Pattern change at end of pattern... and not end of bar?
Dear Zynthians,
I’ve programmed 12 patterns in Zynseq, between which I have to switch frequently. Principally they are running fine and I can also switch between them. My problem is now, that they partly have different length (8 or 12 beats in pattern), i.e. 2 or 3 bars length. So to change a pattern in sync, I always have to wait, till the last bar of the particular pattern was started… and only then I can trigger the pattern change. If I would trigger the pattern change during the 2nd bar of a 3rd bar pattern, the last bar would be omitted…
My question: Is there a way or a “hidden checkbox” to assure, that a pattern is always played completely (as defined in ‘beats per pattern’) before it changes? So I could trigger a pattern change immediately after the 1st note is played… and the pattern would continue for its full length, whether if this is 2 or 3 bars.
(Background: In addition to using Zynseq, I’m playing two keyboards live. Therefore I’m very restricted in triggering the pattern changes…)
System: Oram 2506.1
Thank you in advance for your hints,
Doc MC
Hi @DocMC !
Most , if not all, your requirements are being addressed by the new zymbleton launcher. We hope this will be available for testing very soon, although it could take some time to reach the stable version yet.
All the best,
