I was wondering whether it possible to prepare an SD card with the latest stable release using an Android device as explained in this link.
The reason I am looking to use the latest release is that I am getting an “ERROR” screen whenever I try to switch off the device. Since updating did not solve the issue, I got an new SD card to try the new release. However, I do not have an SD card reader in my computer and the only way to prepare the card is by using my phone.
TBH I don’t see a way to upgrade unless you can wite an image to the SD Card as there is no sane way to upgrade from the former stable release.
If you are using a staging-2210 the update should work, I have tested it several times. You should enable Advance View in Software-Repositories and choose the testing repos.
I can access it through an Android device. There are apps that allow you to prepare an SD card using an Android device. My question therefore was whether I can use these instead of the proposed Windows software.
To copy an image into an SD card you need to see a device in /dev -something like /dev/sdX where is X in a,b,…z) where the SD card is detected.
First you’d need a terminal, that is available. Then you could use dd which I think it’s already installed. Finally you’d need to copy the zynthian image into the andriod filesystem, doable too.
If you do, then you can simply use a terminal and dd to copy the image, but I have to recognise that even for me it’s a little cumbersome.
There is an Android app called “Pi SD Card Imager” which is designed for this purpose but the reviews suggest it does not work with custom images (like ZynthianOS). It won’t work on my Chromebook because the SD card is not exposed as a raw device to the android application (probably due to the emulation layer). You would need to download the image to your Android device’s internal storage (requiring over 7GB spare capacity on your Android device’s internal storage) then use the custom image option to write this to a micro SD.
[Edit] I just confirmed that Pi SD Card Imager fails to write custom OS with my Android phone (Moto G5) but then I read that it requires the Android device to be rooted to write custom OS. If your Android device is rooted then you may have success. It is a bit fiddly:
Install Pi SD Card Imager on Android device
Download Zynthian OS image to a location the Android device can access
Run Pi SD Card Imager
From “…” menu select “Format SD”
Select SD Card from drip down
From “…” menu select “Format”
Confirm
Back to main screen
From “…” menu select Custom OS
From “hamburger” menu select storage device then navigate to select zynthian OS image
From “…” menu, select “Choose SD or USB” (I couldn’t select by clicking on the icon)
From “hamburger” menu select SD card (by name)
“CREATE NEW FOLDER” or use existing empty folder to mount SD
“ALLOW” access
“Write to SD”
At this point it fails if the Android device is not rooted. I have written one of the built-in images using the app (although not tested it).
I finally managed to get a card reader at a reasonable price (EUR15, after browsing every possible store locally, and having people trying to sell me devices for EUR110). However, when I tried to prepare the SD card using the Etcher software, the process failed. Now my computer cannot even recognize the SD card in the card reader. Any ideas?
Just got a breakthrough. Seems that the port of the SD card reader was finicky. I used the other port on the reader and was able to prepare the SD card. Off to my Zynthian now!
