I have forgot that feature hahaha
Thank you @jofemodo, I will investigate that when I’ll be back home (after 15 days of containment at my girlfriend’s home -frankly not that bad - but far from my SBC and my musical gear).
Hey @le51 I am the creator and maintainer of CustomPiOS which is the system used to build Zynthian’s OS (we call those scripts ZynthianOS).
CustomPiOS supports changing the base image that the build is based off which was intentionally done so you can support other SBCs.
I haven’t had much cooperation maintaining other devices and would welcome and help if I can getting other machines to support Zynthian and other distro builds.
Also I see you mentioned armbian, there is an armbian build variant. But it needs more love and caring. There is an “ubuntu base image” switch too, which I started adding to the devel branch of CustomPiOS.
- Zynthian uses ZynthianOS: GitHub - zynthian/ZynthianOS: Disto to build a Zynthian image ready to ship
- Yes but you could adapt it to any base image, we use rasbian because it has non-free drivers we want to have available.
- Yes, we use Jenkins that executes a docker instance of CustomPiOS
- Yes, there is a nightly build. Best method is to have Jenkins that can run docker commands, from there just follow the instructions. I can throw in our jenkins shell script:
#!/bin/dash
cd /home/guysoft
sudo ./docker_rebuild.sh
sudo ./build_zynthianos.sh
docker_rebuild.sh
#!/bin/bash
set -x
pushd /home/guysoft/ZynthianOS/src
docker pull guysoft/custompios:devel
docker-compose stop
docker-compose rm -f
docker-compose up -d
popd
build_zynthianos
#!/bin/bash -x
# Clean Jenkins log => Sometimes it grows too much ...
rm -rf /var/log/jenkins/*
if [ -z ${BUILDS_DIR} ]; then
export BUILDS_DIR="/home/guysoft/builds"
fi
if [ -z ${ZYNTHIAN_FORCE_RBPI_VERSION} ]; then
export ZYNTHIAN_FORCE_RBPI_VERSION="Raspberry Pi 3 Model B Plus"
fi
# Store Start Timestamp
START_TIMESTAMP=$(date --rfc-3339=date)
# Copy soundfonts to CustomPiOS filesystem
rsync -rlv --size-only /home/txino/soundfonts ./src/modules/zynthianos/filesystem
# Delete README files from filesystem
rm -f ./src/modules/zynthianos/filesystem/*/README
rm -f ./src/modules/zynthianos/filesystem/home/*/README
# Create build info file with useful info about the build ...
build_info_fpath=./src/modules/zynthianos/filesystem/home/pi/build_info.txt
echo -e "ZynthianOS: Built on os.zynthian.org\n" > $build_info_fpath
echo -e "Timestamp: $START_TIMESTAMP\n" >> $build_info_fpath
echo -e "Optimized: $ZYNTHIAN_FORCE_RBPI_VERSION\n" >> $build_info_fpath
# Build ZynthianOS
sudo /usr/local/bin/zynthianos
# Post-build proccess
pushd ./src/workspace
# Copy Soundfonts to SD image
#losetup
#cp -a /home/txino/soundfonts/sfz/* ./mount/zynthian/zynthian-data/soundfonts/sfz
# Get ZIP filename
ZIPNAME=$(ls *.zip | head -n 1)
if [ ${ZIPNAME} ]; then
# Calculate new filename
NEW_ZIPNAME=${START_TIMESTAMP}${ZIPNAME:10:100}
# Rename zip file
mv ${ZIPNAME} ${NEW_ZIPNAME}
# Rename img file inside zip file
IMGNAME=${ZIPNAME:0:-3}img
NEW_IMGNAME=${NEW_ZIPNAME:0:-3}img
sed -i "s/${IMGNAME}/${NEW_IMGNAME}/g" ${NEW_ZIPNAME}
# Calculate MD5-sum file
md5sum ${NEW_ZIPNAME} > ${NEW_ZIPNAME}.md5
# Move zip & MD5-sum files to "builds" directory
mv -v ${NEW_ZIPNAME} ${BUILDS_DIR}
mv -v ${NEW_ZIPNAME}.md5 ${BUILDS_DIR}
fi
popd
popd
Hi Guy, thank you for your input.
I’m now back at my home.
Firstly, I will try to build zynthian step by step on the nanopi m4v2 itself (wich is much more powerfull than the nanoPiK1plus, with its Nvme HD and 4 Go ram), starting from the armbian server image and using the script
setup_system_rbpi_raspbian_lite_buster.sh
Then, if I’am successfull with this (<=> having an armbian adapted setup_system script), I’ll go further in automation (as I’m pretty new with these docker/jenkins stuff).
Sorry to revive this thread, but have you got anywhere?
I am also thinking on building zynthian over armbian for H3 (Orange Pi PC plus).
Are there any Raspbian-specific dependencies that would otherwise be a bottleneck in building zynthian for H3?
I think this isn’t a very straightforward process, but are there any hints/tips for porting zynthian to other platforms?
Hi @xanderz ,
it’s not an easy task. A full ZynthianOs is a bunch of Gb of a “working” software stack (raspi base system wich is based on debian, with the help of kxstudio and maybe other deb repo and of course all the apps that are build from source -see here- with everything encapsulated in Zynthian sofware/UI/hardware).
Maybe this could help:
Got it.
But is there anyone around that tried running zynthian on H3 with 1GB of RAM(or at least, similar hardware)?
I honestly am afraid of spending lots of hours in porting zynthian and then finding out that the hardware is crap and has lots of lag.
I would have bought a RPi 3/4 if I can damn find at least one in any store in Romania(chip shortage issue maybe?).
Digikey, Mouser and such have tens of weeks lead time…
@xanderz you will have hours of toil to port Zynthian to any other platform with no guarantee it will work properly, if at all. I would not even attempt this unless I had the device and lots of time. 1 GB RAM will be a limiting factor. It can really slow down compilation of code. Chip shortage is a real pain affecting almost all technology delivery but if you get a chance, try to get a Raspberry Pi 4 (2GB or larger). You can sometimes find vendors selling their own kits with larger RAM units, PSU, etc. for a good deal. Keep looking my friend .
I agree with @riban
It took me hours (days ?) to build Zynthian on a H5 board equiped with 2Gb ram and 32Gb of emmc drive.
I achieved to make the dac to work (with pcm5102 chip) and the UI to get up. But most of the software instruments where buggy (100% of cpu load, interface freezing, application crash and so on).
The very first thing you should test is the audio ability.
Start with whatever debian based os works for the board. add the kxstudio repos and install something like setBfree or Fluidsynth. Get Jackd running with whatever alsa device is reported, plug it all together with qjackctl, patchage or something and give it a quick run with a usb midi keyboard. I’ve done this sort.of thing on the pinephone or pinebook pro and it will give you a good view of how it will manage with audio output capability, or xruns and stuff.
IF it works really well then try git cloning all the zynthian stuff on top of the build and see what runs. I also did that with Fedora on a laptop before I got a zynthian kit. It’s terrible but.can get you off the ground.
@riban There are very few resellers, and they are selling really overpriced raspberry pi4s for which money I can easily buy a used Thinkpad with an i5/i7 that can easily run any vst.
But this defeats the whole purpose of having a fully-embedded, small form factor synthesizer.
@Baggypants thanks for the tips, will try that today and see how it goes. Maybe also patch the kernel to use the RT patch and see if it helps in any way.
I’m planning to get the most barebone armbian image and work from there.
I think I will scrap the on-board compilation idea and go with docker as I have more than decent computer to handle the build
Realtime kernel is not advantageous and generally gives worse performance. Low latency kernel is important.
@Baggypants so I just installed fluidsynth and got a relatively lightweight soundfont(~12MB).
I am really impressed with the performance. The lag is quite small(I can notice it, but it’s very small indeed).
Owning a Korg PA1X they are very close in terms of responsiveness.
No xruns displayed, but I might want to load it a bit more with a beefier soundfont.
Excellent news! Mess with the jack settings to get lower latency with potentially more xruns. There will be a sweet spot somewhere.
For a beefier synth try ob-xd and one of the massive pads. You will need to launch it using jalv. Beyond that there’s Surge synth.
Ok, so I went headfirst and try building zynthian on my orange pi. Removed some lines from the install scripts which were raspberry-specific(wiring being one of them).
Script ran fine, but did not manage to see any ouput because I left it running and when I came back to it, it already finished and closed the screen made when I launched the setup script. So I guess, if there are no logs saved, I can’t know what went wrong.
Anyways, rebooted the board, and hdmi displayed the armbian boot sequence then an error about /sda/fdb1 or something like that. I guess, for the moment, since I don’t have a SPI screen on-hand, I will try to use HDMI (found out on the forum that it is possible to do so).
I wanted to change the hardware settings using the webconf tool, but it doesn’t work. Tried manually launching it with the script and I get all sorts of errors of missing modules in python. So I’m manually installing them, but this is clear that the setup script failed one way or another.
Nevertheless, here’s a snip over ssh. Looks like some parts of zynthian are actually configured:
Ok, so upon further investigation and manually installing python modules, I can’t seem to be able to install patchage, nor find it on pypi.org
patchage isn’t python to my knowledge it’s a system based install
sudo apt install patchage or similar.
http://drobilla.net/software/patchage.html
The vanilla start up zynthian settings in this sort of world for starting up is probably everything in dummies with hdmi screen selected.
A Zynthian kit itself wont start if it can’t detect the audio device selected.
Yes, you are indeed correct. I just quickly found out after doing a bit of google search
I can now access the webconf.
Can’t see any MIDI log though. The midi keyboard is listed in aconnect and I also used it by playing with fluidsynth.
I can see the zynthian splashscreen for a few seconds, and then the error splashscreen.
Again, is there any log file that zynthian outputs when launching? Maybe that gives me a clue.
Edit: Will change the audio to dummy, just in case
Edit2: No, it did not help.
I just found out on the forum I can get some logs using journalctl.
Here is mine:
– Logs begin at Sat 2021-10-30 14:25:09 UTC, end at Sat 2021-10-30 14:28:40 UTC. –
Oct 30 14:25:18 zynthian systemd[1]: Started Zynthian User Interface.
Oct 30 14:25:19 zynthian startx[1696]: X.Org X Server 1.20.4
Oct 30 14:25:19 zynthian startx[1696]: X Protocol Version 11, Revision 0
Oct 30 14:25:19 zynthian startx[1696]: Build Operating System: Linux 4.14.204-odroidxu4 armv7l Debian
Oct 30 14:25:19 zynthian startx[1696]: Current Operating System: Linux zynthian 5.10.60-sunxi #21.08.2 SMP Tue Sep 14 16:28:44 UTC 2021 armv7l
Oct 30 14:25:19 zynthian startx[1696]: Kernel command line: root=UUID=bca5d7e8-0c39-4a40-a387-03b25de4216d rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart=5
Oct 30 14:25:19 zynthian startx[1696]: Build Date: 25 December 2020 07:01:51PM
Oct 30 14:25:19 zynthian startx[1696]: xorg-server-rockchip 2:1.20.3-3armbian1 (Debian -- User Support)
Oct 30 14:25:19 zynthian startx[1696]: Current version of pixman: 0.36.0
Oct 30 14:25:19 zynthian startx[1696]: Before reporting problems, check http://wiki.x.org
Oct 30 14:25:19 zynthian startx[1696]: to make sure that you have the latest version.
Oct 30 14:25:19 zynthian startx[1696]: Markers: (–) probed, (**) from config file, (==) default setting,
Oct 30 14:25:19 zynthian startx[1696]: (++) from command line, (!!) notice, (II) informational,
Oct 30 14:25:19 zynthian startx[1696]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Oct 30 14:25:19 zynthian startx[1696]: (==) Log file: “/var/log/Xorg.0.log”, Time: Sat Oct 30 14:25:19 2021
Oct 30 14:25:19 zynthian startx[1696]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Oct 30 14:25:19 zynthian startx[1696]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Oct 30 14:25:24 zynthian startx[1696]: ./zynthian.sh: line 55: /sys/class/backlight/*/bl_power: No such file or directory
Oct 30 14:25:24 zynthian startx[1696]: PNG file: /zynthian/config/img/fb_zynthian_boot.png - Application must supply a known background gamma
Oct 30 14:25:24 zynthian startx[1696]: /zynthian/config/img/fb_zynthian_boot.png is 1024x600 PNG image, color type GRAY, 8 bit, file gamma 0.4546
Oct 30 14:25:24 zynthian startx[1696]: Zooming image by 100%…done
Oct 30 14:25:24 zynthian startx[1696]: Merging…didn’t find evidence of prior run.
Oct 30 14:25:24 zynthian startx[1696]: done
Oct 30 14:25:24 zynthian startx[1696]: Building XImage…done
Oct 30 14:25:39 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:25:39 zynthian startx[1696]: CheckRes error
Oct 30 14:25:39 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:25:39 zynthian startx[1696]: Cannot open zynthstep client
Oct 30 14:25:39 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:25:39 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:25:39 zynthian startx[1696]: libzynseq failed to start jack client: 33
Oct 30 14:25:54 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:25:54 zynthian startx[1696]: CheckRes error
Oct 30 14:25:54 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:25:54 zynthian startx[1696]: Cannot open jackpeak client
Oct 30 14:25:54 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:25:54 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:25:54 zynthian startx[1696]: libjackpeak failed to start jack client: 33
Oct 30 14:25:54 zynthian startx[1696]: New instance of zynseq
Oct 30 14:25:54 zynthian startx[1696]: zynseq initialising as zynthstep
Oct 30 14:25:58 zynthian startx[1696]: convert-im6.q16: unable to read fonthelvetica' @ error/annotate.c/RenderFreetype/1338. Oct 30 14:25:58 zynthian startx[1696]: convert-im6.q16: non-conforming drawing primitive definition
text’ @ error/draw.c/RenderMVGContent/4301.
Oct 30 14:25:58 zynthian startx[1696]: /zynthian/config/img/fb_zynthian_error_ip.png is 1024x600 PNG image, color type RGB_ALPHA, 8 bit
Oct 30 14:25:58 zynthian startx[1696]: Zooming image by 100%…done
Oct 30 14:25:58 zynthian startx[1696]: Merging…done
Oct 30 14:25:58 zynthian startx[1696]: Building XImage…done
Oct 30 14:26:14 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:26:14 zynthian startx[1696]: CheckRes error
Oct 30 14:26:14 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:26:14 zynthian startx[1696]: Cannot open zynthstep client
Oct 30 14:26:14 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:26:14 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:26:14 zynthian startx[1696]: libzynseq failed to start jack client: 33
Oct 30 14:26:29 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:26:29 zynthian startx[1696]: CheckRes error
Oct 30 14:26:29 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:26:29 zynthian startx[1696]: Cannot open jackpeak client
Oct 30 14:26:29 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:26:29 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:26:29 zynthian startx[1696]: libjackpeak failed to start jack client: 33
Oct 30 14:26:29 zynthian startx[1696]: New instance of zynseq
Oct 30 14:26:29 zynthian startx[1696]: zynseq initialising as zynthstep
Oct 30 14:26:31 zynthian startx[1696]: convert-im6.q16: unable to read fonthelvetica' @ error/annotate.c/RenderFreetype/1338. Oct 30 14:26:31 zynthian startx[1696]: convert-im6.q16: non-conforming drawing primitive definition
Oct 30 14:26:31 zynthian startx[1696]: /zynthian/config/img/fb_zynthian_error_ip.png is 1024x600 PNG image, color type RGB_ALPHA, 8 bit
Oct 30 14:26:31 zynthian startx[1696]: Zooming image by 100%…done
Oct 30 14:26:31 zynthian startx[1696]: Merging…done
Oct 30 14:26:31 zynthian startx[1696]: Building XImage…done
Oct 30 14:26:49 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:26:49 zynthian startx[1696]: CheckRes error
Oct 30 14:26:49 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:26:49 zynthian startx[1696]: Cannot open zynthstep client
Oct 30 14:26:49 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:26:49 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:26:49 zynthian startx[1696]: libzynseq failed to start jack client: 33
Oct 30 14:27:04 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:27:04 zynthian startx[1696]: CheckRes error
Oct 30 14:27:04 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:27:04 zynthian startx[1696]: Cannot open jackpeak client
Oct 30 14:27:04 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:27:04 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:27:04 zynthian startx[1696]: libjackpeak failed to start jack client: 33
Oct 30 14:27:04 zynthian startx[1696]: New instance of zynseq
Oct 30 14:27:04 zynthian startx[1696]: zynseq initialising as zynthstep
Oct 30 14:27:06 zynthian startx[1696]: convert-im6.q16: unable to read fonthelvetica' @ error/annotate.c/RenderFreetype/1338. Oct 30 14:27:06 zynthian startx[1696]: convert-im6.q16: non-conforming drawing primitive definition
Oct 30 14:27:06 zynthian startx[1696]: /zynthian/config/img/fb_zynthian_error_ip.png is 1024x600 PNG image, color type RGB_ALPHA, 8 bit
Oct 30 14:27:06 zynthian startx[1696]: Zooming image by 100%…done
Oct 30 14:27:06 zynthian startx[1696]: Merging…done
Oct 30 14:27:06 zynthian startx[1696]: Building XImage…done
Oct 30 14:27:24 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:27:24 zynthian startx[1696]: CheckRes error
Oct 30 14:27:24 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:27:24 zynthian startx[1696]: Cannot open zynthstep client
Oct 30 14:27:24 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:27:24 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:27:24 zynthian startx[1696]: libzynseq failed to start jack client: 33
Oct 30 14:27:39 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:27:39 zynthian startx[1696]: CheckRes error
Oct 30 14:27:39 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:27:39 zynthian startx[1696]: Cannot open jackpeak client
Oct 30 14:27:39 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:27:39 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:27:39 zynthian startx[1696]: libjackpeak failed to start jack client: 33
Oct 30 14:27:39 zynthian startx[1696]: New instance of zynseq
Oct 30 14:27:39 zynthian startx[1696]: zynseq initialising as zynthstep
Oct 30 14:27:41 zynthian startx[1696]: convert-im6.q16: unable to read fonthelvetica' @ error/annotate.c/RenderFreetype/1338. Oct 30 14:27:41 zynthian startx[1696]: convert-im6.q16: non-conforming drawing primitive definition
Oct 30 14:27:41 zynthian startx[1696]: /zynthian/config/img/fb_zynthian_error_ip.png is 1024x600 PNG image, color type RGB_ALPHA, 8 bit
Oct 30 14:27:41 zynthian startx[1696]: Zooming image by 100%…done
Oct 30 14:27:41 zynthian startx[1696]: Merging…done
Oct 30 14:27:41 zynthian startx[1696]: Building XImage…done
Oct 30 14:27:59 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:27:59 zynthian startx[1696]: CheckRes error
Oct 30 14:27:59 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:27:59 zynthian startx[1696]: Cannot open zynthstep client
Oct 30 14:27:59 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:27:59 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:27:59 zynthian startx[1696]: libzynseq failed to start jack client: 33
Oct 30 14:28:14 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:28:14 zynthian startx[1696]: CheckRes error
Oct 30 14:28:14 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:28:14 zynthian startx[1696]: Cannot open jackpeak client
Oct 30 14:28:14 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:28:14 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:28:14 zynthian startx[1696]: libjackpeak failed to start jack client: 33
Oct 30 14:28:14 zynthian startx[1696]: New instance of zynseq
Oct 30 14:28:14 zynthian startx[1696]: zynseq initialising as zynthstep
Oct 30 14:28:16 zynthian startx[1696]: convert-im6.q16: unable to read fonthelvetica' @ error/annotate.c/RenderFreetype/1338. Oct 30 14:28:16 zynthian startx[1696]: convert-im6.q16: non-conforming drawing primitive definition
Oct 30 14:28:16 zynthian startx[1696]: /zynthian/config/img/fb_zynthian_error_ip.png is 1024x600 PNG image, color type RGB_ALPHA, 8 bit
Oct 30 14:28:16 zynthian startx[1696]: Zooming image by 100%…done
Oct 30 14:28:16 zynthian startx[1696]: Merging…done
Oct 30 14:28:16 zynthian startx[1696]: Building XImage…done
Oct 30 14:28:34 zynthian startx[1696]: Cannot read socket fd = 7 err = Success
Oct 30 14:28:34 zynthian startx[1696]: CheckRes error
Oct 30 14:28:34 zynthian startx[1696]: JackSocketClientChannel read fail
Oct 30 14:28:34 zynthian startx[1696]: Cannot open zynthstep client
Oct 30 14:28:34 zynthian startx[1696]: JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
Oct 30 14:28:34 zynthian startx[1696]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Oct 30 14:28:34 zynthian startx[1696]: libzynseq failed to start jack client: 33
Basically jack ain’t starting
