hi guys
ok so I bought a raspberry pi3 and downloaded the rightfull image burnt it to a sd card and while I try boot it all I get is a lightning type icon on the top right of the screen
im using hdmi
raspberry pi3
I downloaded the right image file , 4gb and burnt it to a 8gb sdcard
what im I doing wrong?
Axeman
September 24, 2017, 8:56am
2
The lightning icon tells you that there is something wrong with power supply, it’s not zynthian related, it’s an hardware indicator.
OK I got a psu and now I just get a black screen after the loading…
Axeman
September 24, 2017, 1:43pm
4
Those images are tailored to a very specific hardware setup: RPi + PiTFT display + HiFiBerry DAC + encoders board.
Have you changed all the configuration files to use HDMI display and touch instead of TFT display and encoders?
As Jofemodo said above:-
You have to change the framebuffer in the next files:
/etc/systemd/system/zynthian.service
/zynthian/zynthian-sys/sbin/splash-screen.sh
/zynthian/zynthian-ui/zynthian.sh
Look for the references to /dev/fb1 and change them to /dev/fb0
The screen resolution is available at the begining of zynhian_gui.py
Define some Constants and Parameters for the GUI
Moreover, don’t hope to get something useful without a DAC. Internal sound is useless and USB audio cards are a pain in the arse.
it was more of a test to see if it I could get it working as is, ill keep getting more bits and pieces until ive got the full kit
Axeman
September 24, 2017, 2:13pm
6
Yes… been there, done that (while waiting for PiTFT and HifiBerry shipping)
With just a plain (no touch) HDMI display and no DAC, if you make those changes to config files, you’ll get a perfect deaf and mute zynthian…
wyleu
September 24, 2017, 3:12pm
7
There is this thread . . …
I am waiting for my hdmi touch screen to come from china. I thought I would get my zynthian up and running on a Hdmi hd monitor.
changed all fb1 to fb0
when I boot the pi I get all the boot up info the display but when it runs zynthian all i get is on dash in the top left.
what am i missing?
The only thing to be aware of is that the directory structure has changed a bit so if things ain’t where they claim to be on the thread they’ve probably just moved somewhere that is a bit more sensible in retrospect.
RB-TFT3.2-V2 can this tft be used with zynthian
mheidt
September 24, 2017, 3:57pm
10
Looks like a waveshare32. But quite expensive…
its a touchshield… im not bothered about the price really, just need to be able to use it and get it quite fast here, im in finland and this company will deliver in a few days etc
mheidt
September 24, 2017, 6:05pm
12
Maybe they are compatible. Just saying that I would google for waveshare and try to get that. Looks like a waveshare clone to me.
mheidt:
waveshare
it looks like a clone yes, I just ordered it, few days to come ,
Hi @christianforshaw !
Please, it would be a lot better if you use the last image:
Hi @zynthianers!
Finally i’ve upload a updated Gorgona image. Its name is “Gorgona Edge” and includes the latest version of software until now. It’s not a “new” image, only an updated one.
http://blog.zynthian.org/download/zynthian_gorgona_edge_rbpi3_pitft-2017-09-18.img.torrent
Only Gorgona RBPi3 version. No RBPi2 and no Gorgonilla. Sorry
BTW, I’m working in a new SD image based in Raspbian Stretch and i hope to release about Christmas
There is no “gorgonilla version” (lite), so you will need a 16GB SD card.
@jofemodo
I sent you a few pm about spares I need if you have them for sale still
i just sent you the answer
ok so my hifiberry dac came and my tft
its a joy-it 3.2" touchscreen tft
tried pluging the tft in and all I get is a white screen, the same white screen as if nothing is installed on the raspberry
I plugged my hdmi monitor in at the same time and I get the loading text message screen thing, nothing else
http://www.joy-it.net/en/tft-display-3-2-v2/
mheidt
September 26, 2017, 5:35pm
18
Search for waveshare32 in this forum. You need a special wiring.
is it a different wiring or should I edit the config file
I search this
#NO_ZYNTHIAN_UPDATE
For more options and information see
Some settings may impact device functionality. See link above for details
Tell bootloader to use initram image
#initramfs initrd.img-4.1.13-v7+
Load RT Kernel for RBPI2
#kernel=kernel7-rt.img
uncomment if you get no picture on HDMI for a default “safe” mode
#hdmi_safe=1
uncomment this if your display has a black border of unused pixels visible
and your display can output without overscan
#disable_overscan=1
uncomment the following to adjust overscan. Use positive numbers if console
goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
uncomment to force a console size. By default it will be display’s size minus
overscan.
#framebuffer_width=1280
#framebuffer_height=720
uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
uncomment to force a HDMI mode rather than DVI. This can make audio work in
DMT (computer monitor) modes
#hdmi_drive=2
uncomment to increase signal to HDMI, if you have interference, blanking, or
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
Disable Splash Screen
disable_splash=1
Disables dynamic frequency clocking
force_turbo=1
Uncomment to overclock the arm. 700 MHz is the default.
[pi2]
arm_freq=900
core_freq=250
sdram_freq=450
over_voltage=2
[all]
Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
Additional overlays and parameters are documented /boot/overlays/README
Disable Blutooth Support for HifiBerry compatibility with RBPi 3
Swap back the ttyAMA0 to GPIO
[pi3]
dtoverlay=pi3-disable-bt
dtoverlay=pi3-miniuart-bt
[all]
Enable MMAP support (Jackd, etc.)
dtoverlay=i2s-mmap
Audio Device Driver:
#dtoverlay=hifiberry-amp
#dtoverlay=hifiberry-dac
dtoverlay=hifiberry-dacplus
#dtoverlay=hifiberry-digi
#dtoverlay=iqaudio-dac
#dtoverlay=iqaudio-dacplus
#dtoverlay=audioinjector-wm8731-audio
#AUDIO_DEVICE_DTOVERLAY
PiTFT Config
#dtoverlay=pitft28-capacitive,rotate=90,speed=32000000,fps=20
#dtoverlay=pitft28-resistive,rotate=90,speed=32000000,fps=20
dtoverlay=waveshare32b:rotate=90,swapxy=1
Adjust Serial Port Clock to allow MIDI baudrate 31250
[pi2]
init_uart_clock=2441000
init_uart_baud=38400
dtparam=uart0_clkrate=3000000
[pi3]
init_uart_clock=39062500
dtparam=uart0_clkrate=48000000
[all]
mheidt
September 26, 2017, 5:42pm
20
No, there is a thread in this forum which tells you what you have to do. I don’t have time to search it right now.
