Newbe : Also Sd card image probkems
Hello, I’m also having a lot of trouble installing the original image from Zynthian. First I tried a 256GB Lenovo. That didn’t work. I tried using the original Pi imager. I kept getting a 99% verification error. Then I tried a 64GB Sandisk Extreme. But that also got a 99% verification error.
Later, I tried a standard Pi OS image from the Pi image program itself, which worked fine.
It booted fine.
On a Pi 4b 8Gb.
Who knows what to do?
Just to be sure, I ordered a 64GB Sandisk S2 Extreme.
Hi @Robroy1974 !
What image are you trying to install? Did you check the file is correctly downloaded using the MD5 hash?
Did you unpack the archive and used the img? This happened multiple times to me.
