thanks, i download Aruk RC-1 and i test pianoteq 6.5
Donāt forget to update RC-1 for getting the latest version
hi!
cāest bon pour pianoteq, jāai installĆ© rc-1 et jāai reussi a faire les mises a jours et actived la licence pianoteq, seul gros problĆØme maintenant, le zynthian crash trĆ©s souvent (des que je lance un plug-in ou un snapshot) cāest tres embetant car cāest impossible de lāutiliser sur scene
merci pour tous vos conseils!
jāespere que mon zynthian marchera mieu!
hi!
itās good for pianoteq, I installed rc-1 and I managed to update and activate the license pianoteq, only big problem now, the zynthian crash very often (as I launch a plug-in or a snapshot) itās very annoying because itās impossible to use it on stage
Thank you for all your advice!
I hope my zynthian will work better!
You are using a 16Gb SD card. I would go with 32 or better 64 once you have a decent Soundfont collection.
I donāt think itās a problem to have a 16Gb card. Your problem seems the to be related with this issue:
Your zynthian is connected to the network, true?
In such a case, try disconnecting it.
This issue is already solved and we should be releasing a new Aruk āRelease Candidateā by monday or tuesday ⦠i hope
If you are impatient, you could try the last night-build. Itās āgreenā and includes the latest fixes and improvements, but itās not tested yet, so it could fail ā¦
https://os.zynthian.org/2019-05-17-zynthianos-stretch-lite-1.0.0.zip
