i have a problem with recording. When my Circuit Tracks or another novation instrument is connected, the record of audio and midi doesn’t work. Can i set the capture path that it is not switching to a connected USB Device. I run Zynthian on a Pi4 with an external SSD so the normal capture path has enough diskspace and writespeed.
Yes it acts as a Mass Storage device. I have also other Instruments connected, thats why i asked to adjust the path in a config. Would it help if i add a Partition of the SSD via fstab and this is taken as captures path?
Better not ignore read only units, because one could use a hardware write protected stick with valuable data. Write protection prevents the data from being shredded by faulty software, so that is why people use this kind of storage media.
We could have a configuration that allows users to flag devices to ignore or a curated list of known offenders… but maybe you want to access the audio on your Circuit Tracks - or whatever.
We could disable saving to read-only media but still allow reading from it.
Wow great! Thx alot, this is very helpful for users. Because i had no idea how to solve the problem because it just didn’t work. I am a bit experienced in looking in the systemlogs so i got a hint with the ro permissions.
Thx for the fix @jofemodo. It works. I remove the fstab entry and made the update, YES
