thank you very much… yesterday the zynthian arrived…
Now it is ready!
BUT! it dont work correctly with the display…
I don’t know the correct settings for it.
With hdmi waveshare display it boots and the controllers and all is working.
Then i switched to the internal display over webinterface…
The piscreen1 works sometimes after switching…
But not after a reboot.
After rebooting with piscreen settings the system hung…
I spent ours and ours now, but not able to find a solution.
Or you can do it from command line. In such a case, you have to connect your Zynthian Box to your local network (router) and login using a remote terminal (ssh) from your computer:
i had done the update over the gui before…
now i called the update over ssh…
no change in the strange behavior.
Same effect as i described.
Also tried with a different RPI3 - change had no effect…
also tried with another sd card - no effect…
drives me crazy!
Any other idea?
Perhaps the display is damaged?
But why should it work with the workaround i found out?
Are you using a fresh Gorgona Edge image? Is your Zynthian connected to your router?
Please, send me some photo of how did you connect your display to the ribbon cable …
The correct driver is “PiScreen2” … PiScreen1 is an older one and wont work with your display!
You don’t need to reboot or unplug/plug the cable after configuring the display, as the configuration system alreasy reboot the system after saving the config.
yes i am using the brandnew gorgona image…
The Zynthian is connected to the internet via a switch and a router.
with piscreen2 i got no output…
I only have to unplug and disconnect because the booting hangs and dont go to the end.
It hangs on the zynthian splash screen in this case…
OK PiScreen2 - strange…
Perhaps i had connected something wrong.
Best regards
Martin
offtopic: I never got an email from the forum when you reply to me…
Regarding the mounting … are the screen separator too long?
I think i make an error and the separators i sent are 0.5 mm too long. We have 2 options to solve it:
i got my Zynthian today as well, and i got it assembled without larger difficulties The instructions were very clear and everything fitted nicely.
After ‘etchin’ the SD-Card image it booted, i can access it via ssh and i followed the update instructions mentioned above whicht helped to get the screen working.
But unfortunately the Zynthian display shows an error message after the inital Zynthian splash screen.
Please see attached photos for my wiring and the mentioned error screen, additionally i included a screenshot of gpio readall
