I’ve had a play about with the 2109 staging release, and also earlier sfizz testing branches, but have never actually got sfizz to make a sound. I’ve got all the standard sfz libraries and can get Linux sampler to work as expected. On 2109staging when I set up a layer and choose sfizz as the engine it seems to all load OK, but then when I select a sfz to load it goes straight to the parameters page without any usual pause while the sfz gets loaded.
Is there some clever trick I’m missing?
I’ve tried a fresh SD card and various permutations of updating/going back to stable releases. Everything else works exactly as expected, just not sfizz.
