I don’t understand the wiring thing you mean, the tft I have is made for the raspberry pi
it should be plug and play out the box
ive installed the tft on the top of the raspberry and I wanted to test it, to see if I get anything other then the Linux/debian/rasbian loading screen that I get on the hdmi monitor I have
I will check a bit more
well well well
I got webconf working and choise waveshare 32b… screen works, im happy guys
Yes guys it’s working on the screen
I get the zynthian start screen but error
I’ll work more on this tomorrow when my eyes are not ruined
Time to solder the wires and add the dac
Thanks guys
mheidt
September 26, 2017, 9:01pm
25
You need to wire the zynthian physically like described her
I added the following into my zynthian_webconf.py
[“PROTOTYPE-4-WS32”, {
‘ZYNTHIAN_WIRING_ENCODER_A’: “26,25,5,4”,
‘ZYNTHIAN_WIRING_ENCODER_B’: “21,27,7,31”,
‘ZYNTHIAN_WIRING_SWITCHES’: “107,23,106,6”
I moved KEES after Prototype-2, because this seemed to be the original base.
And I changed the fritzing picture
[image]
is there anyway I can use my touchscreen on the waveshape tft
and the 3 buttons there on the lcd
OK small step but I’m getting there
My waveshaper 3.2 clone works but I get error
I tried the USB sound card and get error
I tried hifiberry with my hdmi monitor… Get error
I’ve not it any wiring… I’ve got it on custom and everything I blanked out so it does the use any wiring I suppose…
The hdmi got pasted the error screen when I had the hifiberry in… But then again I could not control it… Is there a mouse option or keyboard option
Webconf is working
You should use “dummies” wiring
What model of HifiBerry are you using?
mheidt
September 28, 2017, 2:09pm
29
No, he has to use the wiring I described in the link. (PICTURE!)
And this means the webconf setting and the actual physical wiring
hifiberry dac+ HW 2.6
ok ill have to find some encoders and wire them up
thanks guys,starting but slowly getting happier and happier
While not having encoders, any wiring is needed and “Dummies” option should be used.
Of course, when @christianforshaw connect the encoders, the wiring described in the link is the way to go
Adriel
October 16, 2017, 6:50pm
32
good afternoon ! I installed the image gorgona_edge only with rp3 and hdmi started normal plus the mause does not appreciate why?
Adriel
October 16, 2017, 6:59pm
33
problem solved (I’ve updated), now I’m not going into ui mode
