I purchased the Zynthian kit v1 long ago (2016) and just updated to a new image:
2020-06-03-zynthianos-buster-lite-armhf-1.0.0.zip
flashed onto a new sd card.
Booting the box, first I had to switch to kit v1 in the web gui.
After reboot, red error and the ip address shows.
I can ssh into the box and ran the update commands:
cd /zynthian/zynthian-sys/scripts
./update_zynthian.sh
./update_zynthian_data.sh
reboot
Here is the UI log:
– Logs begin at Sat 2020-06-06 21:42:27 BST. –
Jun 06 21:47:16 zynthian startx[521]: Cannot connect to server socket err = No such file or directory
Jun 06 21:47:16 zynthian startx[521]: Cannot connect to server request channel
Jun 06 21:47:16 zynthian startx[521]: jack server is not running or cannot be started
Jun 06 21:47:16 zynthian startx[521]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Jun 06 21:47:16 zynthian startx[521]: libjackpeak failed to start jack client: 17
Jun 06 21:47:17 zynthian startx[521]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Jun 06 21:47:17 zynthian startx[521]: /zynthian/config/img/fb_zynthian_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Jun 06 21:47:17 zynthian startx[521]: Zooming image by 100%...done
Jun 06 21:47:17 zynthian startx[521]: Merging...done
Jun 06 21:47:17 zynthian startx[521]: Building XImage...done
Jun 06 21:47:25 zynthian systemd[1]: zynthian.service: Stopping timed out. Terminating.
Jun 06 21:47:25 zynthian systemd[1]: zynthian.service: Control process exited, code=killed, status=15/TERM
Jun 06 21:47:25 zynthian startx[521]: xinit: connection to X server lost
Jun 06 21:47:25 zynthian startx[521]: [1B blob data]
Jun 06 21:47:25 zynthian startx[521]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Jun 06 21:47:26 zynthian startx[521]: xinit: unexpected signal 15
Jun 06 21:47:26 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 21:47:26 zynthian systemd[1]: zynthian.service: Failed with result 'timeout'.
Jun 06 21:47:26 zynthian systemd[1]: Stopped Zynthian User Interface.
Jun 06 21:47:26 zynthian systemd[1]: Started Zynthian User Interface.
Jun 06 21:47:26 zynthian startx[756]: X.Org X Server 1.20.4
Jun 06 21:47:26 zynthian startx[756]: X Protocol Version 11, Revision 0
Jun 06 21:47:26 zynthian startx[756]: Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
Jun 06 21:47:26 zynthian startx[756]: Current Operating System: Linux zynthian 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l
Jun 06 21:47:26 zynthian startx[756]: Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Jun 06 21:47:26 zynthian startx[756]: Build Date: 05 June 2019 12:49:54PM
Jun 06 21:47:26 zynthian startx[756]: xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
Jun 06 21:47:26 zynthian startx[756]: Current version of pixman: 0.36.0
Jun 06 21:47:26 zynthian startx[756]: Before reporting problems, check http://wiki.x.org
Jun 06 21:47:26 zynthian startx[756]: to make sure that you have the latest version.
Jun 06 21:47:26 zynthian startx[756]: Markers: (--) probed, (**) from config file, (==) default setting,
Jun 06 21:47:26 zynthian startx[756]: (++) from command line, (!!) notice, (II) informational,
Jun 06 21:47:26 zynthian startx[756]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jun 06 21:47:26 zynthian startx[756]: (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jun 6 21:47:26 2020
Jun 06 21:47:26 zynthian startx[756]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Jun 06 21:47:26 zynthian startx[756]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Jun 06 21:51:35 zynthian systemd[1]: Stopping Zynthian User Interface...
Jun 06 21:51:35 zynthian startx[756]: Terminated
Jun 06 21:51:36 zynthian startx[756]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Jun 06 21:51:36 zynthian startx[756]: /zynthian/config/img/fb_zynthian_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Jun 06 21:51:36 zynthian startx[756]: Zooming image by 100%...done
Jun 06 21:51:36 zynthian startx[756]: Merging...didn't find evidence of prior run.
Jun 06 21:51:36 zynthian startx[756]: done
Jun 06 21:51:36 zynthian startx[756]: Building XImage...done
Jun 06 21:51:45 zynthian startx[756]: WARNING:zynthian_gui_keybinding: Can't load keyboard binding config file '/zynthian/config/keybinding.yaml'. Using default.
Jun 06 21:51:45 zynthian startx[756]: Cannot connect to server socket err = No such file or directory
Jun 06 21:51:45 zynthian startx[756]: Cannot connect to server request channel
Jun 06 21:51:45 zynthian startx[756]: jack server is not running or cannot be started
Jun 06 21:51:45 zynthian startx[756]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Jun 06 21:51:45 zynthian startx[756]: libjackpeak failed to start jack client: 17
Jun 06 21:51:46 zynthian startx[756]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Jun 06 21:51:46 zynthian startx[756]: /zynthian/config/img/fb_zynthian_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Jun 06 21:51:46 zynthian startx[756]: Zooming image by 100%...done
Jun 06 21:51:46 zynthian startx[756]: Merging...done
Jun 06 21:51:46 zynthian startx[756]: Building XImage...done
Jun 06 21:51:55 zynthian startx[756]: WARNING:zynthian_gui_keybinding: Can't load keyboard binding config file '/zynthian/config/keybinding.yaml'. Using default.
Jun 06 21:51:55 zynthian startx[756]: Cannot connect to server socket err = No such file or directory
Jun 06 21:51:55 zynthian startx[756]: Cannot connect to server request channel
Jun 06 21:51:55 zynthian startx[756]: jack server is not running or cannot be started
Jun 06 21:51:55 zynthian startx[756]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Jun 06 21:51:55 zynthian startx[756]: libjackpeak failed to start jack client: 17
Jun 06 21:51:55 zynthian systemd[1]: zynthian.service: Stopping timed out. Terminating.
Jun 06 21:51:55 zynthian systemd[1]: zynthian.service: Control process exited, code=killed, status=15/TERM
Jun 06 21:51:55 zynthian startx[756]: xinit: connection to X server lost
Jun 06 21:51:55 zynthian startx[756]: [1B blob data]
Jun 06 21:51:56 zynthian startx[756]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Jun 06 21:51:56 zynthian startx[756]: xinit: unexpected signal 15
Jun 06 21:51:56 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Jun 06 21:51:56 zynthian systemd[1]: zynthian.service: Failed with result 'timeout'.
Jun 06 21:51:56 zynthian systemd[1]: Stopped Zynthian User Interface.
Jun 06 21:51:56 zynthian systemd[1]: Started Zynthian User Interface.
Jun 06 21:51:57 zynthian startx[919]: X.Org X Server 1.20.4
Jun 06 21:51:57 zynthian startx[919]: X Protocol Version 11, Revision 0
Jun 06 21:51:57 zynthian startx[919]: Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
Jun 06 21:51:57 zynthian startx[919]: Current Operating System: Linux zynthian 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l
Jun 06 21:51:57 zynthian startx[919]: Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Jun 06 21:51:57 zynthian startx[919]: Build Date: 05 June 2019 12:49:54PM
Jun 06 21:51:57 zynthian startx[919]: xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
Jun 06 21:51:57 zynthian startx[919]: Current version of pixman: 0.36.0
Jun 06 21:51:57 zynthian startx[919]: Before reporting problems, check http://wiki.x.org
Jun 06 21:51:57 zynthian startx[919]: to make sure that you have the latest version.
Jun 06 21:51:57 zynthian startx[919]: Markers: (--) probed, (**) from config file, (==) default setting,
Jun 06 21:51:57 zynthian startx[919]: (++) from command line, (!!) notice, (II) informational,
Jun 06 21:51:57 zynthian startx[919]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Jun 06 21:51:57 zynthian startx[919]: (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jun 6 21:51:57 2020
Jun 06 21:51:57 zynthian startx[919]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Jun 06 21:51:57 zynthian startx[919]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Jun 06 21:51:59 zynthian systemd[1]: Stopping Zynthian User Interface...
Jun 06 21:51:59 zynthian startx[919]: Terminated
Jun 06 21:51:59 zynthian startx[919]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Jun 06 21:51:59 zynthian startx[919]: /zynthian/config/img/fb_zynthian_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Jun 06 21:51:59 zynthian startx[919]: Zooming image by 100%...done
Jun 06 21:51:59 zynthian startx[919]: Merging...didn't find evidence of prior run.
Jun 06 21:51:59 zynthian startx[919]: done
Jun 06 21:51:59 zynthian startx[919]: Building XImage...done
Here is lsmod output:
root@zynthian:~# lsmod
Module Size Used by
nft_counter 16384 1
nft_chain_route_ipv4 16384 1
xt_DSCP 16384 1
xt_tcpudp 16384 1
nft_compat 20480 2
nf_tables 122880 7 nft_compat,nft_chain_route_ipv4,nft_counter
nfnetlink 16384 2 nft_compat,nf_tables
cfg80211 651264 0
rfkill 28672 2 cfg80211
8021q 32768 0
garp 16384 1 8021q
stp 16384 1 garp
llc 16384 2 garp,stp
joydev 20480 0
fb_ili9340 16384 1
fbtft 45056 1 fb_ili9340
syscopyarea 16384 1 fbtft
sysfillrect 16384 1 fbtft
sysimgblt 16384 1 fbtft
fb_sys_fops 16384 1 fbtft
snd_soc_pcm512x_i2c 16384 1
snd_soc_pcm512x 32768 1 snd_soc_pcm512x_i2c
evdev 24576 7
raspberrypi_hwmon 16384 0
hwmon 16384 1 raspberrypi_hwmon
snd_soc_hifiberry_dacplus 16384 1
snd_soc_bcm2835_i2s 20480 2
bcm2835_codec 36864 0
snd_soc_core 192512 3 snd_soc_pcm512x,snd_soc_hifiberry_dacplus,snd_soc_bcm2835_i2s
snd_compress 20480 1 snd_soc_core
bcm2835_v4l2 45056 0
v4l2_mem2mem 24576 1 bcm2835_codec
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_pcm 102400 5 snd_soc_pcm512x,snd_pcm_dmaengine,snd_soc_hifiberry_dacplus,snd_soc_bcm2835_i2s,snd_soc_core
gpio_backlight 16384 0
bcm2835_mmal_vchiq 32768 2 bcm2835_codec,bcm2835_v4l2
snd_timer 32768 1 snd_pcm
videobuf2_dma_contig 20480 1 bcm2835_codec
v4l2_common 16384 1 bcm2835_v4l2
videobuf2_vmalloc 16384 1 bcm2835_v4l2
snd 73728 7 snd_compress,snd_soc_pcm512x,snd_timer,snd_soc_core,snd_pcm
videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_vmalloc
videobuf2_v4l2 24576 3 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem
i2c_bcm2835 16384 0
videobuf2_common 45056 4 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
videodev 200704 6 bcm2835_codec,v4l2_common,videobuf2_common,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
spi_bcm2835 20480 0
media 36864 3 bcm2835_codec,videodev,v4l2_mem2mem
vc_sm_cma 36864 1 bcm2835_mmal_vchiq
clk_hifiberry_dacpro 16384 1
uio_pdrv_genirq 16384 0
uio 20480 1 uio_pdrv_genirq
fixed 16384 3
stmpe_ts 16384 0
i2c_dev 20480 0
ip_tables 24576 0
x_tables 32768 4 ip_tables,nft_compat,xt_tcpudp,xt_DSCP
ipv6 454656 26
It looks like Jack and X11 fail to start.
aplay -L
root@zynthian:~# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=sndrpihifiberry
snd_rpi_hifiberry_dacplus, HiFiBerry DAC+ HiFi pcm512x-hifi-0
Default Audio Device
sysdefault:CARD=sndrpihifiberry
dmix:CARD=sndrpihifiberry,DEV=0
Direct sample mixing device
dsnoop:CARD=sndrpihifiberry,DEV=0
Direct sample snooping device
hw:CARD=sndrpihifiberry,DEV=0
Direct hardware device without any conversions
plughw:CARD=sndrpihifiberry,DEV=0
Hardware device with all software conversions
Any idea or suggestion?
