Hello everyone.
I am new here .
I don’t know English, I use a translator. Sorry for the mistakes.
I’m having a problem with one of my MIDI controllers when I try to trigger the pads on the ZynSeq:
I manage to map a pad or key on the controller to a ZynSeq pad, but then it doesn’t work.
This controller assigns vel:64 to NoteOff.
When I use it to play there is no problem.
(With other controllers I have no problem with this. But I see that they assign vel:0 to NoteOff.)
Will this be the problem? Any possible solution?
Ah! I think I have it. It may not be the keyboard but the MIDI channel / active chain. There seems to be an issue that the MIDI signal sent to the sequencer is influenced by the active chain if Omni/Stage Mode is enabled so the active chain’s MIDI channel is used, not the external controller’s MIDI channel. This is a bug. Will you please validate that this is what is happening for you?
