Is it possible to insert the following into Fluidsynth:
Poly mono control
Velocity control
Portamento control (Legato priority last note)
Best regards
Zoran
Poly mono control
Velocity control
Best regards
Zoran
Poly/Mono & Portamento are already implemented. If you have a updated SD image, it should work.
Regarding velocity control, i think “expression” should be the CC you need …
We got involved in a little discussion about expression and it’s implementation in the level discussion, which covered all kinds of interesting sound processing via polyphony …
Sf2,polyphone, tones & levels
