Problem with calibrate my touchscreen
Hello!!.
I have this touchscreen 20.31€ 78% de DESCUENTO|Pantalla táctil LCD IPS TFT de 7 pulgadas, Monitor de 1024x600 píxeles RGB, USB, HDMI, compatible con Raspberry Pi 4B 3B + AIDA64, novedad| | - AliExpress.
Is a panel with 1024x600 inchs and when I Calibrate the touchscreen the middle touch it’s ok, and the top left touch it’s ok again, but when I try to calibrate the last one, Bottom Right touch, the driver don´t recognize this part of my touchscreen. I test with other OS (Windows10) and the touchscreen working correctly, but in Zynthian don´t work well the driver. Please, could you help me?
I confirm that with the new Update, the problem It´s Fixed. thank you for the quickly support.
Best regards,
JMY
