I update my zynthian, after that pianoteq is not running.
I forward the pianoteq ui on my desktop, if I press on the UI keyboard, the sound works correctly.
On my piano, nothing.
I try to run zynthian in console to see if there is debug message, but nothing.
Other engine works ok (not test all, aeolus, linuxsampler, helm works)
I burn image from june 26/06 and update to see, same problem.
Edit: when I press midi keyboard, I have the midi icon on zynthian screen working, same in the midi log, all works except pianoteq does not receive midi signal
I try to run qjackctl, but the software does not show
Anyone have the same problem?
Ok. I had a problem when putting the SD card with licensed version of PT into another Raspi. I tried to add my license but nothing happend because no free license was left…
Like I say, when I forward with ssh, if I press the virtual keyboard on the pianoteq guy, sound works.
Seems to me a midi connection problem.
I will burn again, try pianoteq and see if it’s work before update
Mmmh some progress:
I put pianoteq on channel 1 -> no sound
I clone the channel to channel 2 -> no sound
I add a working engine on channel 2 -> pianoteq make sound.
I can erase the cloning, pianoteq works
I have a stage license.
With only update of pianoteq 6.5.3, pianoteq works correctly.
I make an update, reboot, update again and reboot.
Pianoteq does not make sound, but midi icone blink when I press my midi keyboard.
I try to disable, re-enable audio routing, same problem.
I add an audio effect (mverb) audio works, I can remove the effect, audio continu to works.
Yes, I install the license before the update.
When pianoteq not working, I open an ssh -X to see the UI, moving pianoteq volume does not affect zynthian UI, same if I turn encoder.
When working (after add an audio effect), turning encoder move the volume slider on the pianoteq UI
I’m having exactly the same problem. Pianoteq 6.5.3 installed and working, updated Zynthian, now no sound.
I’m restoring my SD card to an earlier backup when it still worked. Is there a way to see the Zynthian software versions so that we can work out what change affected Pianoteq?
Edit:
I make a modification to have pianoteq work all the time, but don’t know if it’s a correct modification, I send to Jofemodo.
You need to edit the file /zynthian/zynthian-ui/zyngine/zynthian_engine_pianoteq.py like this:
I am suffering Pianoteq not working with the last green Buster nightly after all updates applied. I have reported as issue #70. Pianoteq seems to start without Jack enabled and MIDI routing is missing. I don’t know if that is similar to the issue described here but for me, Pianoteq is broken in the latest build.
