Howdy!
In my search for an easier solution to be able to interact with more than just a single sound card at a time I tried Pipewire. I’ve built it from git (apt repo had quite an old version). It took some fiddling with systemd’s service files (pipewire runs as a user service, where everything else runs as a system service).
It appears mostly to work now. With the default ZynADAC card selected in the webconf tool, I can:
- Capture/play to USB headset using UI of Zynthian (as soon as I insert USB headset it shows up in the Sound Capture/Sound Playback menu
- With the addition of
g_audioI can use Zynthian as a USB sound interface connected to my laptop.
Somewhat minor issues:
- Zynthian gets confused by midi ports now - whenever a synth is added - controls do not work until I re-patch it in Patchage properly. Shouldn’t be hard to fix.
- MOD-UI gets confused by names of devices/ports and UI breaks. Looks like it is due to different cards having same name for ports and MOD-UI using only port name as ID, not card+port name. Should be fixable upstream.
- Probably related to #1 - zynthian doesn’t automatically connect added synths to sound output - i have to manually select it in the settings of the layer.
Obvisouly, usage of multiple cards comes with latencies and other potential issues. But at the same time, using pipewire allowed me to quickly connect USB headphones I had lying around. And I hope I will figure out Bluetooth soon too. Recording digital audio via USB-C sounds like a good option to have (delay there quite significant, so it is not good use for live performance).
What yalls opinion about that setup? Is it something Zynthian might adopt? If so - I could try resolve issues in Zynthian and MOD-UI around port names. But I wanted to make sure it is worth the time.
