Not sure this is a problem? - Update log messages
Normally I do the updating from the screen on the zynthian, but today I ran it from webconf.
I noticed some lines and I wonder if they represent a problem.
Like the last line in:
The following packages will be upgraded:
raspberrypi-sys-mods
1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
and in:
Building dependency tree…
Reading state information…
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
and here:
Updating zynthian-help…
./update_zynthian_code.sh: line 86: cd: /zynthian/zynthian-help: No such file or directory
Updated 0 paths from the index
Regenerating engines DB: engines …
INFO:root:Command took 14s
Running Flag Actions from ‘/zynthian/zynthian-sys/scripts/update_zynthian.sh’…
Hi @BertB !
Some update recipe has not been completed in the past days. Please, run this to fix it:
update_zynthian_sys.sh --from 20260901
And ensure a good connection when updating. Preferably avoiding WIFI.
I did as you suggested, but got a lot errors. So I decided to burn the SD with 2026-08-22-zynthianos-vangelis-2608-beta.img again and did the update software there after.
I got a lot of messages like
Regenerating LV2 presets DB: https://butoba.net/homepage/mimid.html` error: failed to open file /zynthian/zynthian-plugins/lv2-presets/pitch_it_up_noise_rvb.ttl/manifest.ttl (Not a directory) `` lilv_world_load_file(): error: Error loading filefile:///zynthian/zynthian-plugins/lv2-presets/pitch_it_up_noise_rvb.ttl/manifest.ttl’ `lilv_world_load_bundle(): error: Error reading file:///zynthian/zynthian-plugins/lv2-presets/pitch_it_up_noise_rvb.ttl/manifest.ttl ` `error: failed to open file /zynthian/zynthian-plugins/lv2-presets/high_pass_transition.ttl/manifest.ttl (Not a directory) ` lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-plugins/lv2-presets/high_pass_transition.ttl/manifest.ttl’ ``
and
Regenerating engines DB: engines ...
lilv_world_load_file(): error: Error loading file `file:///zynthian/zynthian-plugins/lv2-presets/pitch_it_up_noise_rvb.ttl/manifest.ttl'
Is this the latest Beta?:
Those lines look like normal package-manager summary output rather than an error. “1 upgraded” means one installed package changed, while “0 newly installed” and “0 to remove” are just counts. “2 not upgraded” usually means two packages were held back because their dependency changes were not included in that run; it is worth checking the earlier lines for the exact names and any held-package notice. If the command finished with a successful exit status and the Zynthian still boots and behaves normally, I would not treat that summary alone as a problem. I’d only investigate further if the same packages stay back across updates or the log includes an explicit error or failed configuration step.
Thank you for the info. Is this also valid for the messages achter the update suggested by jofemodo?
