Hi together,
I switched my Pi in my ZynthianV3 pro to a Pi4. Only my hifiberry pro won’t work. When is switch to the normal hifiberry I can hear sound but it’s really crappy. If I switch back to pro in the webconfig anything works but I get no sound
Any idea ?
Rene
                wyleu
                    April 18, 2020,  7:52pm
                  2
              Have you used the same SSDon the two different pi’s?
Perhaps burn a new ssd image and try with that.
              No the sd card was only in the Pi4 (I used an usb audio card before) and now I got the hifiberry (from my V3 set) and I try to get it into my V3 set (in never used the pi3 I will use it for other purposes) … what is strange that I get a sound if I switch to the normal dac in the webconfig but it’s noisy … IF I switch to dac pro  everything seems normal but I get no sound.
Rene
              Now I tried a new image and it’s the same
If I use the Dac+ ADC pro setting in the webconfig Menü I get no sound. If I change the setting to Dac+ ADC I hear noise. Everything else seems to be fine.
Anyone a tip which image to use ? Or how can I test if the berry is not damaged ? The two red leds on the Hi-Fi berry are on.
Best,Rene
                wyleu
                    April 18, 2020,  9:00pm
                  5
              If you’ve got webconfthen things are definitely working. Do you get anything on the ui log in webconf as it starts? Can you log on with an ssh connection?
              I can connect via ssh and also here the ui log:
Rene
              Running without errors but no sound
                wyleu
                    April 18, 2020,  9:11pm
                  9
              Can you get an ssh terminal? Try aplay -l this should display details of the card at least it does on my pi4 adc pro
                wyleu
                    April 18, 2020,  9:22pm
                  11
              So it does seem that the card is there… And alive.
That’s the crazy thing everything seems to works but no sound on the rca jacks. And yes i checked the cable and all that stuff
                wyleu
                    April 18, 2020,  9:27pm
                  14
              But the card did work with a pi3? But it does work when you select hifiberry adc… Can you show the advanced settings from audio including all the options…? You can use zoom on chrome to squeeze it all onto one screen.
What does i2cdetect - y 1 display…?
Power off for 5 minutes and get a cup of tea!
              No … I ordered an official V3 Kit and I had already an Pi4 with an wavshare Display and now I try to fit it together and the Pi3 is in its original packaging and never used
I already used an zynthian with my Pi4 and the wave share display and only USB Midi and USB Sound and it worked well so far … but I love the encoders and want a better latency that what I thought
                le51
                    April 18, 2020,  9:41pm
                  16
              have look with alsamixer if something isn’t disabled/muted.
                wyleu
                    April 18, 2020,  9:44pm
                  17
              The midi ports shouldn’t effect all this. One thing you can to is burn an ssd with raspbian on it and add a mouse and keyboard and see if it works with the card. That does at least test the card if only via alsa.
alsamixer can also play tricks so that may be worth a look
                wyleu
                    April 18, 2020,  9:48pm
                  18
              Hmmmm confusing. Im going for a cup of tea. Basically you want to be sure the card is OK. Get it to play using alsa then try with jack… Everything looks OK from the i2c side…
 wyleu:
systemctl stop zynyhian
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extentX.Org  X Server 1.20.4#1294  SMP Thu Jan 30 13:21:14 GMT 2020 armv7lDebian -- User Support )http://wiki.x.org http://gareus.org/oss/lv2/b_whirl#extended  from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>http://gareus.org/oss/lv2/b_whirl#simple  from <file:///zynthian/zynthian-plugins/lv2/b_whirl.lv2/>http://gareus.org/oss/lv2/b_synth  loaded from <file:///zynthian/zynthian-plugins/lv2/b_synth/>
Thats it
