I am not able to upload to my code to github due to the pain-in-the-ass error 403. Yes I use a token but git push results in an error. Really frustrating. I tried with Atom and with CLI (linux). Anybody had same experience and solved it?
Hi @Jan
403 error means you do not have permission to access the resource. If a user has been granted permission then this is often caused by incorrect authentication, e.g. wrong password / token value.
Which repository are you trying to push to? It would be rather unusual to grant a new user permission to write to a project repository so I would expect you would:
- Fork the project
- Push changes to your own forked repository
- Submit pull requests against the upstream, core project
If you are trying to commit to the core repository (https://github.com/zynthian/zynthian-ui) then I would expect it to fail - unless @jofemodo has granted you write access - which would seem inappropriate / unorthodox / unusual practice.
Many thanks for answering. Problem solved by removing the fork and forking again. No errors anymore. Just did PR. Sorry for the garbage yesterday in the PR list.
