root@zynthian:~# systemctl stop zynthian
root@zynthian:~# /zynthian/zynthian-sys/sbin/zynthian.sh
/zynthian/zynthian-sys/sbin/zynthian.sh: 3: /zynthian/zynthian-sys/sbin/zynthian.sh: source: not found
X.Org X Server 1.18.4
Release Date: 2016-07-19
Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Current Operating System: Linux zynthian 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l
Kernel command line: bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Build Date: 11 November 2016 11:59:59AM
xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
Current version of pixman: 0.33.3
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Wed Sep 6 15:05:20 2017
(==) Using config directory: “/etc/X11/xorg.conf.d”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
root@zynthian:~#
i have just tried it with an adafruit 2.8 resistive tft and same results when reconfigured with webconf it hangs on restart with:
open /dev/fb1 no such file or directory exists
then blank screen on restart.
? You need exactly the files from the website of waveshare. I assume you copied some files the first time and forgot to apply it now after the clean install
yes i started with a fresh gorgonilla image and updated as usual it was all working prior to upgrade.
Xorg.0.log
[ 44.278] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 44.279] (II) no primary bus or device found
[ 44.279] (II) LoadModule: “glx”
[ 44.280] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 44.286] (II) Module glx: vendor=“X.Org Foundation”
[ 44.286] compiled for 1.18.4, module version = 1.0.0
[ 44.287] ABI class: X.Org Server Extension, version 9.0
[ 44.287] (==) AIGLX enabled
[ 44.287] (II) LoadModule: “fbdev”
[ 44.287] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 44.288] (II) Module fbdev: vendor=“X.Org Foundation”
[ 44.288] compiled for 1.18.4, module version = 0.4.4
[ 44.288] Module class: X.Org Video Driver
[ 44.288] ABI class: X.Org Video Driver, version 20.0
[ 44.288] (II) FBDEV: driver for framebuffer: fbdev
[ 44.292] (WW) Falling back to old probe method for fbdev
[ 44.292] (II) Loading sub module “fbdevhw”
[ 44.292] (II) LoadModule: “fbdevhw”
[ 44.293] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 44.293] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 44.293] compiled for 1.18.4, module version = 0.0.2
[ 44.293] ABI class: X.Org Video Driver, version 20.0
[ 44.294] (EE) open /dev/fb1: No such file or directory
[ 44.294] (EE) No devices detected.
[ 44.294] (EE)
Fatal server error:
[ 44.294] (EE) no screens found(EE)
[ 44.294] (EE)
for help.
[ 44.294] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 44.294] (EE)
[ 44.303] (EE) Server terminated with error (1). Closing log file.
new gorgonilla image to start with then apt get update && upgrade then the usual update method and i removed the penriq=17. which worked in the end. thank you very much for all the help. amazing synth
