all up and working except no audio ran this:
/zynthian/zynthian-sys/sbin/zynthian.sh
root@zynthian:~# /zynthian/zynthian-sys/sbin/zynthian.sh
/zynthian/zynthian-sys/sbin/zynthian.sh: 3: /zynthian/zynthian-sys/sbin/zynthian.sh: source: not found
X.Org X Server 1.18.4
Release Date: 2016-07-19
Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Current Operating System: Linux zynthian 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l
Kernel command line: bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Build Date: 11 November 2016 11:59:59AM
xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
Current version of pixman: 0.33.3
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Thu Sep 7 21:26:45 2017
(==) Using config directory: “/etc/X11/xorg.conf.d”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
./zynthian.sh: line 26: /etc/X11/zynthian: No such file or directory
INFO:root:Wiring Layout PROTOTYPE-3H
DEBUG:root:ZYNCODER A: [26, 25, 2, 4]
DEBUG:root:ZYNCODER B: [21, 27, 7, 24]
DEBUG:root:SWITCHES layout: [100, 101, 102, 103]
Zyncoder: Zynswitches poll thread created successfully
Zyncoder: MIDI tuning frequency set to 440 Hz (8192)
INFO:root:SWITCHES INIT…
INFO:root:SETUP GPIO SWITCH 0 => 100
INFO:root:SETUP GPIO SWITCH 1 => 101
INFO:root:SETUP GPIO SWITCH 2 => 102
INFO:root:SETUP GPIO SWITCH 3 => 103
DEBUG:root:ZCTRL ‘Layer’: 0 (0 -> 2), None, None
ERROR:root:Can’t load snapshot ‘/zynthian/zynthian-ui/my-data/snapshots/default.zss’: [Errno 2] No such file or directory: '/zynthian/zynthian-ui/my-data/snapshots/default.zss’
DEBUG:root:ZCTRL ‘Bank’: 0 (0 -> 0), None, None
any ideas please
