I was able to get a crazy performance boost out of Pianoteq on the Odroid N2+ by using a load-balancing hack - basically I dedicated 4 out of 6 CPU cores to Pianoteq.
The reason I’m asking here, is, I’m wondering if this hack can be applied to the Zynthian/Raspberry Pi 4 to give it a similar boost? While I like my Odroid N2+, I like the connections on the Zynthian even better!
On the Odroid N2+/Ubuntu I start Pianoteq like this:
taskset -c 2,3,4,5 ‘Pianoteq 7 STAGE’
On the Zynthian/Raspberry Pi 4 I’m guessing it might look like this:
taskset -c 2,3 ‘Pianoteq 7 STAGE’
I see no discernable difference running pianoteq on a Raspberry Pi with and without this setting. I think Pianoteq’s multicore support already optimises it for the Raspberry Pi. Maybe the Odroid doesn’t support that option. I tried on both RPi3 and RPi4. Shame this isn’t a magic power boost.
I tried with 22050 and 44100 and the behaviour was similar for each test with and without taskset. I am eager to be able to use Pianoteq to its full potential but it is more important to avoid xruns hence it sits at Zynthian default 22050 samples per second.
