-01
Sep 15 13:53:45 zynthian startx[1509]: INFO:zynthian_engine.start: Starting Engine Jalv/MVerb
Sep 15 13:53:45 zynthian startx[1509]: DEBUG:zynthian_engine.start: Command: jalv -n MVerb-01 http://distrho.sf.net/plugins/MVerb
Sep 15 13:53:46 zynthian startx[1509]: DEBUG:zynthian_engine_jalv.__init__: Jack Name => MVerb-01
Sep 15 13:53:46 zynthian startx[1509]: INFO:zynthian_engine_jalv.get_lv2_controllers_dict: Getting Controller List from LV2 Plugin ...
Sep 15 13:53:46 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 5 => midi_chan=None, mixer_chan=4, zmop_index=None
Sep 15 13:53:46 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'JV/Calf Vintage Delay' with ID '5'
Sep 15 13:53:46 zynthian startx[1509]: DEBUG:zynthian_engine_jalv.__init__: CREATING JALV ENGINE => Calf_Vintage_Delay-01
Sep 15 13:53:46 zynthian startx[1509]: INFO:zynthian_engine.start: Starting Engine Jalv/Calf Vintage Delay
Sep 15 13:53:46 zynthian startx[1509]: DEBUG:zynthian_engine.start: Command: jalv -n Calf_Vintage_Delay-01 http://calf.sourceforge.net/plugins/VintageDelay
Sep 15 13:53:47 zynthian startx[1509]: DEBUG:zynthian_engine_jalv.__init__: Jack Name => Calf_Vintage_Delay-01
Sep 15 13:53:47 zynthian startx[1509]: INFO:zynthian_engine_jalv.get_lv2_controllers_dict: Getting Controller List from LV2 Plugin ...
Sep 15 13:53:47 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 1 => midi_chan=0, mixer_chan=0, zmop_index=1
Sep 15 13:53:47 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'PT' with ID '9'
Sep 15 13:53:47 zynthian startx[1509]: INFO:zynthian_engine_pianoteq.start: Starting Engine Pianoteq
Sep 15 13:53:47 zynthian startx[1509]: DEBUG:zynthian_engine_pianoteq.fix_pianoteq_config: Fixing Audio Setup
Sep 15 13:53:47 zynthian startx[1509]: DEBUG:zynthian_engine_pianoteq.fix_pianoteq_config: Fixing MIDI Setup
Sep 15 13:53:47 zynthian startx[1509]: INFO:zynthian_engine.start: Starting Engine Pianoteq
Sep 15 13:53:47 zynthian startx[1509]: DEBUG:zynthian_engine.start: Command: /zynthian/zynthian-sw/pianoteq/pianoteq --prefs /root/.config/Modartt/Pianoteq.prefs --midimapping zynthian --serve 9001 --headless
Sep 15 13:53:50 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 8 => midi_chan=1, mixer_chan=7, zmop_index=2
Sep 15 13:53:50 zynthian startx[1509]: DEBUG:zynthian_chain_manager.add_processor: Adding processor 'LS' with ID '8'
Sep 15 13:53:50 zynthian startx[1509]: INFO:zynthian_engine.start: Starting Engine LinuxSampler
Sep 15 13:53:50 zynthian startx[1509]: DEBUG:zynthian_engine.start: Command: linuxsampler --lscp-port 6688
Sep 15 13:53:50 zynthian startx[1509]: INFO:zynthian_engine_linuxsampler.lscp_connect: Connecting with LinuxSampler Server...
Sep 15 13:53:50 zynthian startx[1509]: INFO:zynthian_processor.get_bank_list: Loaded 1 banks
Sep 15 13:53:50 zynthian startx[1509]: INFO:zynthian_processor.load_preset_list: Loaded 5 presets
Sep 15 13:53:50 zynthian startx[1509]: INFO:zynthian_processor.set_preset: Preset selected: Default (2)
Sep 15 13:53:50 zynthian startx[1509]: INFO:zynthian_processor.set_preset: Preset selected: Subtle (4)
Sep 15 13:53:50 zynthian startx[1509]: INFO:zynthian_processor.load_preset_list: Loaded 1 presets
Sep 15 13:53:51 zynthian startx[1509]: INFO:zynthian_processor.get_bank_list: Loaded 64 banks
Sep 15 13:53:51 zynthian startx[1509]: INFO:zynthian_processor.load_preset_list: Loaded 21 presets
Sep 15 13:53:51 zynthian startx[1509]: INFO:zynthian_processor.set_preset: Preset selected: Recording 1 (9)
Sep 15 13:53:51 zynthian startx[1509]: INFO:zynthian_processor.get_bank_list: Loaded 14 banks
Sep 15 13:53:51 zynthian startx[1509]: INFO:zynthian_engine_linuxsampler._get_preset_list: Getting Preset List for Pianos
Sep 15 13:53:51 zynthian startx[1509]: INFO:zynthian_processor.load_preset_list: Loaded 9 presets
Sep 15 13:53:51 zynthian startx[1509]: INFO:zynthian_processor.set_preset: Preset selected: Salamander/Grand Piano V3 Retuned (4)
Sep 15 13:53:52 zynthian startx[1509]: INFO:zynthian_processor.get_bank_list: Loaded 1 banks
Sep 15 13:53:52 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Sep 15 13:53:52 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Sep 15 13:53:52 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Sep 15 13:53:52 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Sep 15 13:53:52 zynthian startx[1509]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Sep 15 13:53:52 zynthian startx[1509]: INFO:zynseq.restore_riff_data: Restoring RIFF data...
Sep 15 13:53:52 zynthian startx[1509]: ZynCore->setup_behaviour_zyncoder(0, ...): Invalid index!
Sep 15 13:53:52 zynthian startx[1509]: ZynCore->setup_behaviour_zyncoder(1, ...): Invalid index!
Sep 15 13:53:52 zynthian startx[1509]: ZynCore->setup_behaviour_zyncoder(2, ...): Invalid index!
Sep 15 13:53:52 zynthian startx[1509]: ZynCore->setup_behaviour_zyncoder(3, ...): Invalid index!
Sep 15 13:53:56 zynthian startx[1509]: DEBUG:zynthian_gui_keybinding.get_key_action: Get keybinding function name for keycode: 114, modifier: 0
Sep 15 13:53:56 zynthian startx[1509]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'arrow_right' => None
Sep 15 13:53:57 zynthian startx[1509]: DEBUG:zynthian_gui_keybinding.get_key_action: Get keybinding function name for keycode: 113, modifier: 0
Sep 15 13:53:57 zynthian startx[1509]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'arrow_left' => None
Sep 15 13:53:58 zynthian startx[1509]: DEBUG:zynthian_gui_keybinding.get_key_action: Get keybinding function name for keycode: 116, modifier: 0
Sep 15 13:53:58 zynthian startx[1509]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'arrow_down' => None
Sep 15 13:53:59 zynthian startx[1509]: DEBUG:zynthian_gui_keybinding.get_key_action: Get keybinding function name for keycode: 116, modifier: 0
Sep 15 13:53:59 zynthian startx[1509]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'arrow_down' => None
Sep 15 13:53:59 zynthian startx[1509]: DEBUG:zynthian_gui_keybinding.get_key_action: Get keybinding function name for keycode: 111, modifier: 0
Sep 15 13:53:59 zynthian startx[1509]: DEBUG:zynthian_gui.callable_ui_action: CUIA 'arrow_up' => None
Sep 15 13:54:00 zynthian startx[1509]: DEBUG:zynthian_gui_keybinding.get_key_action: Get keybinding function name for keycode: 111, modifier: 0
Sep 15 13:54:01 zynthian startx[1509]: DEBUG:zynthian_gui_keybinding.get_key_action: Get keybinding function name for keycode: 59, modifier: 0
Sep 15 13:54:02 zynthian startx[1509]: DEBUG:zynthian_gui_keybinding.get_key_action: Get keybinding function name for keycode: 104, modifier: 0
Thanks! And ā congrats on being so close to a final release! Iām imagining boxes of 5.1 kits sitting in jofemodoās living room, ready to ship ![]()
Everything works as it should, thanks.
Check your wiring layout config. You seem to have configured some pin in the encoder section and it shouldnāt be there. All 4 pins should be set to -1.
Thanks @jofemodo! I donāt recall changing it, but I donāt remember lots of thingsā¦this fixed my issue.
Fantastic work @jofemodo! ![]()
Now the UI of my custom Pi5 works perfectly as before, with all the functions available in touch, pots and keypad.
A big thank you!
for me the update to the latest RC didnāt go that smoothly.
At first it all looks good after doing the usual procedure:
- Download image 2024-09-14ā¦img
- Decompress it with xz
- Burn it with dd to SDcard
- Put it in the RPi
- Boot
Until here itās all right. Zynthian boots. I see the UI on my V4-Kit and go to admin to connect to WiFi, because I want to update.
The update seems to break something. Because after the update I end up on a white screen and webconf isnāt reachable anymore.
How can I find out whatās happening?
Any logs that get saved to SDcard during update?
All the best, Jojo
Issue after last update of my regular V5 zynthian
zyncoder: oram (79e270a)
zynthian-ui: oram (9b99281)
zynthian-sys: oram (9eba008)
zynthian-data: oram (6fa0db4)
zynthian-webconf: oram (346b77e)
UI doesnāt start anymore. I donāt have a glue why. Any suggestions?
Sep 15 21:02:16 zynthianV5oramRC1 startx[1701]: ZynCore: Setting-up 20+4 x Zynswitches...
Sep 15 21:02:16 zynthianV5oramRC1 startx[1701]: ZynCore: Setting-up Zynpots => 4 x PEC11 ...
Sep 15 21:02:16 zynthianV5oramRC1 startx[1701]: ZynCore->gpiod_start_callbacks: Callback thread created successfully
Sep 15 21:02:16 zynthianV5oramRC1 startx[1701]: ERROR:zynthian_gui_config.<module>: Can't init control I/O subsytem: 'NoneType' object is not subscriptable
Sep 15 21:02:17 zynthianV5oramRC1 startx[1725]: /zynthian/config/img/fb_zynthian_message.png is 800x480 PNG image, color type RGB_ALPHA, 8 bit
Sep 15 21:02:17 zynthianV5oramRC1 startx[1725]: Zooming image by 100%...done
It was working just before. Should I start from scratch again?
Same error and non working UI on a regular V4.
No error on a custom knobless, generic HDMI zynthian.
Just wanted to add that on first boot right after installing the image zynthain shuts down the pi. I had this happen with a pi400 and a cm4. I have to unplug power and plug back in so in can do its thing again.
I also can no longer access webconfig by plugging an Ethernet cable from my pc to the raspberry.
Hi @Hans_JB , when you say this is happening with a cm4, what is the cm4 plugged into - a CM4IOBRD or something else?
What kind of soundcard or audio interface are you using and how is it attached, ie USB, I2S, etc?
I had ORAM installed on the CM4 before with NVME. Itās installed in a waveshare CM4 DISP-BASE-5A https://www.waveshare.com/wiki/CM4-DISP-BASE-5A.
the installation went well. I didnāt even have to do the whole setting up nvme in cmd text file steps. It came up without issues.
I noticed that with both the cm4 and pi400, on first boot, after the first page of text on the screen, both pi shut down and I had to unplug and plug back so it can do the boot over again. Once I did that everything came up no issues. I also wanted to point out that I can no longer access webconfig via eithernet cable from my pc to the Pis which I was ble to do with the last ORAM I installed.
By the way just a heads up to some that may have bought the https://www.waveshare.com/wiki/CM4-DISP-BASE-5A or planning to buy it. The display no longer work with the latest (bookworm) even after installing drivers. Works with previous OS but something changed. I contacted waveshare and they know of the issue and had updated the hardware (so they say) to support it. Since I bought before this latest update, I would have to buy the newest version.
You can still use the HDMI output which still works but defeat the purpose of the all in one.
and the audio hardware? I didnāt see anything about built-in audio on the waveshare site: waveshare.com/wiki/CM4-DISP-BASE-5A
It should be fixed now. Please update and test!
regards,
Iām using a variant of hifiberry. As I mentioned above, I donāt have an issue now and did not have any issues before. I have both raspberry pi setup before as I do now. I just noticed something which I feel should bring up.
I did not have to unplug power and plug it back before on first boot, actually not even through the first boot just about two to three seconds and shutdown. The fact that it happened with both Piās felt like something I should bring up.
Can you get an ssh connection to the machine(s)�
It sounds like the machine is crashing on zynth & zynthwebconf start up. You should still be able to get an ssh connection which will allow you to view various logs and also stop and start the individual components to see where they are tripping up.
Thatās a pain. Did they give any indication of what the change isā¦?
Hi Zynthian developersā¦
It would be incredibly nice if the user (me
and I think also others with no physical knobs attached to the zynthian) could set a SSID and password before booting the Zynthian image. Something like the Raspberry Pi Imager offers.
Each time I download a new Zynthian image I have some kind of issue getting access to the software. Mostly I can access by attaching a keyboard and using raspi-config to configure WIFI. (and that is difficult when the screen is alternating between 2 screensā¦
Thanks in advance.
PS the Access Point is not accessible either⦠in my case
Maarten
It should setup the access point if the UI canāt boot.
Have you tried?
