I’m into music but a total newby with CLI and Linux, so… Ok, so I wanted to see the Pianoteq native UI on my iPad. I have VNC reader installed on the iPad and can acces the screen of my other PI.
I followed all the steps in the wiki “accessing Zynthian from a computer” and installed the VNC server.
I rebooted and entered # vnc4server but got the message “command not found”. As you can see in the picture vnc4server and blackbox are installed.
So, how do I start the vnc server?
Thanks for replying on a potentially silly question
Hi @wyleu I did change the password of the Zynthian and my VNC viewer on iPad sees the Zynthian but cannot connect. I get a time out in the viewer. I don’t know how to turn on VNC on the Zynthian, that I think is the point. I suspect I need to type something in the CLI? (BTW I did all this stuff in the terminal window inside webconfig. That IS the PI CLI isn’t it?)
Down in the depths of every Pi there is a programme called raspi-config that does low level stuff… IN there you can turn on the vnc service in an approved fashion as possible, with the systemctl mechanism all nicely set up for you.
Enter and Tab are the keys that move you around the menu…
You know what’s coming at the end of this don’t you … ? …
Ok I’m some steps further. I did get the screens in the wiki typing raspi-config. Now the VNC viewer recognizes the zynthian but it refuses the password. To be sure: username & password are the same as the ones I use to login in with webconfig, aren’t they?
Hello all, very excited with my new zynthian v4.1 ! its amazing.
I managed to connect to Zythian GUI with VNC viewer, following the information i found on the website. (I ended up working with VNC viewer because i could not get Xquartz to work on macOS11 – i could not confirm that it even works at all with Big Sur.)
Very happy to have the zynthian window on my computer screen, but i would rather like to access Zynaddsubfx’s or PT’s native GUIs …
the information i saw suggests that creating a new synth layer will allow me to see the ui on VNC… but it seems i am missing a key step to get this to work…
I read that X11 hasn’t been officially supported since Mountain Lion and X.Org has been recently abandoned by Red Hat.
So it’s completely possible that this isn’t going to work on new macs with OS11, especially the silicon ones.
Maybe someone knows a more durable alternative ?
Hello again,
thanks for the info @gnuv. So VNC won’t show native UI’s.
But…
I think I have a login issue. I CAN login to webconfig. VNC reader sees the Zynthian but there I can’t login with the same credentials. I suspect it has something to do with the users on the PI.
In webconfig> terminal I see “root@zynthian”
When I activated VNC on the Zynthian, the screen started with user “PI” but I read somewhere that “PI” doesn’t exist on a Zynthian. So I changed that to user “zynthian”. Was that correct?
I installed Xquartz on my Macbook with OS 11 Big Sur. Is seems to work.
When I type “ssh -Y zynthian.local” I get joostovermars@zynthian.local and it doesn’t accept my password (same I use for login to webconfig.)
Well… as I’m not a ‘code animal’ I think I’ll leave it with this. I’m extremely happy with my Zynthian. My main goal was to edit Pianoteq presets but I can do that as well on my Mac and load them into Zynthian.
Thanks everyone for your support. Really appreciate that!
