I stumbled across Zynthian whilst searching for something else, glad I did, what an awesome project, thanks for all your efforts.
I’m new to Zynthian, but not new to Linux, ARM, basic electronics, dremeling project boxes etc. I think your “standard” hardware platform is a very good idea, but, I’m always on a budget these days, so looking at ways to keep my costs down. So, hackable, great for me !
After reading up a little, I just wanted to clarify a few things hardware related, apologies if this has been asked before …
- Can I use HDMI/VGA/Composite video for the display ? From reading the forum It seems probably just a case of switching frame buffer and editing settings files ?
1a. With a touchscreen display, are rotary encoders still required ?
1b. Zynthian headless with xRDP ?
USB sound / USB MIDI card or adapter ? From what I’ve read the worry here is latency issues, but, anyone tried it, and what was conclusion ?
MIDI over ip, is it possible with things like MIDIrtp and the open source versions of Apple MIDI ?
Given Zynthian runs on Raspbian, a Debian derivative, then is it possible to run on other ARM boards, eg Banana PI, Beaglebone, Odroid Etc. on Debian And what about Intel/AMD PC motherboards (which probably has sound card built in already).
Given that GPIOs could be freed with HDMI/VGA/Composite display, and maybe sound card moved to USB, then would it be possible to hack/change the 2in1 to a 1in1 that just does MIDI in, or maybe even MIDI IN/Thru/Out ?
Thanks for your help.
