Note to CC translator
Hello there, I wonder if I can program a patch that translates incoming Midi notes to cc numbers.
Is this the correct code:
MAP CH#1 NON# 0 : 0 => CH#1CC78 : 0
MAP CH#1 NON# 1 : 1 => CH#1CC78 : 1
MAP CH#1 NON# 2 : 2 => CH#1CC78 : 2
Etc.
I will add a note for all the 127 cc divisions.
Next question is: where do I out this code? I am new to all of this so forgive me my ignorance.
There is a LV2 pllugin called, “MIDI Note to CC”. Does that do what you need?
Ah. Missed that. Will give it a go. Thanks!
What are you trying to do and when do we get to hear the audio … :face_with_monocle:?
I am trying to control the pitch of the Comb Filter of my Octatrack with a keyboard…
That’s smart…
The only thing is that biggest keyboards only have 88 notes, so you’d probably have a step bigger than 1 on your output… but that’s smart…
Edit… I would suggest something like
Cc value = (offset) + (key number * factor)…
So that you could ajust the slope of your curve…
This could be done with the “Scale CC Value” MIDI FX, also available in the latest SD images, so you could create a MIDI-FX wlike this:
=> MIDI Note to CC => Scale CC Value =>
If some of this MIDI FXs are not available on the UI, you should enable them from the webconf’s LV2 panel.
Thanks both! Will give it a go. Another question: I’m looking at adding “enforce scale” to this. But I have noticed that there are only major scales in the options. Is there a way to add custom scales? Could I open up that code somehow and add my own scales? Very new to all of this but excited by all the options!
