Newby: how to connect with VNC?
Yes this works. now I have:
so what’s next to get the native UI of Pteq?
If you have this in XQuartz, you can now just open a new Pianoteq layer in Zynthian UI (via VNC for example)
Okay, succes! But Native UI Pteq is extremely unresponsive. On a MacBook Air sept '20 with BigSur & Xquartz. When I quit Xquartz Zynthian stops giving sound, have to reboot.
I will try it on my older MacBook Pro with a ethernet connection & cable.
Screenshots …? :smiley:
Pianoteq UI over X-forwading is painfully slow. It for worse with PT7. If you are on WiFi it will be unusable and even on wired connection it is poor.
So I experienced. Not a big issue. Maybe in the future is is possible to incorporate some more Pteq parameters in the Zynthian UI.
Hi there !
It’s a two year old topic but well…
My Zynthian work
My VNC windows work
Xming is running
Putty is running and i’m logged
Putting the command xterm -bg black -fg yellow & make a window pop into my computer
But nothing pop if I clic into my Zynthian device into my Pianoteq75 or DrumGizmo channel.
What should I have to do is not clear for me. But what should I have to expect is as the captures above… so I do something wrong but don’t know what.
I would suggest not using X-forwarding but instead use VNC which works a lot better. When VNC is enabled there are 2 VNC servers running. One will present the main Zynthian GUI. The other presents a “desktop” which can show the native GUI of each engine / plugin. Both are accessible from the INTERFACE menu in webconf.
Thanks !
For some reasons, the webconf/INTERFACE buttons leads me to a blank page.
But VNC is working great right now !
I set VNC server to zynthian.local:5901 (and was trying 6081 because of the http://zynthian.local:6081/vnc.html link…)
6081 is the port that Zynthian uses to present the VNC session embedded in a webpage. There is also the raw VNC server on port 5901 that you can connect a VNC client to directly. It is strange that you don’t see VNC in the web browsers. Maybe something is blocking it or your browser doesn’t support it.
Thank you for the explanation :slight_smile:
I use chrome on all my devices.
But it’s a good to know information. Is it worth to add it to the wiki pages for a little more dummy beginners (like me) ?
Like this?
