***Update: For future searchers, I bounced around with the screen working and not (and also interpreting an unrelated problem as a screen problem), but eventually I settled on “Generic HDMI Display” with the following in the webconf’s Config field, and it seems to working fine after multiple reboots and such:
disable_overscan=1
dtoverlay=vc4-kms-v3d
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1024 600 60 3 0 0 0
Hey yall, so I’ve been experimenting with Zynthian boxes with the stuff I’ve got at hand cause I’m broke, and one pretty decent bit of my gear at hand is this touchscreen that I’ve had for quite a while - Product page is here:
Anyways, the screen works beautifully on Zynthian with my Pi3 - I add the lines at the bottom of the above link to /boot/config.txt and it works a charm.
On my Pi4, it boots up a vanilla RaspiOS image without even changing the config.txt, but I get a blank screen in Zynthian.
Anyone got any clues as to what’s happening with the RPi4 and this screen vis-a-vis Zynthian? It should work as a standard HDMI screen, or so the propaganda claims.
One thing I noticed that might be significant: I was following breadcrumbs from other forum posts relating to other issues, and I noticed that although the official product page seems to specify a 60Hz refresh in the hdmi_cvt line, I installed and ran edid-decode in RaspiOS, and according to it, the screen was running at 43ish Hz. 43.x, can’t remember exactly.
I would obviously very much prefer to run Zynthian on my 4 than my 3, but ignorance torments me. I’ve been running the staging image but I’m currently imaging the stable onto another SD card, on the possibility that it’s a bug in the RC. Also going to experiment with that hdmi_cvt as soon as the imaging is done.
But, any ideas from the more experienced among us is greatly appreciated - I took the Pi3 Zynth to practice with my new band yesterday and there many oos and ahs when I showed them just how much stuff was packed in there, even if I can only have a couple of engines running on that mobo.
