I’m a newish user myself but I notice that you have:
Wifi: hotspot
IP: 169.254.132.65 192.168.50.1
Are you wanting to connect to it as a WiFi Hotspot (which your webconfig page shows is set) or via your local network - with the Pi connected via wired Ethernet or with the Pi WiFi set to “on” in webconfig ?
As I say I don’t know for sure, but maybe the WiFi setting got changed accidentally when you changed to the PiSound perhaps?
Sorry if this is not relevant, but thought I’d mention it in case it is.
The error message shows when Zynthian could not start. This is most likely due to JACK failing to start. You could look at the service journal output with:
journalctl -ru jack2
This displays the service log in reverse order (newest at top). (‘q’ to quit).
– Logs begin at Wed 2020-05-27 08:29:07 BST, end at Wed 2020-05-27 08:36:14 BST
May 27 08:36:07 zynthian systemd[1]: jack2.service: Scheduled restart job, resta
May 27 08:36:07 zynthian systemd[1]: jack2.service: Service RestartSec=1s expire
May 27 08:36:05 zynthian systemd[1]: jack2.service: Failed with result 'exit-cod
May 27 08:36:05 zynthian systemd[1]: jack2.service: Main process exited, code=ex
May 27 08:36:05 zynthian jackd[3919]: Failed to open server
May 27 08:36:05 zynthian jackd[3919]: creating alsa driver … hw:0|hw:0|256|2|4
May 27 08:36:05 zynthian jackd[3919]: self-connect-mode is "Don’t restrict self
May 27 08:36:05 zynthian jackd[3919]: JACK server starting in realtime mode with
May 27 08:36:05 zynthian jackd[3919]: under certain conditions; see the file COP
May 27 08:36:05 zynthian jackd[3919]: This is free software, and you are welcome
May 27 08:36:05 zynthian jackd[3919]: jackdmp comes with ABSOLUTELY NO WARRANTY
May 27 08:36:05 zynthian jackd[3919]: Copyright 2016-2019 Filipe Coelho.
May 27 08:36:05 zynthian jackd[3919]: Copyright 2004-2016 Grame.
May 27 08:36:05 zynthian jackd[3919]: Copyright 2001-2005 Paul Davis and others.
May 27 08:36:05 zynthian jackd[3919]: jackdmp 1.9.14
May 27 08:36:05 zynthian systemd[1]: Started JACK2 Audio Server.
May 27 08:36:05 zynthian systemd[1]: Stopped JACK2 Audio Server.
May 27 08:35:43 zynthian systemd[1]: jack2.service: Scheduled restart job, resta
May 27 08:35:43 zynthian systemd[1]: jack2.service: Service RestartSec=1s expire
May 27 08:35:42 zynthian systemd[1]: jack2.service: Failed with result 'exit-cod
May 27 08:35:42 zynthian systemd[1]: jack2.service: Main process exited, code=ex
May 27 08:35:42 zynthian jackd[3705]: Failed to open server
It seems to works just for some seconds.
Before, it was alternating between the boot screen and the error screen.
Now it’s alternating between the good zynthian screen, the boot screen and the error screen.
The number of digits in each pair of brackets appears to be missing the last character perhaps?
If that is a copy and paste problem (missing character) then does it not seem that “zynthian-data: master” hasn’t actually changed in the update you did?
Was there an error perhaps when you did the update, you didn’t see?
