Is anybody else experiencing the issue that “Restart UI” or “Reboot” doesn’t work anymore with the latest update?
zynthian-gui returns with status 139 at sys.exit.
If i am not the only one, I will create a github bug.
I can confirm. It’s happening to me too.
But not always … there is a “random” vector.
From our wonderful webconf’s UI log
May 04 00:48:13 zynthian startx[3052]: INFO:root:Looooooooong Switch 3
May 04 00:48:15 zynthian startx[3052]: INFO:root:Short Switch 3
May 04 00:48:15 zynthian startx[3052]: INFO:root:callback None
May 04 00:48:15 zynthian startx[3052]: INFO:root:POWER OFF
May 04 00:48:15 zynthian startx[3052]: INFO:root:Saving snapshot /zynthian/zynthian-my-data/snapshots/last_state.zss =>
May 04 00:48:15 zynthian startx[3052]: {"audio_routing": {"zynaddsubfx:part0": ["MDA Ambience"], "MDA Ambience": ["system"]}, "layers": [{"controllers_dict": {"bandwidth": {"value": 64}, "filter.Q depth": {"value": 64}, "portamento thresh": {"value": 1}, "sustain on/off": {"value": 0}, "portamento up/down": {"value": 64}, "poly on/off": {"value": 64}, "filter cutoff": {"value": 67}, "filter resonance": {"value": 67}, "volume": {"value": 107}, "modulation amplitude": {"value": 127}, "drum on/off": {"value": 0}, "bandwidth depth": {"value": 64}, "portamento on/off": {"value": 0}, "res.center depth": {"value": 64}, "panning depth": {"value": 64}, "modulation": {"value": 0}, "res.bw depth": {"value": 64}, "portamento time": {"value": 64}, "filter.cutoff depth": {"value": 64}, "velocity sens.": {"value": 64}, "velocity offs.": {"value": 64}, "modulation exp": {"value": 0}, "panning": {"value": 62}, "legato on/off": {"value": 0}, "resonance bandwidth": {"value": 64}, "bandwidth exp": {"value": 0}, "modulation depth": {"value": 64}, "resonance center": {"value": 64}}, "preset_index": 2, "bank_name": "Arpeggios", "engine_name": "ZynAddSubFX", "engine_nick": "ZY", "preset_info": ["/zynthian/zynthian-data/zynbanks/Arpeggios/0003-Arpeggio3.xiz", [3, 0, 2], "Arpeggio3", "xiz"], "zs3_list": [null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null], "midi_chan": 0, "b
May 04 00:48:15 zynthian startx[3052]: ank_info": ["/zynthian/zynthian-data/zynbanks/Arpeggios", 3, "Arpeggios", "_"], "bank_index": 3, "preset_name": "Arpeggio3", "active_screen_index": 0}, {"controllers_dict": {"size": {"value": 7.0}, "hf_damp": {"value": 70.0}, "output": {"value": 0.0}, "mix": {"value": 90.0}}, "preset_index": 0, "bank_name": null, "engine_name": "Jalv/MDA Ambience", "engine_nick": "JV/MDA Ambience", "preset_info": null, "zs3_list": [null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null], "midi_chan": 0, "bank_info": null, "bank_index": 0, "preset_name": null, "active_screen_index": 0}], "index": 0, "transpose": [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], "extended_config": {"JV/MDA Ambience": null, "ZY": null}, "clone": [[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0,
May 04 00:48:15 zynthian startx[3052]: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]]}
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:SET CONTROLLER SCREEN main
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:ZCTRL 'volume': 107 (0 -> 127), None, None
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:ZCTRL 'panning': 62 (0 -> 127), None, None
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:ZCTRL 'filter cutoff': 67 (0 -> 127), None, None
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:ZCTRL 'filter resonance': 67 (0 -> 127), None, None
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:Removing layer 1 => 1#JV/MDA Ambience ...
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:Dropping from FX-chain zynaddsubfx:part0 => MDA Ambience
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:Disconnecting zynaddsubfx => MDA Ambience
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:Connecting zynaddsubfx => system
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:ZCTRL 'Layer': 0 (0 -> 9), None, None
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:BANK LIST =>
May 04 00:48:15 zynthian startx[3052]: [('/zynthian/zynthian-my-data/zynbanks/XLZ', 0, 'MY/XLZ', 'MY'), ('/zynthian/zynthian-my-data/zynbanks/XMZ', 1, 'MY/XMZ', 'MY'), ('/zynthian/zynthian-my-data/zynbanks/XSZ', 2, 'MY/XSZ', 'MY'), ('/zynthian/zynthian-data/zynbanks/Arpeggios', 3, 'Arpeggios', '_'), ('/zynthian/zynthian-data/zynbanks/Bass', 4, 'Bass', '_'), ('/zynthian/zynthian-data/zynbanks/Brass', 5, 'Brass', '_'), ('/zynthian/zynthian-data/zynbanks/Choir and Voice', 6, 'Choir and Voice', '_'), ('/zynthian/zynthian-data/zynbanks/Collection', 7, 'Collection', '_'), ('/zynthian/zynthian-data/zynbanks/Companion', 8, 'Companion', '_'), ('/zynthian/zynthian-data/zynbanks/Cormi_Noise', 9, 'Cormi Noise', '_'), ('/zynthian/zynthian-data/zynbanks/Cormi_Sound', 10, 'Cormi Sound', '_'), ('/zynthian/zynthian-data/zynbanks/Cris Owl Alvarez', 11, 'Cris Owl Alvarez', '_'), ('/zynthian/zynthian-data/zynbanks/Drums', 12, 'Drums', '_'), ('/zynthian/zynthian-data/zynbanks/Dual', 13, 'Dual', '_'), ('/zynthian/zynthian-data/zynbanks/Fantasy', 14, 'Fantasy', '_'), ('/zynthian/zynthian-data/zynbanks/Guitar', 15, 'Guitar', '_'), ('/zynthian/zynthian-data/zynbanks/Laba170bank', 16, 'Laba170bank', '_'), ('/zynthian/zynthian-data/zynbanks/Misc', 17, 'Misc', '_'), ('/zynthian/zynthian-data/zynbanks/Noises', 18, 'Noises', '_'), ('/zynthian/zynthian-data/zynbanks/Organ', 19, 'Organ', '_'), ('/zynthian/zynthian-data/zynbanks/Pads', 20, 'Pads', '_'), ('/zynthian/zynthian-data/zynbanks/Plucked', 21, 'Plucked', '_'), ('/zynthian/zynthian-data/zynbanks/Reed and Wind', 22, 'Reed and Wind', '_'), ('/zynthian/zynthian-data/zynbanks/Rhodes', 23, 'Rhodes', '_'), ('/zynthian/zynthian-data/zynbanks/Splitted', 24, 'Splitted', '_'), ('/zynthian/zynthian-data/zynbanks/Strings', 25, 'Strings', '_'), ('/zynthian/zynthian-data/zynbanks/Synth', 26, 'Synth', '_'), ('/zynthian/zynthian-data/zynbanks/SynthPiano', 27, 'SynthPiano', '_'), ('/zynthian/zynthian-data/zynbanks/net-wisdom', 28, 'net-wisdom', '_'), ('/zynthian/zynthian-data/zynbanks/olivers-100', 29, 'olivers-100', '_'), ('/zynthian/zynthian
May 04 00:48:15 zynthian startx[3052]: -data/zynbanks/olivers-other', 30, 'olivers-other', '_'), ('/zynthian/zynthian-data/zynbanks/the_mysterious_bank', 31, 'the mysterious bank', '_'), ('/zynthian/zynthian-data/zynbanks/the_mysterious_bank_2', 32, 'the mysterious bank 2', '_'), ('/zynthian/zynthian-data/zynbanks/the_mysterious_bank_3', 33, 'the mysterious bank 3', '_'), ('/zynthian/zynthian-data/zynbanks/the_mysterious_bank_4', 34, 'the mysterious bank 4', '_')]
May 04 00:48:15 zynthian startx[3052]: INFO:root:Getting Preset List for Arpeggios
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:PRESET LIST =>
May 04 00:48:15 zynthian startx[3052]: [('/zynthian/zynthian-data/zynbanks/Arpeggios/0001-Arpeggio1.xiz', [3, 0, 0], 'Arpeggio1', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0002-Arpeggio2.xiz', [3, 0, 1], 'Arpeggio2', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0003-Arpeggio3.xiz', [3, 0, 2], 'Arpeggio3', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0004-Arpeggio4.xiz', [3, 0, 3], 'Arpeggio4', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0005-Arpeggio5.xiz', [3, 0, 4], 'Arpeggio5', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0006-Aporggio6.xiz', [3, 0, 5], 'Aporggio6', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0006-Arpeggio6.xiz', [3, 0, 5], 'Arpeggio6', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0007-Arpeggio7.xiz', [3, 0, 6], 'Arpeggio7', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0008-Arpeggio8.xiz', [3, 0, 7], 'Arpeggio8', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0009-Arpeggio9.xiz', [3, 0, 8], 'Arpeggio9', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0010-Arpeggio10.xiz', [3, 0, 9], 'Arpeggio10', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0011-Arpeggio11.xiz', [3, 0, 10], 'Arpeggio11', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0033-Sequence1.xiz', [3, 0, 32], 'Sequence1', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0034-Sequence2.xiz', [3, 0, 33], 'Sequence2', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0036-Echoed Synth.xiz', [3, 0, 35], 'Echoed Synth', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0037-Echo FX.xiz', [3, 0, 36], 'Echo FX', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0039-Soft Arpeggio1.xiz', [3, 0, 38], 'Soft Arpeggio1', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0040-Soft Arpeggio2.xiz', [3, 0, 39], 'Soft Arpeggio2', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0041-Soft Arpeggio3.xiz', [3, 0, 40], 'Soft Arpeggio3', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0042-Soft Arpeggio4.xiz', [3, 0, 41], 'Soft Arpeggio4', 'xiz'), ('/zynthian/zynthian-data/zynban
May 04 00:48:15 zynthian startx[3052]: ks/Arpeggios/0043-Soft Arpeggio5.xiz', [3, 0, 42], 'Soft Arpeggio5', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0065-Hyper Organ1.xiz', [3, 0, 64], 'Hyper Organ1', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0066-Hyper Arpeggio.xiz', [3, 0, 65], 'Hyper Arpeggio', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0068-Glass Arpeggio1.xiz', [3, 0, 67], 'Glass Arpeggio1', 'xiz'), ('/zynthian/zynthian-data/zynbanks/Arpeggios/0069-Glass Arpeggio2.xiz', [3, 0, 68], 'Glass Arpeggio2', 'xiz')]
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:Removing layer 0 => 1#ZY ...
May 04 00:48:15 zynthian startx[3052]: DEBUG:root:ZCTRL 'Layer': 0 (0 -> 7), None, None
May 04 00:48:15 zynthian startx[3052]: INFO:root:Stoping Engine ZynAddSubFX
May 04 00:48:15 zynthian startx[3052]: ERROR:root:Jack XRUN!
May 04 00:48:15 zynthian startx[3052]: INFO:root:Stoping Engine Jalv/MDA Ambience
May 04 00:48:16 zynthian startx[3052]: INFO:root:ZYNTHIAN-UI OSC server stopped
May 04 00:48:16 zynthian startx[3052]: Zyncoder: Zynswitches poll thread created successfully
May 04 00:48:16 zynthian startx[3052]: ZynMidiRouter: MIDI tuning frequency set to 440 Hz (8192)
May 04 00:48:19 zynthian startx[3052]: ./zynthian.sh: line 127: 3098 Segmentation fault ./zynthian_gui.py
May 04 00:48:19 zynthian startx[3052]: PNG file: /zynthian/config/img/zynthian_logo_error_ip.png - Application must supply a known background gamma
May 04 00:48:19 zynthian startx[3052]: /zynthian/config/img/zynthian_logo_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4545
May 04 00:48:19 zynthian startx[3052]: Zooming image by 100%...done
May 04 00:48:19 zynthian startx[3052]: Merging...didn't find evidence of prior run.
May 04 00:48:19 zynthian startx[3052]: done
May 04 00:48:19 zynthian startx[3052]: Building XImage...done
May 04 00:48:23 zynthian startx[3052]: INFO:root:Wiring Layout PROTOTYPE-4
May 04 00:48:23 zynthian startx[3052]: DEBUG:root:ZYNCODER A: [26, 25, 0, 4]
May 04 00:48:23 zynthian startx[3052]: DEBUG:root:ZYNCODER B: [21, 27, 7, 3]
May 04 00:48:23 zynthian startx[3052]: DEBUG:root:SWITCHES layout: [107, 23, 106, 2]
May 04 00:48:23 zynthian startx[3052]: DEBUG:root:DISABLED_MIDI_IN = ['']
May 04 00:48:23 zynthian startx[3052]: DEBUG:root:ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
May 04 00:48:23 zynthian startx[3052]: DEBUG:root:ENABLED_MIDI_FB = ['WORLDE_MINI_MIDI_1']
May 04 00:48:24 zynthian startx[3052]: libjackpeak registering as 'jackpeak'.
May 04 00:48:24 zynthian startx[3052]: libjackpeak created input ports
May 04 00:48:24 zynthian startx[3052]: INFO:root:ZYNSWITCHES INIT...
May 04 00:48:24 zynthian startx[3052]: INFO:root:SETUP ZYNSWITCH 0 => wpGPIO 107
May 04 00:48:24 zynthian startx[3052]: INFO:root:SETUP ZYNSWITCH 1 => wpGPIO 23
May 04 00:48:24 zynthian startx[3052]: INFO:root:SETUP ZYNSWITCH 2 => wpGPIO 106
May 04 00:48:24 zynthian startx[3052]: INFO:root:SETUP ZYNSWITCH 3 => wpGPIO 2
May 04 00:48:24 zynthian startx[3052]: INFO:root:ZYNTHIAN-UI OSC server running in port 1370
yes, it’s random.
The other one updated ok and the first one with a different image updated ok as well.
But I remember, that I had a timeout when the update process is asking the net time servers.
So this might have destroyed some internals maybe?
I doubt that. Something is causing a “segmentation fault” in the zynthian-ui main process. The candidates for this are “zyncoder” library or the recently added “jackpeak” … ![]()
I had a clone of an image - two weeks old.
I updated the original, had the time server timeout, updated twice and got the same error. I debugged into and saw, that the return code was 139.
Then I took the cloned image, updated and it worked.
Really obscure
When using CPU meter instead Audio Level, the problem is not present. Could you confirm that?
I was just about to type how it had stayed up with cpu rather than audio for fifteen minutes,
When it went down.
May 06 16:41:17 zynthian-amp2 startx[443]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
May 06 16:41:30 zynthian-amp2 startx[443]: ERROR:root:Jack XRUN!
May 06 17:55:13 zynthian-amp2 startx[443]: JackPosixSemaphore::TimedWait err = Connection timed out
May 06 17:55:13 zynthian-amp2 startx[443]: SuspendRefNum error
May 06 17:55:13 zynthian-amp2 startx[443]: JackClient::Execute error name = ZynMidiRouter
May 06 16:55:15 zynthian-amp2 startx[443]: Server is not running
My faulty image doesn’t boot up anymore. Hence I can’t confirm the potential cause.
@stevewilliam007, excuse me, what itunes has to do with this? What “problem” and “application” do you mean?
ITunes is mentioned as part of the bonjour config for windows access
Pretty sure an internet bot
I deleted the post to hide the link
It was my first thought. I hope it’s a single case …
