i have a cad shematic off the Midi ports wiring and i would like to know if the wiring is ok?
How to upload an image?
The MIDI connections match mine, assuming you are looking into the 5pin din sockets from the plug side, and that was working before it got taken apart for zynthian-1820.local.
i look from the inside…
Blockquote
,and that was working before it got taken apart for zynthian-1820.local.
Blockquote
How is it correct?
from solder side
This is ok now?
Thanks Wyleu
https://wiki.zynthian.org/index.php/Building_a_Zynthian_Box_using_an_official_Kit_v2
So your diagram appears to be right.
Igf you have a multimeter time to start checking connections as per the schematic…
Could you upload pictures of the all in one board and the connectors as they are wired?
