I thought yesterday that I had somehow killed my Pi5, but it seems that the EEPROM is getting scrambled by booting with the 5-22 image of Oram on SD, BUT I have not tested extensively with a bog standard Raspbian image for very long, so not assuming yet that it’s Oram.
The sequence of events to now, as I have tentatively reconstructed it:
Yesterday:
-attempted to get a frankenzynth setup with my Boss GP-10 and my Pi5
-Pi5 bricks itself, I do not connect it to an event, but LED error codes say EEPROM
-reflash with “Boot from SD” utility image
-attempt to boot Oram again, dies
-at some point yesterday I realize that one of my last two not-in-use SD cards is dead also
-give up and go cook a ton of indian food, my current other obsession is watching videos of Indian women and cooking dishes I have been unable to cook my whole life, it’s amazing
This morning so far:
-reflash with Utility image again
-Boot with Raspbian, works. Did not leave it running long, just verified that Pi is not murdered (yay!)
-write Oram to SD card (working with a single card, but it’s only a couple months old and not heavily used)
-Starts booting, I have a generic HDMI plugged in from doing the bootloader
-after about 30 seconds of what looks like boot activity on the LEDs it locks up, Red light goes on, bricked.
-Reflashed bootloader with utility again
-just booted it with Rasbian again
Other things I can think of, I used raspberry Pi Imager software to write the SD on my Windoze laptop, selecting the Oram image in the custom OS option. Not sure if it checks the write under those conditions, or just for OSes that it has explicitly added. I did, however, check the checksum on the downloaded zip file and it matched.
Might be worth investigating what is entailed in getting Zynthian into that app, by the way? I realize it would just be stable but still, you seen some of the two-bit apps they got in there? We need to gentrify that shit.
I’m gonna run some stress on it under raspbian (I do have active cooling) before I try booting Oram again, but interested in any thoughts. Also gonna pick up some brand new SDs asap just to be sure it’s not that.
