Obxd midi drop
hi there playing around with this great synth i get midi drops when i press a key and nothing happens in obxd also the sound quality is varied and fragmented
edit works much better if i turn the voice count down to 4 voices at once.
How did you install it? I haven’t seen it yet
sorry for the late reply. it came with the image file and sounds fat
having problems no audio from this plugin after i installed some beta plugs
Perhaps the same problem as BETA-Tests: more LV2 plugins for MOD-UI?
have applied the fix but still freezing getting this debug:
INFO:root:Bank Selected: Noize Mak3r (8)
DEBUG:root:WS >> stats 4.1 6
DEBUG:root:WS >> mem_load 12.1
DEBUG:root:WS >> disconnect /graph/lv2/Out_R /graph/playback_2
DEBUG:root:WS >> disconnect /graph/midi_capture_1 /graph/lv2/in
DEBUG:root:WS >> disconnect /graph/lv2/Out_L /graph/playback_1
DEBUG:root:WS >> disconnect /graph/serial_midi_in /graph/lv2/in
DEBUG:root:WS >> disconnect /graph/capture_2 /graph/playback_2
DEBUG:root:WS >> disconnect /graph/capture_1 /graph/playback_1
DEBUG:root:WS >> stop
WARNING:root:zynthian_gui.zyncoder_read() => (‘Connection aborted.’, BadStatusLine("’’",))
still getting no sound from obxd and also cannot delete the layer zynthian freezes and a reboot is necessary
DEBUG:root:ZCTRL ‘Bank’: 10 (0 -> 20), None, None
DEBUG:root:WS >> stats 75.2 14
DEBUG:root:WS >> mem_load 9.7
INFO:root:Short Switch 1
DEBUG:root:BACK TO SCREEN => layer
DEBUG:root:ZCTRL ‘Layer’: 0 (0 -> 3), None, None
DEBUG:root:WS >> stats 73.5 14
DEBUG:root:WS >> stats 73.1 14
DEBUG:root:WS >> ping
DEBUG:root:WS << pong
DEBUG:root:WS >> stats 73.0 15
DEBUG:root:WS >> stats 79.6 15
INFO:root:Short Switch 3
DEBUG:root:WS >> disconnect /graph/midi_capture_1 /graph/obxd_wordpress_com/lv2_events_in
DEBUG:root:WS >> disconnect /graph/obxd_wordpress_com/lv2_audio_out_2 /graph/playback_2
DEBUG:root:WS >> disconnect /graph/serial_midi_in /graph/obxd_wordpress_com/lv2_events_in
DEBUG:root:WS >> disconnect /graph/obxd_wordpress_com/lv2_audio_out_1 /graph/playback_1
pstree
systemd─┬─agetty
├─avahi-daemon───avahi-daemon
├─dbus-daemon
├─dhcpcd
├─htpdate
├─jackd───6*[{jackd}]
├─mod-host───4*[{mod-host}]
├─mod-ui───2*[{mod-ui}]
├─sshd───sshd───bash───pstree
├─systemd───(sd-pam)
├─systemd-journal
├─systemd-logind
├─systemd-udevd
├─ttymidi───5*[{ttymidi}]
└─zynthian_webcon───zynthian_webcon
and this if i try to reboot with Obxd in a layer
ERROR:root:zynthian_gui.zyngine_refresh() => (‘Connection aborted.’, BadStatusLine("’’",))
ERROR:root:zynthian_gui.zyngine_refresh() => list.remove(x): x not in list
