Off-Topic: What are you building besides zynthian?
Hi. Assuming you folks chosing zynthian as an option are interested in building things yourself to your liking I would be interested in things you build aside zynthian out of curiosity and for inspiration.
I’ll start. I bought a set of a lonesome amp unit of an Ampeg RB110 bass amplifier together with a speaker from a Marshall guitar amp for 25€ from an eBay derivate locally. I turned it into a bass amp like this:
(P.S. In case you question the output of this user right now: It’ll slow down soon because short holiday over extended weekend ends today)
Thingies are being constructed . . . .
As you can see it is actively checking that the bell tower isn’t moving and what temperature it is..
The previous attempt involved lasers . . .
It listens to clocks and then correlates with a pre recorded sample of the hour strike, generating a n offset from the time with reference to a GPS derived 1kHz 0.1 sec tone and displays the offset on the outer rim of the above display.
Simple really.
It also speaks qmidinet and can sing the hours . . .
Originally an overly complicated, threaded timing engine but there is only so much grunt in a Pi zero 2W and I’ve handed the timing duties over to systemd which seems to want to do everything as root.
We shall see on Sunday . . .
Just finishing off a 3D printer.
A short while ago i finished my 19-inch, 1u rack with dreamDexed on it (8 instances of DX7 on steroids with chorus, delay, reverb, eq, compressor). Also thought that i could run jv880 on it but at this moment i can’t (as most builds only support up to rPI3 and below).
I’m on rPI5 with this due to:
  • possibility to start/stop by NO button with explicit header on board for this purpose
  • ability (in theory) to use boot-manager to boot from USB (connectivity at the front to the right where nowadays a USB-C stick is connected through a panel mounted interface. Time will tell i guess if it will ever become supported)
  • up to 32 voices per TG with room to grow.
for now, it is a rather perfect FM machine and fingers crossed that the authors of virtualJV forks will support rPI5 in the future.
Was about to ask why not MiniDexed but I see that you’re using a fork with better effects.
I am collecting stuff to build a rack mount one too. Yours looks very cool. :heart:
Thx Kirtai. I hope you have fun building yours as well :slight_smile:
I was quite pleased with miniDexed (needless to say) but then dreamDexex came along with that glorious juno-chorus and awesome delay and I must say this is FM nirvana. 8 instances of that classic rhodes sound with chorus and delay is over the top :grinning_face:…
How does it sound precisely…?
I recorded this a while back as a demo. I didn’t dare to put it on my regular SC accunt (last time i did a foolish remix with some well known vocals, i got a life-time ban). From my “burner” account (where i deliberately fronted the FM timbres):
Wow, these are all lovely (as expected).
Here’s another one:Last werkend I restored the old mandoline of the father of my great aunt she gave me some years ago.
All computer tech aside.
This is beautiful :heart:
Hi, this is my “Zast Chord” a self designed chord beased Keytar. I´m a bit proud of it as I did almost all things by myself, designing and building corpus, doing the whole Software, develop circuit diagrams. Except the PCB´s, these were designed by my son based on my diagrams.
You can see it in a small video on youtube
Midi Controller Keytar DIY project by (Zast)
IMG_4403
IMG_44031920×2560 517 KB
sorry, notes in the video are German, but video description is English.
Hope you enjoy !!
Greetings from Austria !!
I recently designed and 3d printed my own pedal board design.
And my next project is modifying a Hothouse Daisy-seed pedal to add midi input and turn it into a quantized looper pedal. It mostly works, but still need to get it to recognize the play/transport to start the correct beat start point.
Next step is to design and order a pcb for the midi input add-on
Pedal building is really fun. I just breadboarded my first circuit.
The circuit is this:
If somebody would ask I would happily tell that I learned reading schematics here first.
Right now I’m refinishing my 90s Ibanez Blazer Strat. I also made a custom pickguard from 3mm birch plywood.
lovely!
This looks very nice! How did you mafe the pickguard? CNC?
No, rather quite manually. Drill, step drill, jigsaw, sanding paper.
I finished it last night:
I’m repairing at the moment…
This may claim to be a Pedal Octave generator but it is in fact a dead short on the -15Volt rail . . .
and this was how power supplies used to look.
    • 15V One centre tap transformer, bridge rectifier, couple of decent size caps ( replaced already) and a 7915 & a 7815…
Both seem fine. . . Chip to be aquired from here. . .
and in answer to the inevitable question…
One of these . . . .
Whats that cruel IC? Something about monophonic stuff? Hope it will work out.
Everything outside 9VDC is out of my intellectual capabilities.
