New zynthianOS image: stable-2401
Hi Jeremias!
The more relevant changesin the new stable-2401 are explained here:
There will be more and deeper changes in the next chain_manager release, so probably you will need to refactor partially your highly customized snapshots. Basically we have removed the “clone” option because we allow having several synth chains in the same MIDI channel. There is a new type of chain, “MIDI+AUDIO” that can be used to route MIDI to several layered chains and then route the audio back to a “group” fader that controls volume of the mix of layered sounds. I think improves quite a bit the current behaviour. All this is in the chain_manager branch, that will be in testing very very soon.
All the best!
Hello @jofemodo
So in the current version of ZynOS, I can’t already test the new paradigm?
Not until the next testing release, unless you want to change to chain_manager branch. It’s one way, so better use a separated SD-card for this.
Now I understand. Thanks @jofemodo!
