Record pattern from MIDI keyboard without UI hardware?
I’m trying to record a pattern using Oram, using my MIDI keyboard as input.
I’m on a stock RPi5 without Zynthian hardware. (What’s this called, BTW?)
I see in a tutorial video that I can do this by arming record using the Record button and then hitting the Play button. How can I do this without these buttons?
I see there’s a great WebUI tool for keyboard shortcuts. Unfortunately, there aren’t actions that correspond to these buttons. (There should be an action for every button!)
In the old discussion when keyboard shortcuts were added, someone suggested having a Play button, and the question was, what to play? Well, whatever hitting the PLAY button would play!
Is there any workaround? This is a deal-killer for me using the pattern editor – not being able to record from my MIDI keyboard. I do not plan to get Zynth hardware, nifty as it may be.
The easiest way would be to enable the virtual onscreen buttons in webconf under Interface > UI Options > Touch Navigation > V5 Keypad.
I’m sure there is a touch input only workflow for recordign patterns, but I don’t know it (There might be an option “record from midi” in the pattern menu, see section 22).
Thanks! I tried the VNC but got only the same display as HDMI. I didn’t try that UI option. It’s actually called Graphics & Usability → Touch Navigation → V5 Keypad at left/right, but you gave me the clue I needed.
If there isn’t a hot key for these buttons, I’ll open an issue to add that.
I think in Oram they should be permanently on when enabled, but maybe the recent changes were also included in oram. With vangelis they switch on/off by tapping the vu-meter-bar on the top right corner.
Ok, I looked it up on my vangelis machine, seems they changed the menu descriptions. Glad you found it.
