Hi
Earlier today I tried doing a full software update of my Zynthian, and unfortunatelty sound is no longer working. Why did I do an update even though everything was working perfectly and I wasn’t missing anything you ask? I don’t know…
The log keeps saying WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN! again and again…
Here’s more from the log:
-- Logs begin at Thu 2019-02-14 10:11:58 GMT. --
Jan 21 17:39:57 zynthian systemd[1]: Started Zynthian User Interface (DEBUG).
Jan 21 17:39:57 zynthian startx[1374]: X.Org X Server 1.20.4
Jan 21 17:39:57 zynthian startx[1374]: X Protocol Version 11, Revision 0
Jan 21 17:39:57 zynthian startx[1374]: Build Operating System: Linux 5.4.0-54-generic armv8l Raspbian
Jan 21 17:39:57 zynthian startx[1374]: Current Operating System: Linux zynthian 5.10.7-v7l+ #1395 SMP Mon Jan 18 16:17:57 GMT 2021 armv7l
Jan 21 17:39:57 zynthian startx[1374]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:D8:73:2C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Jan 21 17:39:57 zynthian startx[1374]: Build Date: 01 December 2020 05:59:57PM
Jan 21 17:39:57 zynthian startx[1374]: xorg-server 2:1.20.4-1+rpt2+deb10u2 (https://www.debian.org/support)
Jan 21 17:39:57 zynthian startx[1374]: Current version of pixman: 0.36.0
Jan 21 17:39:57 zynthian startx[1374]: Before reporting problems, check http://wiki.x.org
Jan 21 17:39:57 zynthian startx[1374]: to make sure that you have the latest version.
Jan 21 17:39:57 zynthian startx[1374]: Markers: (--) probed, (**) from config file, (==) default setting,
Jan 21 17:39:57 zynthian startx[1374]: (++) from command line, (!!) notice, (II) informational,
Jan 21 17:39:57 zynthian startx[1374]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jan 21 17:39:57 zynthian startx[1374]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 21 17:39:57 2021
Jan 21 17:39:57 zynthian startx[1374]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Jan 21 17:39:57 zynthian startx[1374]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Jan 21 17:39:58 zynthian startx[1374]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Jan 21 17:39:58 zynthian startx[1374]: INFO:zynthian_gui_config.<module>: Wiring Layout CUSTOM
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_gui_config.<module>: ZYNCODER A: [12, 22, 5, 2]
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_gui_config.<module>: ZYNCODER B: [13, 21, 4, 0]
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_gui_config.<module>: SWITCHES layout: [14, 26, 3, 7]
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Jan 21 17:39:58 zynthian startx[1374]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Jan 21 17:39:59 zynthian startx[1374]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of <http://gareus.org/oss/lv2/b_whirl#extended> from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Jan 21 17:39:59 zynthian startx[1374]: lilv_world_load_bundle(): note: New version 2071.11 found in <file:///zynthian/zynthian-plugins/lv2/b_whirl/>
Jan 21 17:39:59 zynthian startx[1374]: lilv_world_load_bundle(): warning: Replacing version 2071.7 of <http://gareus.org/oss/lv2/b_whirl#simple> from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>
Jan 21 17:39:59 zynthian startx[1374]: lilv_world_load_bundle(): warning: Ignoring bundle <file:///zynthian/zynthian-plugins/lv2/b_synth.lv2/>
Jan 21 17:39:59 zynthian startx[1374]: lilv_world_load_bundle(): note: Newer version of <http://gareus.org/oss/lv2/b_synth> loaded from <file:///zynthian/zynthian-plugins/lv2/b_synth/>
Jan 21 17:40:00 zynthian startx[1374]: INFO:zynthian_gui.<module>: STARTING ZYNTHIAN-UI ...
Jan 21 17:40:00 zynthian startx[1374]: INFO:zynthian_gui_keybinding.load: Loading key binding from keybinding.yaml
Jan 21 17:40:00 zynthian startx[1374]: DEBUG:zynthian_gui_keybinding.load: Loading default keyboard bindings.
Jan 21 17:40:01 zynthian startx[1374]: libjackpeak registering as 'jackpeak'.
Jan 21 17:40:01 zynthian startx[1374]: libjackpeak created input ports
Jan 21 17:40:01 zynthian startx[1374]: INFO:zynthian_gui.zynswitches_init: SWITCHES INIT...
Jan 21 17:40:01 zynthian startx[1374]: INFO:zynthian_gui.zynswitches_init: SETUP ZYNSWITCH 0 => wpGPIO 14
Jan 21 17:40:01 zynthian startx[1374]: INFO:zynthian_gui.zynswitches_init: SETUP ZYNSWITCH 1 => wpGPIO 26
Jan 21 17:40:01 zynthian startx[1374]: INFO:zynthian_gui.zynswitches_init: SETUP ZYNSWITCH 2 => wpGPIO 3
Jan 21 17:40:01 zynthian startx[1374]: INFO:zynthian_gui.zynswitches_init: SETUP ZYNSWITCH 3 => wpGPIO 7
Jan 21 17:40:01 zynthian startx[1374]: INFO:zynthian_gui.zynswitches_midi_setup: MIDI SWITCHES SETUP...
Jan 21 17:40:01 zynthian startx[1374]: INFO:zynthian_engine.start: Starting Engine JackTransport
Jan 21 17:40:01 zynthian startx[1374]: DEBUG:zynthian_engine.start: Command: /usr/local/bin/jack_transport
Jan 21 17:40:01 zynthian startx[1374]: DEBUG:zynthian_engine_mixer.get_controllers_dict: MIXER CTRL LIST: ['Digital Left', 'Digital Right']
Jan 21 17:40:01 zynthian startx[1374]: DEBUG:zynthian_engine_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: Digital_0 => 60
Jan 21 17:40:01 zynthian startx[1374]: DEBUG:zynthian_engine_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: Digital_1 => 60
Jan 21 17:40:02 zynthian startx[1374]: DEBUG:zynthian_engine_mixer._send_controller_value: amixer -M -c sndrpihifiberry set 'Digital' 'Playback' 60%,60% unmute
Jan 21 17:40:02 zynthian startx[1374]: INFO:zynthian_gui_admin.stop_rbpi_headphones: STOPPING RBPI HEADPHONES
Jan 21 17:40:02 zynthian startx[1374]: ERROR: PatternManager failed to open file for load /zynthian/zynthian-my-data/sequences/patterns.zynseq
Jan 21 17:40:02 zynthian startx[1374]: INFO:zynthian_gui.osc_init: ZYNTHIAN-UI OSC server running in port 1370
Jan 21 17:40:02 zynthian startx[1374]: INFO:zynthian_gui_layer.load_snapshot: Loading snapshot /zynthian/zynthian-my-data/snapshots/default.zss =>
Jan 21 17:40:02 zynthian startx[1374]: {"index": 0, "layers": [], "clone": [[{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}], [{"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}, {"enabled": 0, "cc": [1, 2, 64, 65, 66, 67, 68]}]], "transpose": [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], "audio_capture": {"LinuxSampler:CH0_": ["system:capture_1", "system:capture_2"], "Tal-Reverb-III-00": ["system:capture_1", "system:capture_2"], "fluidsynth:((l|r)_00|fx_(l|r)_(00|01))": ["system:capture_1", "system:capture_2"], "Dragonfly_Hall_Reverb-00": ["system:capture_1", "system:capture_2"], "MIDI_Velocity_Adjust-00": ["system:capture_1", "system:capture_2"]}, "audio_routing": {"LinuxSampler:CH0_": ["Tal-Reverb-III-00"], "Tal-Reverb-III-00": ["system:playback_1", "system:playback_2"], "fluidsynth:((l|r)_00|fx_(l|r)_(00|01))": ["Dragonfly_Hall_Reverb-00"], "Dragonfly_Hall_Reverb-00": ["system:playback_1", "system:playback_2"], "MIDI_Velocity_Adjust-00": ["system:playback_1", "system:playback_2"]}, "midi_routing": {"LinuxSampler:CH0_": [], "Tal-Reverb-III-00": ["MIDI-OUT", "NET-OUT"], "fluidsynth:((l|r)_00|fx_(l|r)_(00|01))": ["MIDI-OUT", "NET-OUT"], "Dragonfly_Hall_Reverb-00": ["MIDI-OUT", "NET-OUT"], "MIDI_Velocity_Adjust-00": ["fluidsynth"]}, "extended_config": {"MX": null, "LS": null, "JV/Tal-Reverb-III": null, "FS": null, "JV/Dragonfly Hall Reverb": null, "JV/MIDI Velocity Adjust": null}, "midi_profile_state": {"MASTER_BANK_CHANGE_UP": "", "SYS_ENABLED": "0", "MASTER_PROGRAM_CHANGE_DOWN": "", "SINGLE_ACTIVE_CHANNEL": "0", "RTPMIDI_ENABLED": "0", "TOUCHOSC_ENABLED": "0", "PORTS": "DISABLED_IN=\\nENABLED_OUT=ttymidi:MIDI_out\\nENABLED_FB=\\n", "MASTER_CHANNEL": "16", "NETWORK_ENABLED": "0", "FILTER_RULES": "\\n", "PROG_CHANGE_ZS3": "0", "MASTER_PROGRAM_CHANGE_UP": "", "MASTER_BANK_CHANGE_CCNUM": "0", "MASTER_BANK_CHANGE_DOWN": "", "PRESET_PRELOAD_NOTEON": "0", "AUBIONOTES_ENABLED": "0", "FINE_TUNING": "440", "MASTER_PROGRAM_CHANGE_TYPE": "Custom", "FILTER_OUTPUT": "0"}}
Jan 21 17:40:02 zynthian startx[1374]: DEBUG:zynthian_config.get_disabled_midi_in_ports: DISABLED_MIDI_IN = ['']
Jan 21 17:40:02 zynthian startx[1374]: DEBUG:zynthian_config.get_enabled_midi_out_ports: ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
Jan 21 17:40:02 zynthian startx[1374]: DEBUG:zynthian_config.get_enabled_midi_fb_ports: ENABLED_MIDI_FB = ['']
Jan 21 17:40:02 zynthian startx[1374]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Jan 21 17:40:02 zynthian startx[1374]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Jan 21 17:40:02 zynthian startx[1374]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Jan 21 17:40:02 zynthian startx[1374]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Jan 21 17:40:02 zynthian startx[1374]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Jan 21 17:40:02 zynthian startx[1374]: INFO:zynthian_gui_admin.stop_midi_clock: STOPPING MIDI CLOCK
Jan 21 17:40:02 zynthian startx[1374]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN!
Jan 21 17:40:02 zynthian startx[1374]: INFO:zynthian_gui_admin.stop_rtpmidi: STOPPING RTP-MIDI
Jan 21 17:40:03 zynthian startx[1374]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN!
Jan 21 17:40:03 zynthian startx[1374]: INFO:zynthian_gui_admin.stop_qmidinet: STOPPING QMIDINET
Jan 21 17:40:03 zynthian startx[1374]: INFO:zynthian_gui_admin.stop_touchosc2midi: STOPPING touchosc2midi
Jan 21 17:40:03 zynthian startx[1374]: INFO:zynthian_gui_admin.stop_aubionotes: STOPPING aubionotes
Jan 21 17:40:03 zynthian startx[1374]: DEBUG:zynthian_gui_controller.config: ZCTRL 'Layer': 0 (0 -> 8), None, None
Jan 21 17:40:04 zynthian startx[1374]: WARNING:zynthian_autoconnect.cb_jack_xrun: Jack Audio XRUN!
I’m using a HiFiBerry DAC2 Pro in a custom build.
From aplay -L I get:
aplay -l
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 3: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0 [HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0]
Subdevices: 0/1
And here’s a screenshot from patchage:
Any thoughts, tips, ideas, direction and whatnot is very appreciated
