The select encoder works as a button, but rotating doesn’t work. If I pick a synth, it shows the left 2 registering data, but the right two don’t change the values when rotated.
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
If your encoder switches work then you can be sure the I2C bus works which is confirmed by your command line. The likely hood is then that you have a wiring issue. Do you get different behaviour if you swap other encoders and see the effect follow a particular encoder or does it stay on a specific 23017 connector pins? Can you check continuity with a multi meter?
Ok, swaping your encoders tells that they are working, so maybe there’s something wrong on the Zynsreen.
Just to be sure, I suppose you didn’t change anything in the hardware configuration ?
This could be caused by trying to insert the male connector reversed and pushing too strong. JST connectors normally plug smoothly when correctly oriented
Great to have another working zynthian over the world. BTW, you shouldn’t forget the . Wyleu’s ravens are hungry …
