Could anybody with the new B+ model please test, if wlan0 shows up?
In my case, ifconfig only shows eth0 and lo.
I need to know, if I have to return the raspbi or if I have to wait for a software update.
Just a fast look at my RPi3B+:
root@teq:~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.76.176.156 netmask 255.255.255.240 broadcast 192.76.176.158
inet6 fe80::ba27:ebff:fe6c:f50 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:6c:0f:50 txqueuelen 1000 (Ethernet)
RX packets 79 bytes 11364 (11.0 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 72 bytes 12160 (11.8 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 2 bytes 78 (78.0 B)
TX packets 2 bytes 78 (78.0 B)
root@teq:~# ifconfig wlan0
wlan0: error fetching interface information: Device not found
Had to comment out this line in /boot/config.txt:
dtoverlay=pi3-disable-wifi
… but did not help. Perhaps because:
root@teq:~# dmesg | grep brcmfmac
[ 2.909644] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 2.914115] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdio.bin for chip 0x004345(17221) rev 0x000006
[ 2.914355] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.bin failed with error -2
[ 2.914577] usbcore: registered new interface driver brcmfmac
[ 4.010904] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 5.020971] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
Ok, only way I found to got it working (link):
wget https://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-brcm80211_20161130-3+rpt3_all.deb
sudo dpkg -i firmware-brcm80211_20161130-3+rpt3_all.deb
Regards, Holger
What image are you using?
@C0d3man, have you tried a “rpi-update” ?
Yes, rpi-update won’t help
It is not a Zynthian. I made this in February, a Minibian based small setup for a Pianoteq-only.
I can confirm, that a rpi-update doesn’t help.
Could you add his fix?
I don’t want to apply it myself, because i want to keep a valid test base.
OK! Let me try it and i will add it …
