looks like pins 16,17,18 are shorted. THis could be the problem.
From the schematic pin 18 is the reset pin and is connected to +5V whilst pins 16 and 17 are both used in the Address selection and should both be tied to 0V
That bridge is going to put a dead short on the +5V line which is not good news. Unless of course things have changed but that would be an explanation.
Yes, that seems to be the explanation.
I’m able to solder conventionnal componants, but not SMDs @jofemodo proposed to replace the board (I would return mine also).
The analysis seems right. Brave @guys!! @fschenckel, you could try to remove the tin excess with a solder iron and cupper-mesh. Anyway, if you don’t feel comfortable doing it, i will send you a replacement and kindly ask you to send-back the faulty unit, so i can fix it.
A deft flick with the soldering iron can achieve miracles, or failing that a bit of aerial cable braid can work effectively as a copper braid ( if it’s copper)
Have you anyway of checking that there is no longer a short circuit?
Sorry I was busy with other things. I tried, but I couldn’t manage to remove the solder excess between pin 2/3 and 4.
I’ve seen you sent me a new card ? Thanks a lot !!!
Give me an address where I can send my card back to you.
