ORAM May22: Sf2 in a USB pen
I put some SF2 in a USB pen named SAMPLES in subfolder:
SAMPLES (D:) > soundfonts > sf2
when I would like to load them with Fluidsynt I find then in
USB> SAMPLES but listed 3 times each
sf2 are listed one time for each level of subfolder where are placed
opened a ticket
In Oram, you don’t need to put the SF2 in any special directory structure never more. You can put in the root or in any dir/subdir in the pendrive, with a maximum recursion of 2 levels. Each directory with soundfonts will be shown separately, not mixed.
In the other hand, I just tested and you are right. There is an issue when listing. Each element is shown 3 times. I will fix ASAP.
Regards.
It’s fixed, @piattica. Please update and test.
