rpi-update done.
aply -l gives:
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 3: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0 [HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0]
Subdevices: 0/1
dmesg gives:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.9-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1396 SMP Thu Jan 21 15:57:42 GMT 2021
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] On node 0 totalpages: 504832
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 308224 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50636 r8192 d23092 u81920
[ 0.000000] pcpu-alloc: s50636 r8192 d23092 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 502528
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:D8:73:2C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000025400000-0x0000000029400000] (64MB)
[ 0.000000] Memory: 1844128K/2019328K available (10240K kernel code, 1354K rwdata, 3152K rodata, 2048K init, 890K bss, 109664K reserved, 65536K cma-reserved, 1232896K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 33823 entries in 67 pages
[ 0.000000] ftrace: allocated 67 pages with 3 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
[ 0.000004] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000015] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000045] bcm2835: system timer (irq = 25)
[ 0.000310] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000319] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000328] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000336] Switching to timer-based delay loop, resolution 18ns
[ 0.000450] Console: colour dummy device 80x30
[ 0.000752] printk: console [tty1] enabled
[ 0.000783] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000806] pid_max: default: 32768 minimum: 301
[ 0.000883] LSM: Security Framework initializing
[ 0.000971] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000990] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001718] Disabling memory control group subsystem
[ 0.001777] CPU: Testing write buffer coherency: ok
[ 0.002002] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002522] Setting up static identity map for 0x200000 - 0x20003c
[ 0.002612] rcu: Hierarchical SRCU implementation.
[ 0.003025] smp: Bringing up secondary CPUs ...
[ 0.003600] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.004220] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.004806] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.004870] smp: Brought up 1 node, 4 CPUs
[ 0.004903] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.004915] CPU: All CPU(s) started in HYP mode.
[ 0.004926] CPU: Virtualization extensions available.
[ 0.005317] devtmpfs: initialized
[ 0.011300] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.011420] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.011445] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.012511] pinctrl core: initialized pinctrl subsystem
[ 0.013034] NET: Registered protocol family 16
[ 0.014846] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.015181] audit: initializing netlink subsys (disabled)
[ 0.015323] audit: type=2000 audit(0.010:1): state=initialized audit_enabled=0 res=1
[ 0.015565] thermal_sys: Registered thermal governor 'step_wise'
[ 0.015868] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.015890] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.016118] Serial: AMBA PL011 UART driver
[ 0.030811] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.050341] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-01-21T16:02:55, variant start
[ 0.060348] raspberrypi-firmware soc:firmware: Firmware hash is a5bf70c44ba93e99f955a66530916240a1661132
[ 0.084470] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.086244] vgaarb: loaded
[ 0.086446] SCSI subsystem initialized
[ 0.086549] usbcore: registered new interface driver usbfs
[ 0.086580] usbcore: registered new interface driver hub
[ 0.086616] usbcore: registered new device driver usb
[ 0.086779] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.087610] clocksource: Switched to clocksource arch_sys_counter
[ 0.500689] VFS: Disk quotas dquot_6.6.0
[ 0.500748] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.500825] FS-Cache: Loaded
[ 0.500934] CacheFiles: Loaded
[ 0.505079] NET: Registered protocol family 2
[ 0.505566] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.505594] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.505626] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.505661] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.505745] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.505772] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.505897] NET: Registered protocol family 1
[ 0.506218] RPC: Registered named UNIX socket transport module.
[ 0.506232] RPC: Registered udp transport module.
[ 0.506244] RPC: Registered tcp transport module.
[ 0.506255] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.506272] PCI: CLS 0 bytes, default 64
[ 0.507587] Initialise system trusted keyrings
[ 0.507760] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.511110] zbud: loaded
[ 0.511925] FS-Cache: Netfs 'nfs' registered for caching
[ 0.512262] NFS: Registering the id_resolver key type
[ 0.512284] Key type id_resolver registered
[ 0.512296] Key type id_legacy registered
[ 0.512358] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.512806] Key type asymmetric registered
[ 0.512820] Asymmetric key parser 'x509' registered
[ 0.512905] bounce: pool size: 64 pages
[ 0.512930] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.513031] io scheduler mq-deadline registered
[ 0.513044] io scheduler kyber registered
[ 0.514963] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.514987] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.515028] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 0.515072] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
[ 0.599693] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 0.599867] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.599882] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.599897] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 0.599946] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.600059] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.601520] PCI: bus0: Fast back to back transfers disabled
[ 0.601700] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.601797] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.602090] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.603567] PCI: bus1: Fast back to back transfers disabled
[ 0.603602] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.603618] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.603685] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.603702] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.603889] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.603987] pcieport 0000:00:00.0: PME: Signaling with IRQ 65
[ 0.604394] bcm2708_fb soc:fb: FB found 1 display(s)
[ 0.611676] Console: switching to colour frame buffer device 100x30
[ 0.613138] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 800x480
[ 0.615962] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.616883] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
[ 0.618489] iproc-rng200 fe104000.rng: hwrng registered
[ 0.619102] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.619998] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.625944] brd: module loaded
[ 0.632051] loop: module loaded
[ 0.633338] Loading iSCSI transport class v2.0-870.
[ 0.634911] libphy: Fixed MDIO Bus: probed
[ 0.635970] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 0.647664] libphy: bcmgenet MII bus: probed
[ 0.727668] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 0.728692] usbcore: registered new interface driver r8152
[ 0.729229] usbcore: registered new interface driver lan78xx
[ 0.729745] usbcore: registered new interface driver smsc95xx
[ 0.776062] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.776563] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.778162] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
[ 0.779742] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 0.780271] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.780800] usb usb1: Product: xHCI Host Controller
[ 0.781322] usb usb1: Manufacturer: Linux 5.10.9-v7l+ xhci-hcd
[ 0.781844] usb usb1: SerialNumber: 0000:01:00.0
[ 0.782673] hub 1-0:1.0: USB hub found
[ 0.783219] hub 1-0:1.0: 1 port detected
[ 0.784012] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.784495] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.784970] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.785645] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 0.786107] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.786573] usb usb2: Product: xHCI Host Controller
[ 0.787041] usb usb2: Manufacturer: Linux 5.10.9-v7l+ xhci-hcd
[ 0.787515] usb usb2: SerialNumber: 0000:01:00.0
[ 0.788282] hub 2-0:1.0: USB hub found
[ 0.788804] hub 2-0:1.0: 4 ports detected
[ 0.790093] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.790695] dwc_otg: FIQ enabled
[ 0.790701] dwc_otg: NAK holdoff enabled
[ 0.790707] dwc_otg: FIQ split-transaction FSM enabled
[ 0.790715] Module dwc_common_port init
[ 0.790923] usbcore: registered new interface driver uas
[ 0.791435] usbcore: registered new interface driver usb-storage
[ 0.791995] mousedev: PS/2 mouse device common for all mice
[ 0.793215] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.794697] sdhci: Secure Digital Host Controller Interface driver
[ 0.795187] sdhci: Copyright(c) Pierre Ossman
[ 0.795965] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.796682] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.799567] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.800167] hid: raw HID events driver (C) Jiri Kosina
[ 0.800705] usbcore: registered new interface driver usbhid
[ 0.801159] usbhid: USB HID core driver
[ 0.804325] Initializing XFRM netlink socket
[ 0.804855] NET: Registered protocol family 17
[ 0.805385] Key type dns_resolver registered
[ 0.806027] Registering SWP/SWPB emulation handler
[ 0.806619] registered taskstats version 1
[ 0.807110] Loading compiled-in X.509 certificates
[ 0.808048] Key type ._fscrypt registered
[ 0.808522] Key type .fscrypt registered
[ 0.808982] Key type fscrypt-provisioning registered
[ 0.814366] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 0.814920] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.815385] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 0.820214] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
[ 0.821066] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 38, base_baud = 62500000) is a 16550
[ 0.821954] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.822878] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.823363] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.856331] of_cfs_init
[ 0.856906] of_cfs_init: OK
[ 0.872839] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.874837] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.876785] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.879930] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.881850] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.886134] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.887155] Waiting for root device /dev/mmcblk0p2...
[ 0.923442] random: fast init done
[ 0.953944] mmc1: new high speed SDIO card at address 0001
[ 0.988814] mmc0: new ultra high speed DDR50 SDXC card at address 1234
[ 0.989643] mmcblk0: mmc0:1234 SA64G 57.7 GiB
[ 0.992465] mmcblk0: p1 p2
[ 1.019535] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.020054] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.025298] devtmpfs: mounted
[ 1.029434] Freeing unused kernel memory: 2048K
[ 1.067743] Run /sbin/init as init process
[ 1.068186] with arguments:
[ 1.068192] /sbin/init
[ 1.068197] with environment:
[ 1.068203] HOME=/
[ 1.068209] TERM=linux
[ 1.147668] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.330209] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.330695] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.331143] usb 1-1: Product: USB2.0 Hub
[ 1.332927] hub 1-1:1.0: USB hub found
[ 1.333603] hub 1-1:1.0: 4 ports detected
[ 1.522686] systemd[1]: System time before build time, advancing clock.
[ 1.610348] NET: Registered protocol family 10
[ 1.611487] Segment Routing with IPv6
[ 1.653092] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.655003] systemd[1]: Detected architecture arm.
[ 1.657659] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[ 1.712482] systemd[1]: Set hostname to <zynthian>.
[ 1.804417] usb 1-1.4: New USB device found, idVendor=0763, idProduct=0150, bcdDevice= 1.13
[ 1.805256] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.805906] usb 1-1.4: Product: USB Uno MIDI Interface
[ 1.806532] usb 1-1.4: Manufacturer: M-Audio
[ 2.147477] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.154271] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.154996] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.156471] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.157015] systemd[1]: Reached target Swap.
[ 2.158695] systemd[1]: Listening on Journal Socket.
[ 2.165692] systemd[1]: Starting Load Kernel Modules...
[ 2.171934] systemd[1]: Starting Restore / save the current clock...
[ 2.174129] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.178529] systemd[1]: Starting Set the console keyboard layout...
[ 2.222225] i2c /dev entries driver
[ 2.282505] dwc2 fe980000.usb: supply vusb_d not found, using dummy regulator
[ 2.283245] dwc2 fe980000.usb: supply vusb_a not found, using dummy regulator
[ 2.497723] dwc2 fe980000.usb: EPs: 8, dedicated fifos, 4080 entries in SPRAM
[ 2.500435] dwc2 fe980000.usb: DWC OTG Controller
[ 2.500960] dwc2 fe980000.usb: new USB bus registered, assigned bus number 3
[ 2.501478] dwc2 fe980000.usb: irq 40, io mem 0xfe980000
[ 2.502154] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.502644] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.503123] usb usb3: Product: DWC OTG Controller
[ 2.503638] usb usb3: Manufacturer: Linux 5.10.9-v7l+ dwc2_hsotg
[ 2.504124] usb usb3: SerialNumber: fe980000.usb
[ 2.504969] hub 3-0:1.0: USB hub found
[ 2.505540] hub 3-0:1.0: 1 port detected
[ 2.551548] MIDI Gadget
[ 2.552033] MIDI Gadget gadget: MIDI Gadget ready
[ 2.552492] dwc2 fe980000.usb: bound driver MIDI Gadget
[ 3.431499] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.473442] systemd-journald[120]: Received request to flush runtime journal from PID 1
[ 3.775902] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 3.776215] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 3.782223] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 3.784246] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 3.854052] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.855052] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 3.855064] [vc_sm_connected_init]: start
[ 3.866263] [vc_sm_connected_init]: installed successfully
[ 3.879078] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.882564] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 3.888169] mc: Linux media interface: v0.10
[ 3.928348] videodev: Linux video capture interface: v2.00
[ 3.966940] input: raspberrypi-ts as /devices/platform/soc/soc:firmware/soc:firmware:touchscreen/input/input0
[ 3.986746] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.987010] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.996818] snd-rpi-hifiberry-dacplus soc:sound: activating headphone amplifier
[ 4.020007] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.021338] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.026269] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.033098] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.033277] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.033329] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.033335] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.033553] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.033756] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.033776] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.033809] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.033819] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.033828] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.033951] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.035767] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.035788] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.038171] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.038196] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.131700] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.187139] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.204928] usbcore: registered new interface driver snd-usb-audio
[ 4.221809] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.229669] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.230107] usbcore: registered new interface driver brcmfmac
[ 4.253133] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 4.461013] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.479836] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 4.540162] tpa6130a2 1-0060: supply Vdd not found, using dummy regulator
[ 5.176370] random: crng init done
[ 5.176384] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.394699] 8021q: 802.1Q VLAN Support v1.8
[ 5.985151] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 6.273218] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 6.273492] bcmgenet fd580000.ethernet eth0: Link is Down
[ 8.249934] uart-pl011 fe201000.serial: no DMA platform data
[ 11.274910] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
And grep dtoverlay /boot/config.txt gives:
#dtoverlay=lirc-rpi
dtoverlay=i2s-mmap
dtoverlay=pi3-disable-bt
dtoverlay=pi3-miniuart-bt
dtoverlay=dwc2
dtoverlay=hifiberry-dacplus
dtoverlay=rpi-ft5406,touchscreen-inverted-x=1,touchscreen-inverted-y=1
dtoverlay=midi-uart0
